Problem with programming an Atmega328P via Arduino UNO
Hi, I'm trying to program an Atmega328P on breadboard via an Arduino Uno.
But I encountered several problems, first of all the process doesn't work.
First of all I loaded this sketch onto the Arduino UNO.
After that, I wanted to load this test sketch onto the Atmega328P to see if it worked.
  pinMode(9, OUTPUT);
  digitalWrite(9, HIGH);
  digitalWrite(9, LOW);
Using these settings:
But it doesn't work, I discovered that it is the Arduino Uno that is programmed, in fact if I then connect a LED to pin 9 of the Arduino it flashes.
That's the circuit:
What should I do?
Thanks for the help!
Did you click on "Upload" or "Upload Using Programmer"
I click here on upload because i don't see other icons
In the MENU click on Sketch, you will see Upload Using Programmer
Click on that to program the IC
You will first need to re-program the Uno with the ISP sketch
YOOOOOOOO THAKS YOU SO MUCH! IT WORK NOW! :grin:
Have a nice day!
Glad you are happy.
You too.
