missdrew:
Quite a few errors, if you copied this from a phone, then I can understand these, generally you had 2 setup() & 2 loop(), and a lot of [ instead of { . Here is an edited version (untested) , but it does compile.
#include <Servo.h>
#include <AFMotor.h>
#define LINE_BUFFER_LENGTH 512
char STEP = MICROSTEP ;
const int penZUp = 120;
const int penZDown = 50;
const int penServoPin = 10 ;
const int stepsPerRevolution = 48;
Servo penServo;
AF_Stepper myStepperY(stepsPerRevolution, 1);
AF_Stepper myStepperX(stepsPerRevolution, 2);
struct point {
float x;
float y;
float z;
struct point actuatorPos;
float StepInc = 1;
int StepDelay = 1;
int LineDelay = 0;
int penDelay = 50;
float StepsPerMillimeterX = 100.0;
float StepsPerMillimeterY = 100.0;
float Xmin = 0;
float Xmax = 40;
float Ymin = 0;
float Ymax = 40;
float Zmin = 0;
float Zmax = 1;
float Xpos = Xmin;
float Ypos = Ymin;
float Zpos = Zmax;
boolean verbose = false;
Serial.begin( 9600 );
penServo.attach(penServoPin);
penServo.write(penZUp);
delay(100);
// Decrease if necessary
myStepperX.setSpeed(600);
myStepperY.setSpeed(600);
Serial.println("Mini CNC Plotter alive and kicking!");
Serial.print("X range is from ");
Serial.print(Xmin);
Serial.print(" to ");
Serial.print(Xmax);
Serial.println(" mm.");
Serial.print("Y range is from ");
Serial.print(Ymin);
Serial.print(Ymax);
delay(100);
char line[ LINE_BUFFER_LENGTH ];
char c;
int lineIndex;
bool lineIsComment, lineSemiColon;
lineIndex = 0;
lineSemiColon = false;
lineIsComment = false;
while (1)
// Serial reception - Mostly from Grbl, added semicolon support
while ( Serial.available() > 0 )
c = Serial.read();
if (( c == '\n') || (c == '\r') )
{ // End of line reached
if ( lineIndex > 0 )
line[ lineIndex ] = '\0';
if (verbose)
Serial.print( "Received : ");
Serial.println( line );
processIncomingLine( line, lineIndex );
lineIndex = 0;
Serial.println("ok");
if ( (lineIsComment) || (lineSemiColon) )
if ( c == ')' ) lineIsComment = false;
if ( c <= ' ' )
else if ( c == '/' )
else if ( c == '(' )
lineIsComment = true;
else if ( c == ';' )
lineSemiColon = true;
else if ( lineIndex >= LINE_BUFFER_LENGTH - 1 )
Serial.println( "ERROR - lineBuffer overflow" );
else if ( c >= 'a' && c <= 'z' )
line[ lineIndex++ ] = c - 'a' + 'A';
line[ lineIndex++ ] = c;
void processIncomingLine( char* line, int charNB )
int currentIndex = 0;
char buffer[ 64 ];
struct point newPos;
newPos.x = 0.0;
newPos.y = 0.0;
while ( currentIndex < charNB )
switch ( line[ currentIndex++ ] )
case 'U':
penUp();
case 'D':
penDown();
case 'G':
buffer[0] = line[ currentIndex++ ]; // /!\ Dirty - Only works with 2 digit commands
// buffer[1] = line[ currentIndex++ ];
// buffer[2] = '\0';
buffer[1] = '\0';
switch ( atoi( buffer ) ) { // Select G command
case 0: // G00 & G01 - Movement or fast movement. Same here
case 1:
// /!\ Dirty - Suppose that X is before Y
char* indexX = strchr( line + currentIndex, 'X' ); // Get X/Y position in the string (if any)
char* indexY = strchr( line + currentIndex, 'Y' );
if ( indexY <= 0 ) {
newPos.x = atof( indexX + 1);
newPos.y = actuatorPos.y;
else if ( indexX <= 0 ) {
newPos.y = atof( indexY + 1);
newPos.x = actuatorPos.x;
else {
indexY = '\0';
drawLine(newPos.x, newPos.y );
// Serial.println("ok");
actuatorPos.x = newPos.x;
actuatorPos.y = newPos.y;
case 'M':
buffer[0] = line[ currentIndex++ ]; // /!\ Dirty - Only works with 3 digit commands
buffer[2] = line[ currentIndex++ ];
buffer[3] = '\0';
case 300:
char* indexS = strchr( line + currentIndex, 'S' );
float Spos = atof( indexS + 1);
if (Spos == 30) {
penDown();
if (Spos == 50) {
penUp();
case 114: // M114 - Repport position
Serial.print( "Absolute position : X = " );
Serial.print( actuatorPos.x );
Serial.print( " - Y = " );
Serial.println( actuatorPos.y );
default:
Serial.print( "Command not recognized : M");
Serial.println( buffer );
void drawLine(float x1, float y1)
if (verbose)
Serial.print("fx1, fy1: ");
Serial.print(x1);
Serial.print(",");
Serial.print(y1);
Serial.println("");
if (x1 >= Xmax)
x1 = Xmax;
if (x1 <= Xmin)
x1 = Xmin;
if (y1 >= Ymax)
y1 = Ymax;
if (y1 <= Ymin)
y1 = Ymin;
if (verbose)
Serial.print("Xpos, Ypos: ");
Serial.print(Xpos);
Serial.print(",");
Serial.print(Ypos);
Serial.println("");
if (verbose)
Serial.print("x1, y1: ");
Serial.print(x1);
Serial.print(",");
Serial.print(y1);
Serial.println("");
x1 = (int)(x1 * StepsPerMillimeterX);
y1 = (int)(y1 * StepsPerMillimeterY);
float x0 = Xpos;
float y0 = Ypos;
long dx = abs(x1 - x0);
long dy = abs(y1 - y0);
int sx = x0 < x1 ? StepInc : -StepInc;
int sy = y0 < y1 ? StepInc : -StepInc;
long i;
long over = 0;
if (dx > dy)
for (i = 0; i < dx; ++i)
myStepperX.onestep(sx, STEP);
over += dy;
if (over >= dx)
over -= dx;
myStepperY.onestep(sy, STEP);
delay(StepDelay);
for (i = 0; i < dy; ++i)
over += dx;
if (over >= dy)
over -= dy;
delay(StepDelay);
if (verbose)
Serial.print("dx, dy:");
Serial.print(dx);
Serial.print(",");
Serial.print(dy);
Serial.println("");
Serial.print("Going to (");
Serial.print(x0);
Serial.print(",");
Serial.print(y0);
Serial.println(")");
delay(LineDelay);
Xpos = x1;
Ypos = y1;
void penUp()
delay(penDelay);
Zpos = Zmax;
digitalWrite(15, LOW);
digitalWrite(16, HIGH);
if (verbose)
Serial.println("Pen up!");
void penDown()
penServo.write(penZDown);
delay(penDelay);
Zpos = Zmin;
digitalWrite(15, HIGH);
digitalWrite(16, LOW);
if (verbose)
Serial.println("Pen down.");
I'm trying to compile this code. I've installed libraries this way: Sketch->include library->add ZIP library
jimLee:
After all that.. Now I'm dying of curiosity to see the avatar.
-jim lee
Google "potężny gej" if your curious
