Problem with Serial communication betweeen two Arduino Uno, Need Help
Hi everyone, I currently learning how to do Serial communication between two Arduino Uno board, I currently find some useful resources online and I immediately tried it out on my Arduino boards. I connect the cables between the Rx ---> TX correctly
( RX --- TX, TX----RX, like a cross).
The code is here:
//This is the sender
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("This is a test ");
//This is the receiver
char recievedChar;
if (Serial.available()){
recievedChar = Serial.read();
Serial.print(recievedChar);
The problem is I found out if I didn't connect the the one ground pin from one Arduino to another ground pin on the second Arduino, the Serial transfer will not start. Can somebody explain to me how come I have to connect the ground pins together to make it works ? Because I am try to build a wireless remote control project after I learn this and I don't want a cable linking between the ground pins.
http://computerchristmas.com/christmas/link-how_to/HowToId-4/How_To_Build_A_Parallel_Port_Controller_Box
The ground is required to make a complete electrical circuit between the two arduinos. The below might be of interest.
https://www.google.com/search?as_q=electronic+tutorial&as_epq=&as_oq=&as_eq=&as_nlo=&as_nhi=&lr=&cr=&as_qdr=all&as_sitesearch=&as_occt=any&safe=images&tbs=&as_filetype=&as_rights=
