hi I have 2 esp32, 2 lora ra02 and cameraa ov7670 I program a code but problem image received very blurry and detach help me to solve this problem
Seeing the code might help
I would agree, it could be an error in your code.
Code for Slave:
#include "OV7670.h"
#include <SPI.h>
#include <LoRa.h>
const int SIOD = 21; // SDA
const int SIOC = 22; // SCL
const int VSYNC = 34;
const int HREF = 35;
const int XCLK = 32;
const int PCLK = 33;
const int D0 = 27;
const int D1 = 17;
const int D2 = 16;
const int D3 = 15;
const int D4 = 25;
const int D5 = 13;
const int D6 = 12;
const int D7 = 26;
const int NSS = 18; // LoRa SS pin
const int RST = 14; // LoRa reset pin
const int DIO0 = 26; // LoRa IRQ pin
OV7670 *camera;
// Initialize Camera
camera = new OV7670(OV7670::Mode::QQVGA_RGB565, SIOD, SIOC, VSYNC, HREF, XCLK, PCLK, D0, D1, D2, D3, D4, D5, D6, D7);
// Initialize LoRa
SPI.begin(5, 19, 27, 18); // SCK, MISO, MOSI, SS
LoRa.setPins(NSS, RST, DIO0);
if (!LoRa.begin(433E6)) { // Set frequency to 433MHz
Serial.println("Starting LoRa failed!");
while (1);
Serial.println("LoRa initialized");
camera->oneFrame();
// Send image frame data via LoRa
int frameSize = camera->xres * camera->yres * 2;
int packetSize = 200; // Adjust the packet size if needed
for (int i = 0; i < frameSize; i += packetSize) {
LoRa.beginPacket();
LoRa.write(camera->frame + i, min(packetSize, frameSize - i));
LoRa.endPacket();
delay(10); // Small delay between packets
delay(1000); // Adjust delay as needed
Code for master:
#include <SPI.h>
#include <LoRa.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include "BMP.h"
#define ssid1 "amine"
#define password1 "0123456789"
WiFiServer server(80);
unsigned char bmpHeader[BMP::headerSize];
unsigned char frame[160 * 120 * 2]; // Buffer for QQVGA RGB565 image
int frameIndex = 0;
void serve()
WiFiClient client = server.available();
if (client)
String currentLine = "";
while (client.connected())
if (client.available())
char c = client.read();
if (c == '\n')
if (currentLine.length() == 0)
client.println("Content-type:text/html");
client.println();
client.print(
"body{margin: 0}\nimg{height: 40%; width: auto}"
client.println();
currentLine = "";
else if (c != '\r')
currentLine += c;
if(currentLine.endsWith("GET /camera"))
client.println("Content-type:image/bmp");
client.println();
client.write(bmpHeader, BMP::headerSize);
client.write(frame, sizeof(frame));
client.stop();
// Initialize WiFi
WiFi.begin(ssid1, password1);
Serial.println("Connecting Wifi...");
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.print("Stream Link: http://");
Serial.print(WiFi.localIP());
Serial.println("/camera");
BMP::construct16BitHeader(bmpHeader, 160, 120); // QQVGA resolution
server.begin();
// Initialize LoRa
while (1);
int packetSize = LoRa.parsePacket();
if (packetSize) {
while (LoRa.available()) {
frame[frameIndex++] = LoRa.read();
if (frameIndex >= sizeof(frame)) {
frameIndex = 0; // Reset index after receiving full frame
serve();
please read
and post your code accordingly.
Furthermore I suspect you should not transmit an image via LoRa as you might exceed limits for data transmission in this band.
A few comments;
First, if the image being received via LoRa is not correct, you need to be sure that the original image taked by the camera is good.
Second, there appears to be no error checking, you seem to be assuming that all packets that are part of the image (and there is quite a few) are all received completly error free. Appreciate that LoRa in itself cannot alter the image so that its 'blurry'.
Third, take with the duty cycle restrictions in your part of the World, you could be restricted to 10% or even 1%, which severly restricts the number of images per hour you can send.
Finally, 2.4Ghz LoRa is a far better choice for sending images, its a Worldwide band with no or few duty cycle issues.
