Please help!
I have a Nano IoT 33 with two neopixel strips attached.
Strip A has 72 LEDs
Strip B has 21 LEDs
Strip B lights as expected, however, I am attempting to get strip A to light from both ends. Currently I only seem to be able to get the count up to work on strip A.
// Simple demonstration on using an input device to trigger changes on your
// NeoPixels. Wire a momentary push button to connect from ground to a
// digital IO pin. When the button is pressed it will change to a new pixel
// animation. Initial state has all pixels off -- press the button once to
// start the first animation. As written, the button does not interrupt an
// animation in-progress, it works only when idle.
#ifdef __AVR__
#include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
#include <WiFiNINA.h>
// Digital IO pin connected to the button. This will be driven with a
// pull-up resistor so the switch pulls the pin to ground momentarily.
// On a high -> low transition the button press logic will execute.
#define BUTTON_PIN 2
#define PIXEL_PIN_A 12 // Digital IO pin connected to the NeoPixels.
#define PIXEL_PIN_B 10 // Digital IO pin connected to the NeoPixels.
#define PIXEL_COUNT 72 // Number of NeoPixels
// Declare our NeoPixel strip object:
Adafruit_NeoPixel stripa(PIXEL_COUNT, PIXEL_PIN_A, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel stripb(PIXEL_COUNT, PIXEL_PIN_B, NEO_GRB + NEO_KHZ800);
// Argument 1 = Number of pixels in NeoPixel strip
// Argument 2 = Arduino pin number (most are valid)
// Argument 3 = Pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// NEO_RGBW Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
//please enter your sensitive data in the Secret tab
char ssid[] = "YellowAjah"; // your network SSID (name)
char pass[] = "xxx"; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS; // the Wi-Fi radio's status
boolean oldState = HIGH;
int mode = 0; // Currently-active animation mode, 0-9
int j = 0;
// attempt to connect to Wi-Fi network:
while (status != WL_CONNECTED) {
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
pinMode(BUTTON_PIN, INPUT_PULLUP);
stripa.begin(); // Initialize NeoPixel strip object (REQUIRED)
stripa.show(); // Initialize all pixels to 'off'
stripb.begin(); // Initialize NeoPixel strip object (REQUIRED)
stripb.show(); // Initialize all pixels to 'off'
// Get current button state.
boolean newState = digitalRead(BUTTON_PIN);
// Check if state changed from high to low (button press).
if((newState == LOW) && (oldState == HIGH)) {
// Short delay to debounce button.
delay(20);
// Check if button is still low after debounce.
if(newState == LOW) { // Yes, still low
if(++mode > 2) mode = 0; // Advance to next mode, wrap around after #2
switch(mode) { // Start the new animation...
case 0:
colorWipe(stripa.Color( 0, 0, 0), 50); // Black/off
colorWipe(stripb.Color( 0, 0, 0), 50); // Black/off
case 1:
colorWipe(stripa.Color(255,139,39), 50); // Dim
colorWipe(stripb.Color(255,139,39), 50); // Dim
case 2:
colorWipe(stripa.Color( 255, 255, 255), 50); // Bright
colorWipe(stripb.Color( 255, 255, 255), 50); // Bright
// Set the last-read button state to the old state.
oldState = newState;
// Fill strip pixels one after another with a color. Strip is NOT cleared
// first; anything there will be covered pixel by pixel. Pass in color
// (as a single 'packed' 32-bit value, which you can get by calling
// strip.Color(red, green, blue) as shown in the loop() function above),
// and a delay time (in milliseconds) between pixels.
void colorWipe(uint32_t color, int wait) {
for(int i=0; i<stripa.numPixels(); i++) { // For each pixel in strip...
stripa.setPixelColor(i, color); // Set pixel's color (in RAM)
stripa.setPixelColor((72 - i), color); // Set pixel's color (in RAM)
stripa.show(); // Update strip to match
if(i < 22) {
stripb.setPixelColor(i, color); // Set pixel's color (in RAM)
stripb.show(); // Update strip to match
delay(wait); // Pause for a moment
Can anyone give me some pointers on where I am going wrong, please?
Thanks,
GlennCannon
