Hello!
This is my first time posting so I'm not sure how this works, but I've been working on reading the registers for the L3GD20H gyroscope in SPI. I need to make sure my readRegister function is working in order to read the registers of my gyroscope. So, the issue is that the readRegister function is returning 5 bits instead of 8. When I go to read the WHOAMI register it returns 11010 and instead should return 1101 0111 as per page 36 of the datasheet
l3gd20h.pdf (2.4 MB)
Here's my code,
#include <SPI.h>
const int WHOAMI = 0xD7;
const int CTRL1 = 0x20;
const int OUT_X_L = 0x28;
const int OUT_X_H = 0x29;
const int OUT_Y_L = 0x2A;
const int OUT_Y_H = 0x2B;
const int OUT_Z_L = 0x2C;
const int OUT_Z_H = 0x2D;
const int STATUS = 0x27;
const int LOW_ODR = 0x39;
// readData = 0x80;
// writeData = 0x00;
long gx[16], gy[16], gz[16]; // 16 bit
unsigned long timeLimit = 60000; // 60s
const int GYRO_CS = 10; // labeled CS
const int GYRO_MISO = 12; // labeled SA0
const int GYRO_MOSI = 11; // labeled SDA
const int GYRO_CLK = 13; // labeled SCL
Serial.begin(9600); // setting the baud rate
SPI.begin();
pinMode(GYRO_CS, OUTPUT);
digitalWrite(GYRO_CS, HIGH);
Serial.println(readRegister(WHOAMI)); // prints 11010, should return 1101 0111
// writeRegister(CTRL1, 0x0F); // enables normal mode and x,y,z axis
byte readRegister(byte address) {
byte inByte = 0;
SPI.beginTransaction(SPISettings(10000000, MSBFIRST, SPI_MODE0));
digitalWrite(GYRO_CS, LOW);
SPI.transfer(address | 0x80); // 1101 0111 | 1000 0000 = 1101 0111
inByte = SPI.transfer(0x00);
SPI.endTransaction();
return inByte;
void writeRegister(int8_t thisRegister, int8_t val){
SPI.transfer(thisRegister << 1);
SPI.transfer(val);
Any help would be much appreciated! I've been staring at this for a while and I need a different set of eyes.
