I am having strange problems with my Arduino Yun. I can only upload small sketches (like the Blink example). If I upload anything much larger I get errors like this:
Global variables use 506 bytes (19%) of dynamic memory, leaving 2,054 bytes for local variables. Maximum is 2,560 bytes.
Found programmer: Id = "1111111"; type = 1
Software Version = 1.1; Hardware Version = 1.1
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
processing.app.debug.RunnerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:125)
at processing.app.Sketch.upload(Sketch.java:1719)
at processing.app.Sketch.exportApplet(Sketch.java:1625)
at processing.app.Sketch.exportApplet(Sketch.java:1597)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2397)
at java.lang.Thread.run(Thread.java:695)
Caused by: processing.app.debug.RunnerException: Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:111)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:123)
... 5 more
I am connected to the Yun from Mac OSX 10.9, Arduino 1.5.6 rc2 over USB. I have tried restarting the Yun (many times) and my Macbook. Nothing works.
I think the problem is serial. I have discovered I can only get smaller sketches to upload using the /dev/cu* device, not the /dev/tty.usbmodem* device. Uploading over the network to the Yun also does not work (I am asked for a password, but the actual uploading hangs). I also cannot connect to the Serial Moniter over the network and locally (USB) it does not show me any output.
I fear I have somehow kill my Yun
Edit: I have upgraded to Arduino 1.5.7 but it has not fixed anything.
Bizarrely it now seems to be working, at least with local USB. I feel like an idiot. I am very sure it was not working. i have spent a couple of hours today trying to figure it out.
My only problem now is try the Serial Monitor over the network.
All I get is:
Unable to connect: retrying (1)...
Unable to connect: retrying (2)...
Unable to connect: retrying (3)...
Unable to connect: retrying (4)...
Unable to connect: is the sketch using the bridge?
It defaults to 300 baud, I try changing it but it hangs.
I know I am probably sounding incompetent, seeing as how it sometimes works. Here is a video showing you exactly what happens. I have both the Arduino IDE and the Yun in the same shot. You can see how when I click upload, after compiling, the RX LED flashes a few times and then nothing. It just hangs there for minutes.
Edit: I did not realize how large the video was. Here is a lower res version:
