Problem mit SD-Kartenleser am Adruino Leonardo
Hallo ich komme mit meinen Adruino Lenoardo nicht weiter.
Problem:
Er erkennt den SD-Kartenleser einfach nicht ich haben ihnen an verschieden Leonardos getestet immer mit dem ergebnis Erkennungs Fehler
Nun habe ich in meiner verzweiflung ihn an einen Uno Angeschlossen gleicher Skech und Siehe da er Läuft wie ein Uhrwerk
Ich also Pin für pin zurück an den Leonarde und wieder Fehler
Als Skech verwenden Ich:
 SD card read/write
 This example shows how to read and write data to and from an SD card file
 The circuit:
  SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
 created   Nov 2010
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
File myFile;
 while (!Serial) {
   ; // wait for serial port to connect. Needed for native USB port only
 Serial.print("Initializing SD card...");
 if (!SD.begin(4)) {
   Serial.println("initialization failed!");
   while (1);
 Serial.println("initialization done.");
 // open the file. note that only one file can be open at a time,
 // so you have to close this one before opening another.
 myFile = SD.open("test.txt", FILE_WRITE);
 // if the file opened okay, write to it:
 if (myFile) {
   Serial.print("Writing to test.txt...");
   myFile.println("testing 1, 2, 3.");
   // close the file:
   myFile.close();
   Serial.println("done.");
   // if the file didn't open, print an error:
   Serial.println("error opening test.txt");
 // re-open the file for reading:
 myFile = SD.open("test.txt");
 if (myFile) {
   Serial.println("test.txt:");
   // read from the file until there's nothing else in it:
   while (myFile.available()) {
     Serial.write(myFile.read());
   // close the file:
   myFile.close();
 // nothing happens after setup
Meine Leonardo:
https://www.amazon.de/dp/B07MY2VZX9?psc=1&ref=ppx_yo2ov_dt_b_product_details
Mein Uno:
https://www.amazon.de/dp/B0B8TYB8ZL?psc=1&ref=ppx_yo2ov_dt_b_product_details
mein SD-Kartenleser:
https://www.amazon.de/dp/B06X1DX5WS?ref=ppx_yo2ov_dt_b_product_details&th=1
und
https://www.amazon.de/dp/B0B455V96L?psc=1&ref=ppx_yo2ov_dt_b_product_details
Das trifft auf den Leonardo nicht zu!
Hallo danke für den Hinweis nach dem ich mehrer Pinout Bilder durch forstet habe
stellte ich fest das Mosi, Miso, CLK auf dern ICSP Schnittstelle sind
Siehe Bild
Danke jetzt bin ich wesentlich weiter Problem ist gelöst
