Background:
I'm in the process of designing a dashboard a early model vehicle. The Arduino Nano is used to interpret the signals my computer does not process (turn signals, CEL, etc). One of the things i'm attempting to get working is reading the speed sensor that's in the car from the factory. It's a reed switch, 9 teeth on the ring gear for each revolution. I using an ISR to pickup each time the reed switch is activated. The Arduino is sending all this information to an application via can frames.
Problem:
Right now my code does work, but the problem comes at higher speeds, my speed output is way too noisy - it'll jump several MPH while cruising at a fixed speed. Debouncing with a time based code would usually work here, but the high speed limits how long I can run a debounce wait. For instance, if i were to run a time based debounce of 10 ms, my highest speed i can read from the reed switch is 43MPH. Does anyone have any suggestions on how to "smooth" the speed value effectively?
/// Define global variables
unsigned long Time;
byte LastBroadcast;
// Define global variables for Pins; r stands for read; bool is true or false (on/off in our case)
bool LBLr; // Left Blinker from Digital in on Arduino
bool RBLr; // Right Blinker from Digital in on Arduino
bool HBr; // High Beams from Digital in on Arduino
bool MALFr; // Check Engine Light from Digital in on Arduino
bool ParkBkr; // Park Brake From Digital in
bool LowFuelr; //Low Fuel from Digital in
bool BrkRearr; //Brake Lining Rear from Digital in
bool Fogr; //Fog Light from Digital in
bool BrkFrontr; // Brake Lining Front from Digtial in
bool RunLghtsr; //Running Lights from Digital in
bool AltFailr; //Alternator Fail from Digital in
bool BrakeFldr; //Brake Fluid Low from Digital in
bool OilPressr; //Oil Pressure Low from Analog
// Assign numbers/Pins to variables
int ParkBkPin = 2; // Parking Brake on Pin D2
int LBLPin = 4; //Left Blinker on Pin D4
int HBPin = 5; // High Beams on Pin D5
int RBLPin = 6; // Right Blinker on Pin D6
int BrkRearPin = 7; // Brake Lining Rear on D7
int FogPin = 8; // Fog lights on D8
int BrkFrontPin = 9; // Brake Lining Front D9
int MALFPin = 10; // Check Engine (MALF) on Pin D10
int RunLghtsPin = 11; // Running Lights on pin D11
int AltFailPin = 12; // Alternator Fail on D12
int BrakeFldPin = 13; // Brake Fluid Low on D13
int OilPressPin = A0; // Low Oil Pressure on A0
int LowFuelPin = A2; // Low Fuel on Pin A2
int FuelLevelPin = A6; //Fuel level sensor on pin A6
int TempPin = A7; // Temp Sensor on pin A7
int FuelLevel; //define this as an integer
int TempVal;
//all of this is for speed calc
int ReedSwitch = 3; //Declaring pin for reed switch to be used for Speed Calculation. Digital Pin 2 or 3 must be used for the reed switch on the Nano
float start, finished;
float elapsed, time;
const int circumference = 1.9812; //circumference of tire in meters
float circMetric=(circumference);
float circImperial; // using 1 kilometer = 0.621371192 miles
volatile byte Speed; // Keeping this as byte so it's smaller and transmitts every interrupt (not sure if required)
volatile byte Speed1;
volatile unsigned long count = 0;
volatile unsigned long shortcount = 0;
//Fuel
const int numReadings = 250; //Size of array, larger the number the larger the array and the smoother the average value.
int readIndex = 0;
int readings[numReadings];
int total = 0;
int average = 0;
delay (3000); //3s startup delay
//Speed Calc Stuff
start= millis();
circImperial=circMetric*.62137; // convert metric to imperial for MPH calculations
Serial.begin(9600); //enable serial connection. Needs to be 9600 for bluetooth.
// Serial.begin(115200); // 115200 for direct connection to comptuer
pinMode(LBLPin, INPUT_PULLUP); // Left Blinker will activate with ground to pin
pinMode(RBLPin, INPUT_PULLUP); // Right Blinker will activate with ground to pin
pinMode(HBPin, INPUT_PULLUP); // High Beams will activate with ground to pin
pinMode(MALFPin, INPUT_PULLUP); // Check engine light will activate when pin is grounded
pinMode(ParkBkPin, INPUT_PULLUP); // Park Brake will activate when pin is grounded
pinMode(LowFuelPin, INPUT_PULLUP); // Low Fuel will activate when pin is grounded
pinMode(BrkRearPin, INPUT_PULLUP); // Activate when pin is grounded
pinMode(FogPin, INPUT_PULLUP); // Activate on ground to pin
pinMode(BrkFrontPin, INPUT_PULLUP); // Activate when pin is grounded
pinMode(RunLghtsPin, INPUT_PULLUP); // Activate on ground to pin
pinMode(AltFailPin, INPUT_PULLUP); // Activate when pin is grounded
pinMode(BrakeFldPin, INPUT_PULLUP); // Activate when pin is grounded
pinMode(OilPressPin, INPUT_PULLUP); // Activate when pin is grounded
attachInterrupt(digitalPinToInterrupt(ReedSwitch), CalculateSpeed, FALLING); //Reedswitch(D3) is detecting a change in voltage(FALLING) and running CalculateSpeed() at each interrupt. Inputpullup not needed before here based on the way I wired it (i think)
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0; }
void CalculateSpeed() //ISR for interrupt. (Run this each time the interrupt is called.)
if((millis()-start)>10) // for debounce. 20ms = 23MPH Max; 10ms = 43MPH Max
//calculate elapsed
elapsed=millis()-start;
//reset start
start=millis();
//calculate speed in mph
Speed1=(3600*circImperial/4)/elapsed; //This comes out somewhat close to actual MPH. Value needs to be changed in Realdash via gague math compared to a known speed.
if (Speed1 >= 2){
Speed = Speed1; // No changes if Speed is higher than 2 MPH
if (Speed1 <= 2){
Speed = 0; // If speed is less than 2 MPH, Speed = 0. This is so speed doesn't show greater than 0 MPH when stopped
void loop() //Main functions that run continuously
Time = millis();
// Go read the ardiuno Pins
ReadIOPins();
//Run the Calculate Fuel Level code
CalculateFuelLevel();
//Check Temperature
Temperature();
// Send Data to CanBus every 10 milliseconds: 23 ms orginally, not sure if 10ms is required for anything. Speed calc maybe?
if (Time - LastBroadcast > 20)
LastBroadcast = millis();
BuildCanFrames();
void ReadIOPins() // Reads current status of each pin; r stands for read
LBLr = !digitalRead(LBLPin);
RBLr = !digitalRead(RBLPin);
HBr = !digitalRead(HBPin);
MALFr = !digitalRead(MALFPin);
ParkBkr = !digitalRead(ParkBkPin);
LowFuelr = !digitalRead(LowFuelPin);
BrkRearr = !digitalRead(BrkRearPin);
Fogr = !digitalRead(FogPin);
BrkFrontr = !digitalRead(BrkFrontPin);
RunLghtsr = !digitalRead(RunLghtsPin);
AltFailr = !digitalRead(AltFailPin);
BrakeFldr = !digitalRead(BrakeFldPin);
OilPressr = !analogRead(OilPressPin);
void CalculateFuelLevel() //Math to calculate fuel level.
//int tankvalue; //define integer to be used below
total = total - readings[readIndex];
readings[readIndex] = analogRead(FuelLevelPin);
total = total + readings[readIndex];
readIndex = readIndex + 1;
if (readIndex >= numReadings) {
readIndex = 0;
FuelLevel = total/numReadings;
// tankvalue = analogRead(FuelLevelPin); //read the signal coming from the sender
// FuelLevel = map(tankvalue, 80, 10, 0, 100); //convert that number to percentage. My values: 80 = empty(0); 10 = full(100)
if (FuelLevel < 0)
{ // Apply rule if tank is reading less than empty, Prevents negative values.
FuelLevel = 0;
if (FuelLevel > 100) // Apply rule if tank is reading more than full, Prevents values greater than 100.
FuelLevel = 100;
void Temperature()
TempVal = analogRead(TempPin); //Read the temperature pin (A7)
float mv = (TempVal/1024.0)*5000; //Scale value
float celcius = mv/10; //Convert to C
float Temperature = (celcius*9)/5 + 32; //Convert to F
void BuildCanFrames()
byte CanBuffer[8];
// build & send CAN frames to RealDash.
// a CAN frame payload is always 8 bytes (0-7) containing data in a manner.
// described by the RealDash custom channel description XML file
// all multibyte values are handled as little endian by default.
// endianess of the values can be specified in XML file if it is required to use big endian values
// build 1st CAN frame: //This is what is transmitted to Realdash
CanBuffer[0] = HBr;
CanBuffer[1] = MALFr;
CanBuffer[2] = LBLr;
CanBuffer[3] = RBLr;
CanBuffer[4] = ParkBkr;
CanBuffer[5] = LowFuelr;
CanBuffer[6] = BrkRearr;
CanBuffer[7] = Fogr;
// write first CAN frame to serial:
SendCANFrameToSerial(3200, CanBuffer); //1st CAN frame id is 3200
// build 2nd CAN frame:
CanBuffer[0] = BrkFrontr;
CanBuffer[1] = RunLghtsr;
CanBuffer[2] = AltFailr;
CanBuffer[3] = BrakeFldr;
CanBuffer[4] = OilPressr;
CanBuffer[5] = FuelLevel;
CanBuffer[6] = Speed;
CanBuffer[7] = Temperature;
// write second CAN frame to serial:
SendCANFrameToSerial(3201, CanBuffer); //2nd CAN frame id is 3201, 3rd would be 3202, etc.
// I don't understand anything after this but it works
void SendCANFrameToSerial(unsigned long canFrameId, const byte* frameData)
// the 4 byte identifier at the beginning of each CAN frame
// this is required for RealDash to 'catch-up' on ongoing stream of CAN frames
const byte serialBlockTag[4] = { 0x44, 0x33, 0x22, 0x11 };
Serial.write(serialBlockTag, 4);
// the CAN frame id number (as 32bit little endian value)
Serial.write((const byte*)&canFrameId, 4);
// CAN frame payload
Serial.write(frameData, 8);
