Problem with http://arduino.local/ in Arduino YUN
DISCLAIMER : I'm french and I don't speak English naturally :~
It is said ! :slight_smile:
So, I have Arduino YUN and when it starts its WIFI network, I connect there.
At the moment, no problem except that the connection time is in extremely long .........
However, when I want to go in the interface of the YUN with the address http: // arduino.local, the browser (Google chrome) load during a good minute to mark in the end that the page is inaccessible...
I would thus want to know how to solve this problem and especially where from comes it ?
I thank every person who will answer me.
Can you access the web interface through http://192.168.240.1?
If you are on windows, you need bonjour from Apple, if you search this forum for bonjour you should find posts with instructions on installation.
Thanx noblepepper but where can I find a topic like this ?
And is it possible that I have to make a special script for the arduino?
The adress 192.168.240.1 don't work.
After you connected did you change anything or is the Yun still as it was when you recieved it?
The first time you power up the Yun it will open a WiFi access point and the configuration page should be available at 192.168.240.1.
What OS are you running on your host computer?
http://forum.arduino.cc/index.php?topic=188101.msg1554795#msg1554795
http://forum.arduino.cc/index.php?topic=188101.msg1583686#msg1583686
Dariagua:
On the "Getting started" page for the Yun
http://arduino.cc/en/Guide/ArduinoYun#toc13
No.
What is the IP of your hosts PC you are trying to connect from?
This can of course only work if your host PC is in the same 192.168.240.0/24 subnet as the Yun is by default. And of course that you did not change the configuration of the Yun.
The use of a URL (http://arduino.local) will only work if there is some kind of name resolution available and for that it s recommended to have the Apple Bonjour service installed. But using the default IP address with a Yun in default Access Point mode has to work or you have a more basic networking issue, likely with your host PC...
Ralf
