Problem using wavefront algorithm with Arduino Robot.
Hello,
I am using the wavefront algorithm to go from a set location to a specified goal. (I am not using the servo motor and IR senor that I said before). I am using a specified array that has a point set for the robot, for the goal and for the walls. When I upload the code the Arduino robot doesn't follow the shortest path and doesn't even reach the goal. I think I the problem lies within the wavefront algorithm I implemented. I have the code below (It's quite long). Any help will be greatly appreciated.
// include the robot library
#include <ArduinoRobot.h>
// Constants
const int GridSize   = 10;
// Global variables
//int NoSteps=0;
int old_state=1;//records current pointed direction of robot: 1 is up, 2 is right, 3 is down, and 4 is left (clockwise)
int new_state=1;//required direction of robot
//X is vertical, Y is horizontal
int Map[GridSize][GridSize] =
 {{0,0,0,0,0,0,0,0,0,0},
  {0,255,254,255,0,0,0,0,0,0},
  {0,255,255,255,0,0,0,0,0,0},
  {0,0,1,0,0,0,0,0,0,0},
  {0,0,0,0,0,0,0,0,0,0}};
  // Wave Front Variables
const int nothing=0;
const int wall=255;
const int goal=1;
const int robot=254;
//starting robot/goal locations
int robot_x=3;
int robot_y=2;
int goal_y=8;
int goal_x=3;
//Map locations
int x=0;
int y=0;
//temp variables
int counter=0;
//when searching for a node with a lower value
int minimum_node=250;
int min_node_location=0;
int reset_min=250;//anything above this number is a special item, ie a wall or robot
// Global variables
  Robot.begin();
  //pinMode(ServoPin,OUTPUT);
  //for (int H=0; H<GridSize;H++)
   // for (int W=0; W<GridSize;W++)
    //  Map[H][W]=0;
  //reset encoder function
  //store robot location in Map
  Map[robot_x][robot_y]=robot;
  Map[goal_x][goal_y]=goal;
  // Drive around until a button or unsafe condition is detected
  while( Map[robot_x][robot_y]!=goal)//program ends when robot reaches goal
    new_state=propagate_wavefront();
    //////////////wavefront code//////////////
    while(new_state!=old_state && new_state!=0)
      //if not pointed in the right direction, rotate
      if (abs(old_state - new_state) == 2)//rotate 180 degrees
        rotate_CCW();
        rotate_CW();
      else if ((signed int)(old_state - new_state) == -1 || (signed int)(old_state - new_state) == 3)//rotate 90 degrees CW
        rotate_CW();
      else if ((signed int)(old_state - new_state) == 1 || (signed int)(old_state - new_state) == -3)//rotate 90 degrees CCW
        rotate_CCW();
      //make new state the old state
      old_state=new_state;
      //recheck with new location
      //find new location to go to
    //there is no solution
    if (new_state==0)
    //go to new location
    else//move if there is a solution, otherwise dont move forward
      Map[robot_x][robot_y]=256;
      if (new_state==1)
        robot_x--;
      if (new_state==2)
        robot_y++;
      if (new_state==3)
        robot_x++;
      if (new_state==4)
        robot_y--;
      straight();//distance, velocity
      //update new location of robot
    if(new_state!=0)
    if (robot_x==goal_x &&robot_y==goal_y)
      goal_x=3;
      unpropagate();
//rotate 90
void rotate_CCW()
  Robot.motorsStop(); // stop the motors
  delay(500); // wait for a moment
  Robot.turn(-90); // turn to the left and try again
//rotate -90
void rotate_CW()
  Robot.turn(-90); // turn to the right and try again
//drive straight function
void straight()
  // move forward for one second
  Robot.motorsWrite(150,150);
  Robot.motorsWrite(0,0); // stop moving
int propagate_wavefront()
  //clear old wavefront
  unpropagate();
  counter=0;//reset the counter for each run!
  while(counter<200)//allows for recycling until robot is found
    x=0;
    y=0;
    while(x<GridSize && y<GridSize)//while the Map hasnt been fully scanned
      //if this location is a wall or the goal, just ignore it
      if (Map[x][y] != wall && Map[x][y] != goal)
        //a full trail to the robot has been located, finished!
        if (min_surrounding_node_value(x, y) < reset_min && Map[x][y]==robot)
          //finshed! tell robot to start moving down path
          return min_node_location;
        //record a value in to this node
        else if (minimum_node!=reset_min)//if this isnt here, 'nothing' will go in the location
            Map[x][y]=minimum_node+1;
      //go to next node and/or row
      y++;
      if (y==GridSize && x!=GridSize)
        x++;
        y=0;
    counter++;
  return 0;
void unpropagate()//clears old path to determine new path
  //stay within boundary
  for(x=0; x<GridSize; x++)
    for(y=0; y<GridSize; y++)
      if (Map[x][y] != wall && Map[x][y] != goal && Map[x][y] != 256) //if this location is something, just ignore it
        Map[x][y] = nothing;//clear that space
//this function looks at a node and returns the lowest value around that node
//1 is up, 2 is right, 3 is down, and 4 is left (clockwise)
int min_surrounding_node_value(int x, int y)
  minimum_node=reset_min;//reset minimum
  //down
  if(x <(GridSize-1))//not out of boundary
    if  (Map[x+1][y] < minimum_node && Map[x+1][y] != nothing)//find the lowest number node, and exclude empty nodes (0's)
      minimum_node = Map[x+1][y];
      min_node_location=3;
  //up
  if(x > 0)
    if  (Map[x-1][y] < minimum_node && Map[x-1][y] != nothing)
      minimum_node = Map[x-1][y];
      min_node_location=1;
  //right
  if(y < (GridSize-1))
    if  (Map[x][y+1] < minimum_node && Map[x][y+1] != nothing)
      minimum_node = Map[x][y+1];
      min_node_location=2;
  //left
  if(y > 0)
    if  (Map[x][y-1] < minimum_node && Map[x][y-1] != nothing)
      minimum_node = Map[x][y-1];
      min_node_location=4;
  return minimum_node;
