Problem with my arduino UNO
I have an arduino UNO, i want to put a wire from 5V but i can not, the entry does not allow the full wire goal, I try to pin a resistor and enters very hard...
WHAT CAN I DO?
Are you saying you can not push a wire(pin) into the 5v socket?
Examine it closely(with a magnifying glass). If it has been damaged you may be able to tell.
Try using a needle to open the contacts rather than a larger wire. Once it is opened you may then be able to use the larger wire.
Yes, for example, if i connect the wire to gnd there isn´t problem but if i want to connect the wire to 5v i can not, and if enter but doesn´t full
If the socket is not recoverable, you may try soldering a wire to that pin (under the board), and using it for the 5v.
Else, use the usb power, or the 12v power inputs.
I connect already, but a wire not enter nice yet... Can I have problem because the wire not enter good?
fipinedasant:
You have connected, but not firm, and the arduino is working?
If the arduino is working ok, and your program is not critical, then I think you are ok with that.
Do you think your wire is to small, or to large, or what?
Try to lift/remove the black plastic that covers the pins.
Then you can see if the pin is damaged.
Leo..
YES, my arduino and (module bluetooth) that is where i want to connect, work good.... but i don´t know if is very sure use the whire so
