I've a numeric dashboard project for my old truck that has a faulty dashboard at the moment (fuel level and water temp has wrong value, the sensors are good).
In this project, I've 4 sensors that are basically a resistor that changes with the value of the content (NTC400 water temp sensor, fuel capacitive sensor and 2 pressure sensors for air tank). But today I've a problem with some reverse voltage in measuring sensor ohms value. This project use a voltage divider to get the sensor resistance value.
For more context, I've tested air tank pressure sensor to get the value in ohms @ X bars. The sensor is orginally connected like that on the old dashboard (see attachement for drawing):
+24V (702A "11 pin)=> Gauge => dashboard sensor output (702A "14) => sensor => ground (I assume, it's an ohms mesurement with a voltage divider as the old dashboard gauge is only made from resistors and other small stuf, not ADC or anything else from what I can see inside).
All tests was done with a calibrated multimeter and not with the Arduino (the value in Arduino was not good until I set an offset, but like explained below, the reverse voltage value is not always the same).
I test without the dashboard, I test only the sensor that haven't any power supply like shown on manufacturer drawing (only two wire on this sensor).
With the master relay OFF I've correct values from 10 to 140 ohms (0 to 7.5 bars) and when I engage the master relay, the value became totally broken (50 ohms to 80 ohms @ 7.5bar)... When I check the voltage between ground and the dashboard input of the sensor (702A "14) I get 65 mV (Ground => Voltmeter => sensor input => ground) like shown in attachement.
This values doesn't change when engine is running but change as I engage more or less equipments from 50 to 95 mV on this input (with NTC400 water temp sensor the value isn't the same, about 20 mV when air pressure one is at 65 mV).
So, how can I "suppress" this reverse voltage (I don't know if it's the good name for this) to get the real good sensor value (ohms) like when master relay is not energized?
Or another way to get my sensor value maybe ?
I can set an offset in the arduino (it work as the equipement activated not change).
However, the old Analogic dashboard work perfectly for the air pressure values (the water and fuel gauges are broken and gave wrong value..., that's why I've this numeric dashboard project) but I can't use it anymore and a new one is few thousand euros...
Also it's difficult to explained very well the problem, let me know if it's not clear or need more informations.
