Hi
I have a problem in aploading code in esp32 and it show me time out error
I studied many webpage about this problem some page said that perss boot key when uploading and another page said use 10 micro fard capicator for solve this problem and anothers said use another usb cable and etc, but none which this solutions not perfom sucsessfully
I dont know how i can slove this errors
Any one know where is problem in esp32(wemos lolin32)
What's Your native language? I ask because unknown characters in the end of Your reply.
Make sure that the board is connected to the window You use. When disconnecting and connecting check the TOOL/port for board being present.
Sometimes I run several boards and several IDE windows and thinks don't work. However I can't remember I've got "time out".
I have a LOLIN D32.
It does not have a "boot" button, and I had these troubles in the past. I have even added a "boot" button myself. But today it is working normally.
Do you have Windows 10 or Windows 11, and updated it ?
Do you have the latest version of the Arduino IDE, and the updated "boards" and "libraries" ?
How do you add boot key?
My esp dont have boot key , it has just reset key.
I test on windows 7 ,8 and 10
What library?
I use last IDE.
I use esp32 board , i sucsessed two times upload code on it but after of it , permenetly show time out error
I'm using linux myself, but in Windows 11 then I use 1.8.16 from the *.exe or *.zip file (not the app from the Store).
Go to the "Board Manager", menu: Tools / Boards / Boards Manager
Select "Updateble" and update them.
Go to the "Libraries Manager", menu: Tools / Manage Libraries
I have forgotten how I used the extra "Boot" button. I think the "Boot" button can be a button between Pin 0 and GND. Release the button in time (but I don't know at what time).
I wrote a note somewhere that "40MHz" and "230400 baud" seems to work best.
Post a pic of your wiring and post your code. Using the wrong pins or commanding the wrong pins to operate at the wrong time can cause program load issues.
Such as putting a GPS Tx pin on GPIO_NUM_13 during program load or putting 5V onto GPIO_NUM_6.
