Hi. Started my new project on Arduino Nano and Nextion screen. Later i decided to go wireless, and fun begins. Earlier i had projects done with Nextion and Wemos D1 mini. And still have some running at home. But this time it is not working. I can transmit values from Wemos to Nextion, but cannot read them. I have tried different pins, few boards, jumper wires. I can see data coming back on the osciloscope, but cannot get them into Wemos. I can also read serial output sent from Arduino Nano, and Nano can read Nextion. Just in case tried with two different Nextion screens as well. My last hope is, i had recently updated boards, maybe that is a problem, but othervise i am out of idea, how to solve this.
Maybe someone can try Wemos and Nextion with the latest esp8266 boards update pls? Any advice much appreciated.
I am using this library: bborncr/nextion
My test code is:
Support for Nextion on these fora is pretty much as follows:
You can follow the methods I set out in using Nextion displays with Arduino. My methods do not use the Nextion libraries, so I can offer help on using my methods but I cannot offer anything very helpful for any Nextion library.
The original Nextion libraries are full of bugs. There is a link from my tutorial to to some improved Nextion libraries created by Ray Livingston, I suggest those might be worth trying if you prefer to use a library.
Just a thought,
Have you tried writing some simple code to take data from the serial Rx connected to the Nextion Tx and mirroring it to the serial monitor? This would be a test to see if the data is even getting to the D1 mini.
Personally I would not bother with software serial. I have a D1 mini but have not used it yet. I think this is the one that uses the ESP8266, it that correct? You can use:
Got a little bit further with my current setup. Now i am sure, that is one of library faults. don`t know which, but managed to get output on serial monitor:
First two lines are button object ID, another two are representation of my numeric value.
I`ve been using bborncr/nextion library for few years now, as it was so easy to use. Seems like its time has gone now.....
My programing skills are poor, so i rely on debug monitor a lot.
Thank you for your kind reply, i had a look at your tutorials, it looks as complex as Mars rover comparing to my old "Lego" way of doing it. Will need good few days to break into it.
