This is my first project, so bear with me. I am creating a musical keyboard, and am working first on making sure my keyboard matrix scan works. The basic sketch reads the row and displays the key "number" on an LCD display. I'm able to get the display to change based on key press, however it only displays the keys (36-40) associated with the last column turned on. I confirmed this by disabling the enabling of column 8, and the outcome propagated with keys 31-35 being displayed on the LCD screen. It's almost as if the loop is being run once, stopping at the last column in the loop. Any help would be appreciated to help me understand how to make sure each key number is reflected by column.
Code is below:
#define row_1 30
#define row_2 31
#define row_3 32
#define row_4 33
#define row_5 34
#define col_1 22
#define col_2 23
#define col_3 24
#define col_4 25
#define col_5 26
#define col_6 27
#define col_7 28
#define col_8 29
int temp=0,tempold=1;
LiquidCrystal_I2C lcd(0x27, 20, 4); // set the LCD address to 0x27 for a 16 chars and 2 line display
- lcd.init(); // initialize the lcd*
- // Print a message to the LCD.*
- lcd.backlight();*
- lcd.begin(16, 2);*
- lcd.print("Hello, world!");*
- pinMode(row_1,OUTPUT);*
- pinMode(row_2,OUTPUT);*
- pinMode(row_3,OUTPUT);*
- pinMode(row_4,OUTPUT);*
- pinMode(row_5,OUTPUT);*
- pinMode(col_1,INPUT);*
- pinMode(col_2,INPUT);*
- pinMode(col_3,INPUT);*
- pinMode(col_4,INPUT);*
- pinMode(col_5,INPUT);*
- pinMode(col_6,INPUT);*
- pinMode(col_7,INPUT);*
- pinMode(col_8,INPUT);*
temp=0;*
digitalWrite(col_1, 1); digitalWrite(col_2, 0); digitalWrite(col_3, 0); digitalWrite(col_4, 0); digitalWrite(col_5, 0); digitalWrite(col_6, 0); digitalWrite(col_7, 0); digitalWrite(col_8, 0);*
if (digitalRead(row_1)==1) temp=1;*
if (digitalRead(row_2)==1) temp=2;*
if (digitalRead(row_3)==1) temp=3;*
if (digitalRead(row_4)==1) temp=4;*
if (digitalRead(row_5)==1) temp=5;*
digitalWrite(col_1, 0); digitalWrite(col_2, 1); digitalWrite(col_3, 0); digitalWrite(col_4, 0); digitalWrite(col_5, 0); digitalWrite(col_6, 0); digitalWrite(col_7, 0); digitalWrite(col_8, 0);*
if (digitalRead(row_1)==1) temp=6;*
if (digitalRead(row_2)==1) temp=7;*
if (digitalRead(row_3)==1) temp=8;*
if (digitalRead(row_4)==1) temp=9;*
if (digitalRead(row_5)==1) temp=10;*
digitalWrite(col_1, 0); digitalWrite(col_2, 0); digitalWrite(col_3, 1); digitalWrite(col_4, 0); digitalWrite(col_5, 0); digitalWrite(col_6, 0); digitalWrite(col_7, 0); digitalWrite(col_8, 0);*
if (digitalRead(row_1)==1) temp=11;*
if (digitalRead(row_2)==1) temp=12;*
if (digitalRead(row_3)==1) temp=13;*
if (digitalRead(row_4)==1) temp=14;*
if (digitalRead(row_5)==1) temp=15;*
digitalWrite(col_1, 0); digitalWrite(col_2, 0); digitalWrite(col_3, 0); digitalWrite(col_4, 1); digitalWrite(col_5, 0); digitalWrite(col_6, 0); digitalWrite(col_7, 0); digitalWrite(col_8, 0);*
if (digitalRead(row_1)==1) temp=16;*
if (digitalRead(row_2)==1) temp=17;*
if (digitalRead(row_3)==1) temp=18;*
if (digitalRead(row_4)==1) temp=19;*
if (digitalRead(row_5)==1) temp=20;*
digitalWrite(col_1, 0); digitalWrite(col_2, 0); digitalWrite(col_3, 0); digitalWrite(col_4, 0); digitalWrite(col_5, 1); digitalWrite(col_6, 0); digitalWrite(col_7, 0); digitalWrite(col_8, 0);*
if (digitalRead(row_1)==1) temp=21;*
if (digitalRead(row_2)==1) temp=22;*
if (digitalRead(row_3)==1) temp=23;*
if (digitalRead(row_4)==1) temp=24;*
if (digitalRead(row_5)==1) temp=25;*
digitalWrite(col_1, 0); digitalWrite(col_2, 0); digitalWrite(col_3, 0); digitalWrite(col_4, 0); digitalWrite(col_5, 0); digitalWrite(col_6, 1); digitalWrite(col_7, 0); digitalWrite(col_8, 0);*
if (digitalRead(row_1)==1) temp=26;*
if (digitalRead(row_2)==1) temp=27;*
if (digitalRead(row_3)==1) temp=28;*
if (digitalRead(row_4)==1) temp=29;*
if (digitalRead(row_5)==1) temp=30;*
digitalWrite(col_1, 0); digitalWrite(col_2, 0); digitalWrite(col_3, 0); digitalWrite(col_4, 0); digitalWrite(col_5, 0); digitalWrite(col_6, 0); digitalWrite(col_7, 1); digitalWrite(col_8, 0);*
if (digitalRead(row_1)==1) temp=31;*
if (digitalRead(row_2)==1) temp=32;*
if (digitalRead(row_3)==1) temp=33;*
if (digitalRead(row_4)==1) temp=34;*
if (digitalRead(row_5)==1) temp=35;*
digitalWrite(col_1, 0); digitalWrite(col_2, 0); digitalWrite(col_3, 0); digitalWrite(col_4, 0); digitalWrite(col_5, 0); digitalWrite(col_6, 0); digitalWrite(col_7, 0); digitalWrite(col_8, 1);*
if (digitalRead(row_1)==1) temp=36;*
if (digitalRead(row_2)==1) temp=37;*
if (digitalRead(row_3)==1) temp=38;*
if (digitalRead(row_4)==1) temp=39;*
if (digitalRead(row_5)==1) temp=40;*
if (temp!=tempold)*
lcd.setCursor(0, 1); lcd.print(" ");*
lcd.setCursor(0, 1); lcd.print(temp);*
tempold=temp;*
