Problem compiling, no bootloader since .csv swap
We're a team working on Olimex's esp-32-poe-iso, everything was well until we tried their 16 mbs boards and had to change the csv and the config.
But ever since when i try to compile i'm met with a "No such file or directory: 'C:\Users\conta\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\tools\sdk\esp32\bin\bootloader_dio_40m.elf'" alongside a fal from esptool.py which I can't seem to fix.
I'm on a Windows 11 pc with arduino 1.8.19.
here's a screenshot of the output
I've found similar problems with notably platformIO breaking their config file after an update and I'm suspecting something along those lines but I'm not on platformIO and can't seem to find someone who had the same issue.
Also :
  • My Teammate has no issue compiling
  • The path displayed is for my computer so it's not hardcoded in the file
  • And on his end the compilation now takes 10-15 more time than before and seemingly goes into every installed library to "check them", I don't know if it's related.
    Thank you for reading this and thanks in advance for your answers.
