HI GUYS, I have problem with speedometer and I looked many tutorials but most of them missed my problem. When I use below code in Arduino and bring sensor to near magnet speed is change which is good however if I away magnet from sensor, speed stays higher value which is not correct(it has to go 0 value) now I think that something wrong with this tutorials. any help will save my day
this example from https://www.instructables.com/id/Arduino-Bike-Speedometer/
// pin connected to reed switch
#define reed 11
int reedVal;
int maxDebounceTicks = 100;
int currentDebounceTicks;
int time = 0;
// the wheel radius, in kilometers
float radius = 0.0003556;
float circumference;
float velocity = 0.00;
float distance = 0.00;
// initialize LCD with the numbers of the interface pins
// set up the LCD's number of columns and rows
currentDebounceTicks = maxDebounceTicks;
circumference = 2 * 3.14 * radius;
pinMode(reed, INPUT);
cli();
// set entire TCCR1A register to 0
TCCR1A = 0;
// set entire TCCR1B register to 0
TCCR1B = 0;
// initialize counter value to 0;
TCNT1 = 0;
// set timer count for 1khz increments
// = (16*10^6) / (1000*8) - 1
OCR1A = 1999;
// turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS11 bit for 8 prescaler
TCCR1B |= (1 << CS11);
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE1A);
sei();
displayText();
delay(100);
ISR(TIMER1_COMPA_vect) {
reedVal = digitalRead(reed);
if (reedVal) {
// wait the given number of ticks, before calculating the velocity
if (currentDebounceTicks == 0) {
// circumference in kilometers, time in hours
velocity = circumference/((float)time/3600000);
time = 0;
distance = distance + circumference;
if (currentDebounceTicks > 0) {
currentDebounceTicks -= 1;
if (time > 2000) {
// set velocity to 0 when tire is still for 2 seconds
velocity = 0;
time += 1;
void displayText(){
// Serial.println(int(velocity));
// Serial.println(" km/h");
// if (distance > 1) {
// Serial.println(distance);
// Serial.println(" km");
// else {
// Serial.println(int(distance * 1000));
// Serial.println(" m");
Serial.println(velocity);
