Hi , i quiet a newbie ....... i have a problem which was the esp-01
i use arduino uno with chip atmega 328 p at controller upload the code
i have try thousands of way but still doesnt work , can anyone guide me or notice me some important things
The proverbial crystal ball is still in the dishwasher...
➜ Please do yourself a favor and read How to get the best out of this forum. Post accordingly, including code with code tags, necessary documentation for your request such as your exact circuit and power supply details, links to components, etc.
(we don't even know what your question or problem is)
Easiest way to do it is.
Upload an empty sketch onto the DUE (or blink or something else as long as pin 0 & 1 are not used and Serial is not used)
install the esp8266 core.
connect:
ESP-01 DUE
Vcc 3.3v
GND GND
GPIO 0 GND (at boot to set it to upload mode)
CH_PD 3.3v
TX TX
RX RX
For a DUE which is a 3.3v device there is no voltage divider required to reduce the logic levels, but for an UNO there is. and then use this: UNO-RX -> 1K -> ESP-01 RX -> 1k -> 1K -> GND
This will protect the ESP from the UNO 5v logic level that will damage the ESP-01 and reduce it to 3.3v
Do not use higher value resistors as they may influence the maximum transmission speed.
Make sure nothing is connected to GPIO 2 as well.
Try uploading something simple like 'blink' and define the ledpin as '1' which is the TX pin and has a blue led on it (active LOW)
This is using the USB to TTL converter of the DUE. With a board with multiple UARTs you can even upload using Serial Passthrough example but then you should cross-over (swap) the TX & RX lines between the boards and make sure that the baud rates (of both UARTs) match whatever you set as the upload speed in the IDE.
I don't own a DUE so i can not verify what i am sharing.
Uploading your own firmware will overwrite the AT firmware that was on the ESP-01, keep that in mind.
