I am having trouble outputting data to a SSD1306 oled display using a pico and the Adafruit_SSD1306 library. The program I am using is based on the example and it compiles and runs fine when using commands like:
display.println(F("sText"));
That is fine if you just want to display a line of text that never varies, however, when you try to print a string using a variable it fails to compile. Changing the line of code above to the two lines below gives an error: "Error compiling for board Raspberry Pi Pico".
String s = "sText";
display.println(F(s));
I have not seen this problem described elsewhere. I know the thing is wired ok because it displays the "sText" string when it is not passed as a variable.
Any thoughts?
Try again with verbose turned on and paste the entire compiler output log here in code tags. My hunch is the F is not allowed for the Pico. Compiler warnings Default of course.
The F() macro is only for literal strings (i.e. "This is a literal string") not Strings with a capital S variables. Or any other kind of variables for that matter.
And in any case, it has no effect on the Pico. Leave it off.
MOD EDIT
For the sake of sanity I have added code tags to the error output
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\j6sum\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\j6sum\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\j6sum\OneDrive\Documents\Arduino\libraries -fqbn=rp2040:rp2040:rpipicow:flash=2097152_0,freq=133,opt=Small,rtti=Disabled,stackprotect=Disabled,exceptions=Disabled,dbgport=Disabled,dbglvl=None,usbstack=picosdk,wificountry=worldwide,ipbtstack=ipv4only,uploadmethod=default -vid-pid=2E8A_F00A -ide-version=10819 -build-path C:\Users\j6sum\AppData\Local\Temp\arduino_build_184452 -warnings=none -build-cache C:\Users\j6sum\AppData\Local\Temp\arduino_cache_453617 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.pqt-pioasm.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-pioasm\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-pioasm-1.5.0-b-c7bab52.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-pioasm\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-openocd.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-openocd\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-openocd-1.5.0-b-c7bab52.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-openocd\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-picotool.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-picotool\1.5.0-b-03f2812 -prefs=runtime.tools.pqt-picotool-1.5.0-b-03f2812.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-picotool\1.5.0-b-03f2812 -prefs=runtime.tools.pqt-elf2uf2.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-elf2uf2\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-elf2uf2-1.5.0-b-c7bab52.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-elf2uf2\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-python3.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-python3\1.0.1-base-3a57aed -prefs=runtime.tools.pqt-python3-1.0.1-base-3a57aed.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-python3\1.0.1-base-3a57aed -prefs=runtime.tools.pqt-gcc.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-gcc-1.5.0-b-c7bab52.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-mklittlefs.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-mklittlefs\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-mklittlefs-1.5.0-b-c7bab52.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-mklittlefs\1.5.0-b-c7bab52 -verbose C:\Users\j6sum\OneDrive\Documents\Arduino\OLED_DEV\OLED_DEV.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\j6sum\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\j6sum\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\j6sum\OneDrive\Documents\Arduino\libraries -fqbn=rp2040:rp2040:rpipicow:flash=2097152_0,freq=133,opt=Small,rtti=Disabled,stackprotect=Disabled,exceptions=Disabled,dbgport=Disabled,dbglvl=None,usbstack=picosdk,wificountry=worldwide,ipbtstack=ipv4only,uploadmethod=default -vid-pid=2E8A_F00A -ide-version=10819 -build-path C:\Users\j6sum\AppData\Local\Temp\arduino_build_184452 -warnings=none -build-cache C:\Users\j6sum\AppData\Local\Temp\arduino_cache_453617 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.pqt-pioasm.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-pioasm\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-pioasm-1.5.0-b-c7bab52.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-pioasm\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-openocd.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-openocd\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-openocd-1.5.0-b-c7bab52.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-openocd\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-picotool.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-picotool\1.5.0-b-03f2812 -prefs=runtime.tools.pqt-picotool-1.5.0-b-03f2812.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-picotool\1.5.0-b-03f2812 -prefs=runtime.tools.pqt-elf2uf2.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-elf2uf2\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-elf2uf2-1.5.0-b-c7bab52.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-elf2uf2\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-python3.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-python3\1.0.1-base-3a57aed -prefs=runtime.tools.pqt-python3-1.0.1-base-3a57aed.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-python3\1.0.1-base-3a57aed -prefs=runtime.tools.pqt-gcc.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-gcc-1.5.0-b-c7bab52.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-mklittlefs.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-mklittlefs\1.5.0-b-c7bab52 -prefs=runtime.tools.pqt-mklittlefs-1.5.0-b-c7bab52.path=C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\tools\pqt-mklittlefs\1.5.0-b-c7bab52 -verbose C:\Users\j6sum\OneDrive\Documents\Arduino\OLED_DEV\OLED_DEV.ino
Using board 'rpipicow' from platform in folder: C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.2.2
Using core 'rp2040' from platform in folder: C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.2.2
Detecting libraries used...
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452\\sketch\\OLED_DEV.ino.cpp" -o nul
Alternatives for Adafruit_SSD1306.h: [Adafruit_SSD1306@2.5.13]
ResolveLibrary(Adafruit_SSD1306.h)
-> candidates: [Adafruit_SSD1306@2.5.13]
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452\\sketch\\OLED_DEV.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.11.11]
ResolveLibrary(Adafruit_GFX.h)
-> candidates: [Adafruit_GFX_Library@1.11.11]
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452\\sketch\\OLED_DEV.ino.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.16.3]
ResolveLibrary(Adafruit_I2CDevice.h)
-> candidates: [Adafruit_BusIO@1.16.3]
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452\\sketch\\OLED_DEV.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\Wire\\src" "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452\\sketch\\OLED_DEV.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\Wire\\src" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\SPI\\src" "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452\\sketch\\OLED_DEV.ino.cpp" -o nul
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\Wire\\src" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\SPI\\src" "C:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306\\Adafruit_SSD1306.cpp" -o nul
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\Wire\\src" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\SPI\\src" "C:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp" -o nul
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\Wire\\src" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\SPI\\src" "C:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\Wire\\src" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\SPI\\src" "C:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp" -o nul
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\Wire\\src" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\SPI\\src" "C:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\glcdfont.c" -o nul
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\Wire\\src" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\SPI\\src" "C:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o nul
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\Wire\\src" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\SPI\\src" "C:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o nul
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\Wire\\src" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\SPI\\src" "C:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp" -o nul
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\Wire\\src" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\SPI\\src" "C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\Wire\\src" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\SPI\\src" "C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\SPI\\src\\SPI.cpp" -o nul
Generating function prototypes...
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\Wire\\src" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\SPI\\src" "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452\\sketch\\OLED_DEV.ino.cpp" -o "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-python3\\1.0.1-base-3a57aed/python3" -I "C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/tools/signing.py" --mode header --publickey "C:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\OLED_DEV/public.key" --out "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core/Updater_Signing.h"
"C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.5.0-b-c7bab52/bin/arm-none-eabi-g++" -I "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico W\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipicow\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/" "@C:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/lib/platform_inc.txt" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO_W "-DBOARD_NAME=\"RASPBERRY_PI_PICO_W\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\cores\\rp2040" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\variants\\rpipicow" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\j6sum\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\Wire\\src" "-IC:\\Users\\j6sum\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.2.2\\libraries\\SPI\\src" "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452\\sketch\\OLED_DEV.ino.cpp" -o "C:\\Users\\j6sum\\AppData\\Local\\Temp\\arduino_build_184452\\sketch\\OLED_DEV.ino.cpp.o"
In file included from C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.2.2\cores\rp2040/api/String.h:2,
from c:\users\j6sum\appdata\local\arduino15\packages\rp2040\hardware\rp2040\3.2.2\arduinocore-api\api\IPAddress.h:23,
from c:\users\j6sum\appdata\local\arduino15\packages\rp2040\hardware\rp2040\3.2.2\arduinocore-api\api\arduinoapi.h:30,
from C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.2.2\cores\rp2040/api/ArduinoAPI.h:2,
from C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.2.2\cores\rp2040/Arduino.h:28,
from C:\Users\j6sum\AppData\Local\Temp\arduino_build_184452\sketch\OLED_DEV.ino.cpp:1:
C:\Users\j6sum\OneDrive\Documents\Arduino\OLED_DEV\OLED_DEV.ino: In function 'void loop()':
c:\users\j6sum\appdata\local\arduino15\packages\rp2040\hardware\rp2040\3.2.2\arduinocore-api\api\string.h:45:28: error: invalid cast from type 'arduino::String' to type 'const arduino::__FlashStringHelper*'
45 | #define F(string_literal) (reinterpret_cast<const __FlashStringHelper *>(PSTR(string_literal)))
C:\Users\j6sum\OneDrive\Documents\Arduino\OLED_DEV\OLED_DEV.ino:37:21: note: in expansion of macro 'F'
37 | display.println(F(string));
Using library Adafruit_SSD1306 at version 2.5.13 in folder: C:\Users\j6sum\OneDrive\Documents\Arduino\libraries\Adafruit_SSD1306
Using library Adafruit_GFX_Library at version 1.11.11 in folder: C:\Users\j6sum\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_BusIO at version 1.16.3 in folder: C:\Users\j6sum\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 1.0 in folder: C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.2.2\libraries\Wire
Using library SPI at version 1.0 in folder: C:\Users\j6sum\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.2.2\libraries\SPI
exit status 1
Error compiling for board Raspberry Pi Pico W.
Thanks. It is now working. I had tried unsuccessfully to do what you recommend before posting, but now I see that I had the board set to be pico W not the wireless version. I suspect that my issue had to do with differences between the wired and wireless versions.
Thanks again for your help.
Pico W IS wireless.
Right. I had a non-wireless board and had the IDE set to wireless. When I set the IDE to the correct board it worked.
