My UNO R3 doesn't work even though it worked yesterday, and i haven't done anything to it. The Yellow LED is constantly lit up and i can't upload sketches to the UNO R3?
The COM port is of course working perfectly, i have checked that in Terminal.
The error message says:
avrdude: ser_open(): can´t open device "\.\com3": a device attached to the system is not functioning
Sometimes, the same USB port doesn't recognize the non-original board. I have some ones of those. My solution, when this happen is: rebooting the computer and then change the port. Then tray to upload the simplest program I have, usually does it function to me.
Hi guys!
I've had same problem with a non original Uno3, but the board was perfectly recognized on /dev/ttyACM0 ... but doesn't upload any sketch due to privileges problems.
Solution: "sudo chmod 777 /dev/ttyACM0" .... insist maybe, one more time!!!
guys my code is not getting uploaded.i'm using the unor3, i have selected the correctboard even port also in settings.still it is getting strucked at 'uploading'
My board is clone board, So many clone boards from Asia not support driver from Arduino.cc IDE
Because of different specs
This solution worked for the ERROR **"avrdude: ser_open device \.\COM1 **
You can try it for different #upload errors
1] So at first download the IDE From arduino.org. While installing it ask for the Atmel drivers to install
Install all the drivers and software it ask for
2] You have to set COM port for arduino to COM1
For that go to Control Panel>Hardware and sound>Device Manager>
** Find arduino uno port in Ports (COM and LPT)**
** Or in Unspecified ports**
Right Click on Arduino uno port go to properties>port setting >advanced>change COM port Number to COM1
3] After that we have to try different Drivers in IDE to find the working one.
Driver that worked for me, Work in most cases
4] To change the driver
Go to control panel>Hardware and Sound>Device Manager>Find Arduino port>right click on it>select
Update driver software>select browse my computer for driver software>select let me pick from my list*
of drivers on my computer> uncheck show compatible hardware*
5] Then you have to check compatible hardware from the list
In my case the drivers worked for the ERROR "avrdude: ser_open device \.\COM1”
is Atmel Corp>EDBG Virtual COM port
double click to select driver . Don’t worry if it shows Update driver warning
Atmel Corp>EDBG Virtual COM port drivers worked for most of the clone Adriano Uno
Hello , I"m a newer in arduino and I tried to make the first test on it Using the basic exemple blink, first of all I check if I was using the right borad < in case uno< and for sure the port, in my case com1.I did the compile and it looks good ,but when I traied to upload ,take a look the trouble....
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x5c
trouble to upload contact http://www.arduino.cc/en/Guide/Troubleshooting
Sketch uses 2242 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 210 bytes (10%) of dynamic memory, leaving 1838 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x20
An error occurred while uploading the sketch
option enabled in File -> Preferences.
Hello, Welcome to the Arduino Forum. This guide explains how to get the best out of this forum. Please read and follow the instructions below. Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is frustrating for you and frustrating for us. The people who try to help with your pro…
It will help you get the very best out of the forum in the future.
Your OS and version can be valuable information, please include it along with extra security you are using. Antivirus etc.
Always list the version of the IDE you are using and the board version if applicable.
Use quote or add error messages as an attachment NOT a picture.
this error appear to me when i upload a program on the arduino so please help me to solve it !!
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x62
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
