This current project is running 6 TOF sensors as well as 6 servos. I am currently able to connect 5 sensors to the I2C bus, however, when I connect the sensor on A2 to pins A4 and A5, none of the other sensors work; The servo driver that also runs on the I2C bus still functions, however. After testing different sensors and various other things, here's what I know for sure:
- The sensor I am trying to connect is functional, and I can get a reading from it if I swap it to another sensor's pins.
- The A2 pin doesn't seem to be the issue, because the issue persists if I connect it to A6 instead.
- All of the other functions of the code work without any issues if I disconnect the SDA and SCL pins to this sensor, and I can even leave the VCC, GND, and XSHUT pins in.
Here's the code I followed to initialize and read from multiple sensors:
Here's my code:
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
#include <VL53L0X.h>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
VL53L0X pinch1;
VL53L0X grab1;
VL53L0X wrist1;
VL53L0X wrist2;
VL53L0X wrist3;
VL53L0X open1;
#define SERVOMINSTOP 100
#define SERVOMIN (120) // This is the 'minimum' pulse length count (out of 4096)
#define SERVOMID 300
#define SERVOMID4 210
#define SERVOMAX (400) // This is the 'maximum' pulse length count (out of 4096)
#define SERVOMAXSTOP 210
#define SERVOMAXSTOP1 200
#define SERVOMAXSTOP2 250
#define SERVO_FREQ 50 // Analog servos run at ~50 Hz updates
//int sensorPin = A0;
//int sensorPin1 = A1;
//int sensorPin2 = A2;// select the input pin for the potentiometer // select the pin for the LED
int grabstate=0;
int wriststate=0;
int w;
int o;
int g;
int p;
int w2;
int w3;
//unsigned long duration;
//unsigned long duration1;
//unsigned long duration2;
struct servo {
int id;
int minPos;
int midPos;
int maxPos;
int maxPos2;
//void servoUp(struct servo servoID) {
// Serial.println(servoID.id);
// for (uint16_t pulselen = servoID.minPos; pulselen < servoID.maxPos; pulselen++) {
// pwm.setPWM(servoID.id, 0, pulselen);
// Serial.println("Done Up");
//void servoDown(struct servo servoID) {
// for (uint16_t pulselen = servoID.maxPos; pulselen > servoID.minPos; pulselen--) {
// Serial.println("Done Down");
// our servo # counter
//uint8_t servonum = 0;
struct servo servo0;
struct servo servo1;
struct servo servo2;
struct servo servo3;
struct servo servo4;
struct servo servo5;
servo0.id = 0;
servo0.minPos = SERVOMINSTOP;
servo0.midPos = SERVOMID;
servo0.maxPos = SERVOMAXSTOP;
servo1.id = 1;
servo1.minPos = SERVOMIN;
servo1.midPos = SERVOMID;
servo1.maxPos = SERVOMAX;
servo1.maxPos2 = SERVOMAXSTOP1;
servo2.id = 2;
servo2.minPos = SERVOMIN;
servo2.midPos = SERVOMID;
servo2.maxPos = SERVOMAX;
servo2.maxPos2 = SERVOMAXSTOP2;
servo3.id = 3;
servo3.minPos = SERVOMIN;
servo3.midPos = SERVOMID;
servo3.maxPos = SERVOMAX;
servo4.id = 4;
servo4.minPos = SERVOMIN;
servo4.midPos = SERVOMID4;
servo4.maxPos = SERVOMAX;
servo5.id = 5;
servo5.minPos = SERVOMIN;
servo5.midPos = SERVOMID4;
servo5.maxPos = SERVOMAX;
pwm.begin();
pwm.setOscillatorFrequency(27000000);
pwm.setPWMFreq(SERVO_FREQ); // Analog servos run at ~50 Hz updates
delay(10);
pinMode(A3, OUTPUT);
pinMode(A2, OUTPUT);
pinMode(A1, OUTPUT);
pinMode(A0, OUTPUT);
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
pinMode(10, OUTPUT);
pinMode(9, OUTPUT);
pinMode(8, OUTPUT);
pinMode(7, OUTPUT);
pinMode(6, OUTPUT);
pinMode(5, OUTPUT);
pinMode(4, OUTPUT);
pinMode(3, OUTPUT);
pinMode(2, OUTPUT);
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
digitalWrite(5, LOW);
digitalWrite(6, LOW);
digitalWrite(7, LOW);
digitalWrite(8, LOW);
digitalWrite(9, LOW);
digitalWrite(10, LOW);
digitalWrite(11, LOW);
digitalWrite(12, LOW);
digitalWrite(13, LOW);
digitalWrite(A0, LOW);
digitalWrite(A1, LOW);
digitalWrite(A2, LOW);
digitalWrite(A3, LOW);
Wire.begin();
digitalWrite(6, HIGH);
delay(150);
Serial.println("00");
pinch1.init(true);
Serial.println("01");
delay(100);
pinch1.setAddress((uint8_t)01);
Serial.println("02");
digitalWrite(4, HIGH);
delay(150);
grab1.init(true);
Serial.println("03");
delay(100);
grab1.setAddress((uint8_t)02);
Serial.println("04");
digitalWrite(A1, HIGH);
delay(150);
Serial.println("10");
wrist1.init(true);
Serial.println("11");
delay(100);
wrist1.setAddress((uint8_t)03);
Serial.println("12");
digitalWrite(A0, HIGH);
delay(150);
Serial.println("13");
open1.init(true);
Serial.println("14");
delay(100);
open1.setAddress((uint8_t)05);
Serial.println("15");
digitalWrite(A2, HIGH);
delay(150);
wrist2.init(true);
delay(100);
wrist2.setAddress((uint8_t)06);
Serial.println("addresses set");
digitalWrite(A3, HIGH);
delay(150);
wrist3.init(true);
delay(100);
wrist3.setAddress((uint8_t)07);
servoMinUpToMax(servo3);
delay(100);
servoMaxDownToMin(servo1);
servoMaxDownToMin(servo2);
servoMinUpToMax(servo4);
servoMaxDownToMin(servo0);
servoMinUpToMax(servo5);
pinch1.startContinuous();
grab1.startContinuous();
wrist1.startContinuous();
wrist2.startContinuous();
wrist3.startContinuous();
open1.startContinuous();
// You can use this function if you'd like to set the pulse length in seconds
// e.g. setServoPulse(0, 0.001) is a ~1 millisecond pulse width. It's not precise!
void setServoPulse(uint8_t n, double pulse) {
double pulselength;
pulselength = 1000000; // 1,000,000 us per second
pulselength /= SERVO_FREQ; // Analog servos run at ~60 Hz updates
Serial.print(pulselength); Serial.println(" us per period");
pulselength /= 4096; // 12 bits of resolution
Serial.print(pulselength); Serial.println(" us per bit");
pulse *= 1000000; // convert input seconds to us
pulse /= pulselength;
Serial.println(pulse);
pwm.setPWM(n, 0, pulse);
void servoMinUpToMid(struct servo servoID) {
for (uint16_t pulselen = servoID.minPos; pulselen < servoID.midPos; pulselen++) {
Serial.println("Done MinUpToMid");
void servoMaxDownToMid(struct servo servoID) {
for (uint16_t pulselen = servoID.maxPos; pulselen > servoID.midPos; pulselen--) {
Serial.println("Done MaxDownToMid");
void servoMidUpToMax(struct servo servoID) {
for (uint16_t pulselen = servoID.midPos; pulselen < servoID.maxPos; pulselen++) {
Serial.println("Done MidUpToMax");
void servoMidDownToMin(struct servo servoID) {
for (uint16_t pulselen = servoID.midPos; pulselen > servoID.minPos; pulselen--) {
Serial.println("Done MidDownToMin");
void servoMaxDownToMin(struct servo servoID) {
Serial.println("Done MaxDownToMin");
void servoMinUpToMax(struct servo servoID) {
Serial.println("MinUpToMax");
void servoMinUpToMax2(struct servo servoID) {
for (uint16_t pulselen = servoID.minPos; pulselen < servoID.maxPos2; pulselen++) {
g=grab1.readRangeContinuousMillimeters();
// if (!grab1.timeoutOccurred()){
if ((g < 60)&&(g>1)&&(grabstate==0)&&(wriststate==0)) {
servoMinUpToMid(servo2);
servoMaxDownToMid(servo5);
servoMaxDownToMid(servo3);
servoMaxDownToMid(servo4);
delay(50);
servoMinUpToMid(servo1);
grabstate=1;
Serial.print(g);
if((g < 50)&&(g>1)&&(grabstate==0)&&(wriststate==1)){
servoMinUpToMax(servo1);
servoMinUpToMax(servo2);
servoMaxDownToMin(servo4);
servoMaxDownToMin(servo5);
delay(50);
servoMaxDownToMin(servo3);
grabstate=1;
p=pinch1.readRangeContinuousMillimeters();
Serial.print(p);
// if (!pinch1.timeoutOccurred()){
if ((p < 50)&&(p>1)&&(grabstate==0)) {
servoMinUpToMax2(servo2);
delay(50);
servoMinUpToMax2(servo1);
grabstate=1;
o=open1.readRangeContinuousMillimeters();
Serial.print(o);
// if (!open1.timeoutOccurred()){
if ((o < 40)&&(o>1)) {
delay(100);
delay(3000);
grabstate=0;
w=wrist1.readRangeContinuousMillimeters();
w3=wrist3.readRangeContinuousMillimeters();
Serial.print(w);
// if (!wrist1.timeoutOccurred()){
if (((w < 80)&&(w>1)&&(grabstate==0)&&(wriststate==0))||((w3 < 80)&&(w3>1)&&(grabstate==0)&&(wriststate==0))) {
servoMinUpToMax(servo0);
delay(3000);
wriststate=1;
if (wriststate==1){
w2=wrist2.readRangeContinuousMillimeters();
Serial.print(w2);
// if (!wrist2.timeoutOccurred()){
if ((w2 < 100)&&(w2>1)&&(grabstate==0)&&(wriststate==1)) {
wriststate=0;
else{
And here's my wiring diagram:
