I have a project using about fifteen 144 neopixel strips (2160 neopixels). I understand the power concerns, and I should be fine, since I'm not ever turning on more than about 144 on at the same time. My problem is when using the Adafruit Neopixel Library example code, if I set a NUMPIXELS value of 595 or more, my code stops working. Any idea why that might be or what solution I can use? I've seen way longer runs of Neopixels, so it seems like it should be possible. I'm running the project off an UNO. I can post the code, but it's literally just the example code from the library.
Put your sketch between the code tags [code][/code]
Or if it is too big, attach the ino file.
I think the problem is that I'm exceeding the SRAM on the Uno. I can probably do it with a different board.
Each neopixel needs 3 bytes.
A Bobuino has 16k of SRAM vs 2k for UNO.
Also look at the Due and the Zero they have lost more SRAM. The Mega has 8K and the Teensey has even more.
If you need to handle over a 100 pixels on a uno, you need to encode the pixels with fewer bytes using a color palette.
I've written a library called FAB_LED (on github) that allows you to do that.
