Problem compilling with Servo.h and VirtualWire.h
hi i got this error while trying to verify/upload my sketch.
Servo\Servo.cpp.o: In function __vector_11': C:\Program Files\arduino-1.0.1\libraries\Servo/Servo.cpp:103: multiple definition of __vector_11'
VirtualWire\VirtualWire.cpp.o:C:\Program Files\arduino-1.0.1\libraries\VirtualWire/VirtualWire.cpp:416: first defined here
here is my full code
#include <VirtualWire.h>
#include <Servo.h>
  int ledPin = 13;
  Servo motorPin;
  Servo motorPin2;
  Servo motorPin3;
  Servo motorPin4;
      Serial.begin(9600);	// Debugging only
      Serial.println("setup");
      // Initialise the IO and ISR
      vw_set_ptt_inverted(true); // Required for DR3100
      vw_setup(2000);	 // Bits per sec
      vw_set_rx_pin(2);
      vw_rx_start();       // Start the receiver PLL running
  pinMode(ledPin, OUTPUT);
  motorPin.attach(12);
  motorPin2.attach(11);
  motorPin3.attach(9);
  motorPin4.attach(8);
      uint8_t buf[VW_MAX_MESSAGE_LEN];
      uint8_t buflen = VW_MAX_MESSAGE_LEN;
      if (vw_get_message(buf, &buflen)) // Non-blocking
  	int i= 0;
        // Flash a light to show received good message
  	// Message with a good checksum received, dump it.
  	Serial.print("Got: ");
          if(buf[i] == '1')
            digitalWrite(ledPin, HIGH);
            motorPin.write(180);
            motorPin2.write(180);
            motorPin3.write(180);
            motorPin4.write(180);
         if(buf[i] == '2')
            motorPin2.write(0);
            motorPin4.write(0);
        if(buf[i] == '3')
            motorPin.write(0);
            motorPin3.write(0);
        if(buf[i] == '4')
            motorPin.write(0);
            motorPin2.write(0);
            motorPin3.write(0);
            motorPin4.write(0);
        if(buf[i] == '5')
            motorPin.write(90);
            motorPin2.write(90);
            motorPin3.write(90);
            motorPin4.write(90);
        digitalWrite(ledPin, LOW);
also some little info
I'm using
-Arduino uno
-RF Link Transmitter - 434MHz
-RF Link Receiver - 4800bps (434MHz)
-using Arduino 1.01
so do you guys have any idea on how i can fix this? :~
11 & 12 are the default pins for virtual wlre.
You need to use the commands like this one
vw_set_rx_pin(2);
to change them both.
VirtualWire.cpp:
// This is the interrupt service routine called when timer1 overflows
// Its job is to output the next bit from the transmitter (every 8 calls)
// and to call the PLL code if the receiver is enabled
//ISR(SIG_OUTPUT_COMPARE1A)
SIGNAL(TIMER1_COMPA_vect)   // <<---- line 416
Servo.cpp:
// Wiring pre-defines signal handlers so don't define any if compiling for the Wiring platform
// Interrupt handlers for Arduino
#if defined(_useTimer1)
SIGNAL (TIMER1_COMPA_vect)   // <<----- line 103
  handle_interrupts(_timer1, &TCNT1, &OCR1A);
They both user Timer 1. Thus they are incompatible.
So is there a way around that?
Rewrite VirtualWire to use another timer?
I have same problem with above servo.h and virtualwire.h not working together because of they are using same TIMER.
The solution is;
I know it but how can we rewrite virtualwire.cpp?
I changed SIGNAL(TIMER1_COMPA_vect) to SIGNAL(TIMER2_COMPA_vect) then I saved file. Afterwards virtualwire not works any more with or without servo.h library.
help ;(
There is more to it than that. For one thing Timer1 is a 16-bit timer and Timer2 is an 8-bit timer. Next you have to change other stuff to make it use that timer.
Hi Nick,
Thanks for replying,
I changed SIGNAL(TIMER1_COMPA_vect) to SIGNAL(TIMER2_COMPA_vect) just because of this link Demande d'aide pour ce code (Voiture téléguidée) - Français - Arduino Forum (pls look at the undermost message). He changed timer1 to timer2 then it works as far as I understand it (meanwhile I dont know french, I used google translation.)
As I learn timer0/2 8bit timer1/3/4/5 8bit timers. And the solution of this problem is using ServoTimer2 or SoftwareServo library. But I want to use servo.h and virtualwire.h
What can I do more ? What will be changed in virtualwire.cpp?
thanks
Note: when I write virtualwire.cpp library codes it gives an error max length (9500 characters)
