core.a(main_orig.cpp.o): In function main': /home/insippo/arduino-0022/hardware/arduino/cores/arduino/main_orig.cpp:7: undefined reference to setup'
/home/insippo/arduino-0022/hardware/arduino/cores/arduino/main_orig.cpp:10: undefined reference to `loop'
ubuntu 10.04, arduino duemilanove and eth shield w5100 with sd card. If i connect eth shield to arduino usb connection filed.
if i upload without eth shield : core.a(main_orig.cpp.o): In function main': /home/insippo/arduino-0022/hardware/arduino/cores/arduino/main_orig.cpp:7: undefined reference to setup'
/home/insippo/arduino-0022/hardware/arduino/cores/arduino/main_orig.cpp:10: undefined reference to `loop' again this error
what the problem ?
if i connect w5100 shield to arduino, arduino disconnect from usb port and arduino ide says:
Error inside Serial.serialEvent()
java.io.IOException: Input/output error in nativeavailable
at gnu.io.RXTXPort.nativeavailable(Native Method)
at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1532)
at processing.app.Serial.serialEvent(Serial.java:215)
at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732)
at gnu.io.RXTXPort.eventLoop(Native Method)
at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575)
ubuntu 10.04 and ubuntu 10.10 arduino duemilanove+w5100 with sd card reader
