Problem with code for Arduino using an RTC
I am working on a code to create a moving clock system. I have an RTC1302 to keep the time and the plan is to use that time keeping system to move servo motors at designated times.
I don't have much experience with Arduino code yet, but attached is what I currently have
sketch_feb24a.ino (5.0 KB)
The top section of the code is the virtuabotixRTC program which did not show up in the possible library downloads so I just found it online. If anyone has any help regarding how to fix these errors I will be very grateful.
Error messages -
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
C:\Users\agkos\AppData\Local\Temp\ccNz4bDJ.ltrans0.ltrans.o: In function `global constructors keyed to 65535_0_sketch_feb24a.ino.cpp.o.1901':
:(.text.startup+0x8e): undefined reference to `virtuabotixRTC::virtuabotixRTC(unsigned char, unsigned char, unsigned char)'
C:\Users\agkos\AppData\Local\Temp\ccNz4bDJ.ltrans0.ltrans.o: In function `setup':
C:\Users\agkos\OneDrive\Documents\Arduino\sketch_feb24a/sketch_feb24a.ino:64: undefined reference to `virtuabotixRTC::setDS1302Time(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, int)'
C:\Users\agkos\AppData\Local\Temp\ccNz4bDJ.ltrans0.ltrans.o: In function `loop':
C:\Users\agkos\OneDrive\Documents\Arduino\sketch_feb24a/sketch_feb24a.ino:68: undefined reference to `virtuabotixRTC::updateTime()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Uno.
option enabled in File -> Preferences.
Please, in the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
Use the </> icon from the ‘reply menu’ to attach the copied sketch.
if you follow instruction on youtube then follow it to the end.
#include <virtuabotixRTC.h>
// Creation of the Real Time Clock Object
virtuabotixRTC myRTC(6, 7, 8);
void setup()  {
  // Set the current date, and time in the following format:
  // seconds, minutes, hours, day of the week, day of the month, month, year
  myRTC.setDS1302Time(18, 10, 10, 7, 18, 9, 2020);
void loop()  {
  // This allows for the update of variables for time or accessing the individual elements.
  myRTC.updateTime();
  // Start printing elements as individuals
  Serial.print("Current Date / Time: ");
  Serial.print(myRTC.dayofmonth);
  Serial.print("/");
  Serial.print(myRTC.month);
  Serial.print("/");
  Serial.print(myRTC.year);
  Serial.print("  ");
  Serial.print(myRTC.hours);
  Serial.print(":");
  Serial.print(myRTC.minutes);
  Serial.print(":");
  Serial.println(myRTC.seconds);
  // Delay so the program doesn't print non-stop
It looks like you may have a .h installed for the library, but no source.
Hard to tell.
#include <RtcDS1302.h>
//virtuabotixRTC code starts here
#include "stdio.h"
#ifndef virtuabotixRTC_H        //|
#define virtuabotixRTC_H        //|
#include <stddef.h>        //|
#include <string.h>        //|
#if defined(ARDUINO) && ARDUINO >= 100        //|
#include "Arduino.h"        //|
#else        //|
#include "WProgram.h"        //|
#include <pins_arduino.h>        //|
#endif
#define DS1302_ENABLE            0x8E        //|
#define DS1302_TRICKLE           0x90
class virtuabotixRTC  {        //|
  public:
    virtuabotixRTC(uint8_t inSCLK, uint8_t inIO, uint8_t inC_E);
    void initRTC(uint8_t CLK, uint8_t IO, uint8_t ENABLE);     // Sets the pins and enable them          //|
    void DS1302_clock_burst_read( uint8_t *p);                 // Reads clock data, and sets pinmode     //|
    void DS1302_clock_burst_write( uint8_t *p);                // Writes clcok data, and sets pinmode    //|
    uint8_t DS1302_read(int address);                          // Reads a byte from DS1302, sets pinmode //|
    void DS1302_write( int address, uint8_t data);             // Writes a byte to DS1302, sets pinmode  //|
    void _DS1302_start( void);                                 // Function to help setup start condition //|
    void _DS1302_stop(void);                                   // Function to help stop the communication//|
    uint8_t _DS1302_toggleread( void);                         // Function to help read byte with bit    //|
    void _DS1302_togglewrite( uint8_t data, uint8_t release);  // Function to help wrtie byte with bit   //|
    void setDS1302Time(uint8_t seconds, uint8_t minutes,       // This function sets the time on the     //|
                       uint8_t hours, uint8_t dayofweek,       // DS1302                                 //|
                       uint8_t dayofmonth, uint8_t month,                                                //|
                       int year);        //|
    void updateTime();                                         // This function simply updates the time  //|
    uint8_t SCLK;        //|
    uint8_t IO;        //|
    uint8_t C_E;        //|
    uint8_t seconds;        //|
    uint8_t minutes;        //|
    uint8_t hours;        //|
    uint8_t dayofweek;        //|
    uint8_t dayofmonth;        //|
    uint8_t month;        //|
    int year;        //|
#endif
//end of virtuaboticRTC code
virtuabotixRTC myRTC(6, 7, 8); //set pins of RTC to CLK 6, IO 7, CE 8
#include <Servo.h>
Servo servo1; //define test servo
  servo1.attach(3); //attach servo to pin 3
  myRTC.setDS1302Time(00, 28, 21, 4, 24, 2, 2022); //set the current time
  myRTC.updateTime();
  Serial.print(":");
  Serial.print(myRTC.seconds); //prints the minutes and seconds on serial monitor for checks
  delay(5000);
  if ((myRTC.seconds) == 10);
  servo1.write(180); //when seconds hit 10 the servo moves by 180*
  if ((myRTC.seconds) == 20);
  servo1.write(0); //when seconds hit 20 the servo moves back to start position
#include <Servo.h>
  // myRTC.setDS1302Time(00, 28, 21, 4, 24, 2, 2022); //set the current time
  myRTC.updateTime();
  Serial.print(":");
  delay(5000);
here yor programm without unnesecery text. not forget to install the lib from github.
