Mini CNC plotter machine stops working at pen function gcode
Hi there,
I am working on Mini CNC Plotter Machine using Arduino Uno + Motor shield + GCTRL for control. Every things work fine but when the machine reaches the code M300 S30 pen up and not reaches the end of gcode. Which creates problem in servo motor for penup pendown parts in complex drawing where penup is in the middle of some large gcode. Stepper motors are totally fine, but facing problem with pen up down with servo motor.
Hardware used: Arduino Uno R3, L293D MotorDriver Shield, Stepper motor from CD/DVD drives and Micro Servo SG90 Motor
Here the codes I have used
//Arduino Code
#include <Servo.h>
#include <AFMotor.h>
#define LINE_BUFFER_LENGTH 512
char STEP = MICROSTEP ;
// Servo position for Up and Down
const int penZUp = 40;
const int penZDown = 80;
// Servo on PWM pin 10
const int penServoPin =10 ;
// Should be right for DVD steppers, but is not too important here
const int stepsPerRevolution = 48;
// create servo object to control a servo
Servo penServo;
// Initialize steppers for X- and Y-axis using this Arduino pins for the L293D H-bridge
AF_Stepper myStepperY(stepsPerRevolution,1);
AF_Stepper myStepperX(stepsPerRevolution,2);
/* Structures, global variables    */
struct point {
  float x;
  float y;
  float z;
// Current position of plothead
struct point actuatorPos;
//  Drawing settings, should be OK
float StepInc = 1;
int StepDelay = 0;
int LineDelay =0;
int penDelay = 50;
// Motor steps to go 1 millimeter.
// Use test sketch to go 100 steps. Measure the length of line.
// Calculate steps per mm. Enter here.
float StepsPerMillimeterX = 100.0;
float StepsPerMillimeterY = 100.0;
// Drawing robot limits, in mm
// OK to start with. Could go up to 50 mm if calibrated well.
float Xmin = -20;
float Xmax = 20;
float Ymin = -20;
float Ymax = 20;
float Zmin = 0;
float Zmax = 1;
float Xpos = Xmin;
float Ypos = Ymin;
float Zpos = Zmax;
// Set to true to get debug output.
boolean verbose = false;
//  Needs to interpret
//  G1 for moving
//  G4 P300 (wait 150ms)
//  M300 S30 (pen down)
//  M300 S50 (pen up)
//  Discard anything with a (
//  Discard any other command!
 * void setup() - Initialisations
  //  Setup
  Serial.begin( 9600 );
  penServo.attach(penServoPin);
  penServo.write(penZUp);
  delay(100);
  // Decrease if necessary
  myStepperX.setSpeed(600);
  myStepperY.setSpeed(600);
  //  Set & move to initial default position
  // TBD
  //  Notifications!!!
  Serial.println("Mini CNC Plotter alive and kicking!");
  Serial.print("X range is from ");
  Serial.print(Xmin);
  Serial.print(" to ");
  Serial.print(Xmax);
  Serial.println(" mm.");
  Serial.print("Y range is from ");
  Serial.print(Ymin);
  Serial.print(Ymax);
 * void loop() - Main loop
  delay(100);
  char line[ LINE_BUFFER_LENGTH ];
  char c;
  int lineIndex;
  bool lineIsComment, lineSemiColon;
  lineIndex = 0;
  lineSemiColon = false;
  lineIsComment = false;
  while (1) {
    // Serial reception - Mostly from Grbl, added semicolon support
    while ( Serial.available()>0 ) {
      c = Serial.read();
      if (( c == '\n') || (c == '\r') ) {             // End of line reached
        if ( lineIndex > 0 ) {                        // Line is complete. Then execute!
          line[ lineIndex ] = '\0';                   // Terminate string
          if (verbose) {
            Serial.print( "Received : ");
            Serial.println( line );
          processIncomingLine( line, lineIndex );
          lineIndex = 0;
        else {
          // Empty or comment line. Skip block.
        Serial.println("ok");
      else {
        if ( (lineIsComment) || (lineSemiColon) ) {   // Throw away all comment characters
          if ( c == ')' )  lineIsComment = false;     // End of comment. Resume line.
        else {
          if ( c <= ' ' ) {                           // Throw away whitepace and control characters
          else if ( c == '/' ) {                    // Block delete not supported. Ignore character.
          else if ( c == '(' ) {                    // Enable comments flag and ignore all characters until ')' or EOL.
            lineIsComment = true;
          else if ( c == ';' ) {
            lineSemiColon = true;
          else if ( lineIndex >= LINE_BUFFER_LENGTH-1 ) {
            Serial.println( "ERROR - lineBuffer overflow" );
          else if ( c >= 'a' && c <= 'z' ) {        // Upcase lowercase
            line[ lineIndex++ ] = c-'a'+'A';
          else {
            line[ lineIndex++ ] = c;
void processIncomingLine( char* line, int charNB ) {
  int currentIndex = 0;
  char buffer[ 64 ];                                 // Hope that 64 is enough for 1 parameter
  struct point newPos;
  newPos.x = 0.0;
  newPos.y = 0.0;
  //  G1 for moving
  //  G1 X60 Y30
  //  G1 X30 Y50
  while( currentIndex < charNB ) {
    switch ( line[ currentIndex++ ] ) {              // Select command, if any
    case 'U':
      penUp();
    case 'D':
      penDown();
    case 'G':
      buffer[0] = line[ currentIndex++ ];          // /!\ Dirty - Only works with 2 digit commands
      //      buffer[1] = line[ currentIndex++ ];
      //      buffer[2] = '\0';
      buffer[1] = '\0';
      switch ( atoi( buffer ) ){                   // Select G command
      case 0:                                   // G00 & G01 - Movement or fast movement. Same here
      case 1:
        // /!\ Dirty - Suppose that X is before Y
        char* indexX = strchr( line+currentIndex, 'X' );  // Get X/Y position in the string (if any)
        char* indexY = strchr( line+currentIndex, 'Y' );
        if ( indexY <= 0 ) {
          newPos.x = atof( indexX + 1);
          newPos.y = actuatorPos.y;
        else if ( indexX <= 0 ) {
          newPos.y = atof( indexY + 1);
          newPos.x = actuatorPos.x;
        else {
          indexY = '\0';
        drawLine(newPos.x, newPos.y );
        //        Serial.println("ok");
        actuatorPos.x = newPos.x;
        actuatorPos.y = newPos.y;
    case 'M':
      buffer[0] = line[ currentIndex++ ];        // /!\ Dirty - Only works with 3 digit commands
      buffer[2] = line[ currentIndex++ ];
      buffer[3] = '\0';
      case 300:
          char* indexS = strchr( line+currentIndex, 'S' );
          float Spos = atof( indexS + 1);
          if (Spos == 50) {
            penUp();
          if (Spos == 30) {
            penDown();
      case 114:                                // M114 - Repport position
        Serial.print( "Absolute position : X = " );
        Serial.print( actuatorPos.x );
        Serial.print( "  -  Y = " );
        Serial.println( actuatorPos.y );
      default:
if ((buffer[0] == 1) && (buffer [1] == 8)){ // M18 = drives off
Serial.println( " M18: we are done, turn drives off" );
myStepperX.release();
myStepperY.release();
else {
Serial.print("Command not recognised: M");
Serial.println( buffer );
 * Draw a line from (x0;y0) to (x1;y1).
 * int (x1;y1) : Starting coordinates
 * int (x2;y2) : Ending coordinates
void drawLine(float x1, float y1) {
  if (verbose)
    Serial.print("fx1, fy1: ");
    Serial.print(x1);
    Serial.print(",");
    Serial.print(y1);
    Serial.println("");
  //  Bring instructions within limits
  if (x1 >= Xmax) {
    x1 = Xmax;
  if (x1 <= Xmin) {
    x1 = Xmin;
  if (y1 >= Ymax) {
    y1 = Ymax;
  if (y1 <= Ymin) {
    y1 = Ymin;
  if (verbose)
    Serial.print("Xpos, Ypos: ");
    Serial.print(Xpos);
    Serial.print(",");
    Serial.print(Ypos);
    Serial.println("");
  if (verbose)
    Serial.print("x1, y1: ");
    Serial.print(x1);
    Serial.print(",");
    Serial.print(y1);
    Serial.println("");
  //  Convert coordinates to steps
  x1 = (int)(x1*StepsPerMillimeterX);
  y1 = (int)(y1*StepsPerMillimeterY);
  float x0 = Xpos;
  float y0 = Ypos;
  //  Let's find out the change for the coordinates
  long dx = abs(x1-x0);
  long dy = abs(y1-y0);
  int sx = x0<x1 ? StepInc : -StepInc;
  int sy = y0<y1 ? StepInc : -StepInc;
  long i;
  long over = 0;
  if (dx > dy) {
    for (i=0; i<dx; ++i) {
      myStepperX.onestep(sx,STEP);
      over+=dy;
      if (over>=dx) {
        over-=dx;
        myStepperY.onestep(sy,STEP);
    delay(StepDelay);
  else {
    for (i=0; i<dy; ++i) {
      over+=dx;
      if (over>=dy) {
        over-=dy;
      delay(StepDelay);
  if (verbose)
    Serial.print("dx, dy:");
    Serial.print(dx);
    Serial.print(",");
    Serial.print(dy);
    Serial.println("");
  if (verbose)
    Serial.print("Going to (");
    Serial.print(x0);
    Serial.print(",");
    Serial.print(y0);
    Serial.println(")");
  //  Delay before any next lines are submitted
  delay(LineDelay);
  //  Update the positions
  Xpos = x1;
  Ypos = y1;
//  Raises pen
void penUp() {
  delay(penDelay);
  Zpos=Zmax;
  //digitalWrite(15, LOW);
    //digitalWrite(16, HIGH);
  if (verbose) {
    Serial.println("Pen up!");
//  Lowers pen
void penDown() {
  penServo.write(penZDown);
  delay(penDelay);
  Zpos=Zmin;
  //digitalWrite(15, HIGH);
    //digitalWrite(16, LOW);
  if (verbose) {
    Serial.println("Pen down.");
import java.awt.event.KeyEvent;
import javax.swing.JOptionPane;
import processing.serial.*;
Serial port = null;
// select and modify the appropriate line for your operating system
// leave as null to use interactive port (press 'p' in the program)
//String portname = null;
//String portname = Serial.list()[0]; // Mac OS X
//String portname = "/dev/ttyUSB0"; // Linux
String portname = "COM10"; // Windows
boolean streaming = false;
float speed = 0.001;
String[] gcode;
int i = 0;
void openSerialPort()
  if (portname == null) return;
  if (port != null) port.stop();
  port = new Serial(this, portname, 9600);
  port.bufferUntil('\n');
void selectSerialPort()
    String result = (String) JOptionPane.showInputDialog(null,
    "Select the serial port that corresponds to your Arduino board.",
    "Select serial port",
    JOptionPane.PLAIN_MESSAGE,
    null,
    Serial.list(),
    0);
  if (result != null) {
    portname = result;
    openSerialPort();
  size(500, 250);
  openSerialPort();
void draw()
  background(0);
  fill(255);
  int y = 24, dy = 12;
  text("INSTRUCTIONS", 12, y); y += dy;
  text("p: select serial port", 12, y); y += dy;
  text("arrow keys: jog in x-y plane", 12, y); y += dy;
  text("5 & 2: jog in z axis", 12, y); y += dy;
  text("$: display grbl settings", 12, y); y+= dy;
  text("h: go home", 12, y); y += dy;
  text("0: zero machine (set home to the current location)", 12, y); y += dy;
  text("g: stream a g-code file", 12, y); y += dy;
  text("x: stop streaming g-code (this is NOT immediate)", 12, y); y += dy;
  y = height - dy;
  text("current jog speed: " + speed + " inches per step", 12, y); y -= dy;
  text("current serial port: " + portname, 12, y); y -= dy;
void keyPressed()
  if (key == '1') speed = 0.001;
  if (key == '2') speed = 0.01;
  if (key == '3') speed = 0.1;
  if (!streaming) {
    if (keyCode == LEFT) port.write("G21/G90/G1 X-10  F3500\n");
    if (keyCode == RIGHT) port.write("G21/G90/G1 X10 F3500\n");
    if (keyCode == UP) port.write("G21/G90/G1 Y10 F3500\n");
    if (keyCode == DOWN) port.write("G21/G90/G1 Y-10 F3500\n");
    if (key == '5') port.write("M300 S50\n");
    if (key == '2') port.write("M300 S30\n");
    if (key == 'h') port.write("G90\nG20\nG00 X0.000 Y0.000 Z0.000\n");
    if (key == 'v') port.write("$0=75\n$1=74\n$2=75\n");
    //if (key == 'v') port.write("$0=100\n$1=74\n$2=75\n");
    if (key == 's') port.write("$3=10\n");
    if (key == 'e') port.write("$16=1\n");
    if (key == 'd') port.write("$16=0\n");
    if (key == '0') openSerialPort();
    if (key == 'p') selectSerialPort();
    if (key == '$') port.write("$$\n");
  if (!streaming && key == 'g') {
    gcode = null; i = 0;
    File file = null;
    println("Loading file...");
    selectInput("Select a file to process:", "fileSelected", file);
  if (key == 'x') streaming = false;
void fileSelected(File selection) {
  if (selection == null) {
    println("Window was closed or the user hit cancel.");
    println("User selected " + selection.getAbsolutePath());
    gcode = loadStrings(selection.getAbsolutePath());
    if (gcode == null) return;
    streaming = true;
    stream();
void stream()
  if (!streaming) return;
  while (true) {
    if (i == gcode.length) {
      streaming = false;
      return;
    if (gcode[i].trim().length() == 0) i++;
    else break;
  println(gcode[i]);
  port.write(gcode[i] + '\n');
  i++;
void serialEvent(Serial p)
  String s = p.readStringUntil('\n');
  println(s.trim());
  if (s.trim().startsWith("ok")) stream();
  if (s.trim().startsWith("error")) stream(); // XXX: really?
//GCTRL code which is used in Processing software
//Sample Gcode which should run till end
(Scribbled version of C:\Users\sgosw\AppData\Local\Temp\ink_ext_XXXXXX.svgIVSFN2 @ 3500.00)
( unicorn.py --tab="pen_changes" --pen-up-angle=50 --pen-down-angle=30 --start-delay=150 --stop-delay=150 --xy-feedrate=3500 --z-feedrate=150 --z-height=0 --finished-height=0 --register-pen=false --x-home=0 --y-home=0 --num-copies=1 --continuous=false --pause-on-layer-change=false C:\Users\sgosw\AppData\Local\Temp\ink_ext_XXXXXX.svgIVSFN2 )
G21 (metric ftw)
G90 (absolute mode)
G92 X0.00 Y0.00 Z0.00 (you are here)
(Polyline consisting of 1 segments.)
G1 X-7.30 Y-4.26 F3500.00
M300 S50 (pen down)
G4 P150 (wait 150ms)
G1 X-5.09 Y-4.07 F3500.00
G1 X-4.36 Y-6.29 F3500.00
G1 X-3.62 Y-7.07 F3500.00
G1 X-2.58 Y-7.69 F3500.00
G1 X0.14 Y-8.22 F3500.00
G1 X2.51 Y-7.82 F3500.00
G1 X4.04 Y-6.70 F3500.00
G1 X4.54 Y-5.16 F3500.00
G1 X4.05 Y-3.68 F3500.00
G1 X2.46 Y-2.62 F3500.00
G1 X-0.69 Y-1.74 F3500.00
G1 X-4.11 Y-0.61 F3500.00
G1 X-5.22 Y0.15 F3500.00
G1 X-6.00 Y1.07 F3500.00
G1 X-6.47 Y2.13 F3500.00
G1 X-6.62 Y3.31 F3500.00
G1 X-6.43 Y4.63 F3500.00
G1 X-5.86 Y5.86 F3500.00
G1 X-4.92 Y6.90 F3500.00
G1 X-3.64 Y7.66 F3500.00
G1 X-2.09 Y8.12 F3500.00
G1 X-0.39 Y8.28 F3500.00
G1 X1.46 Y8.12 F3500.00
G1 X3.08 Y7.63 F3500.00
G1 X4.41 Y6.83 F3500.00
G1 X5.40 Y5.73 F3500.00
G1 X6.02 Y4.39 F3500.00
G1 X6.26 Y2.89 F3500.00
G1 X4.02 Y2.72 F3500.00
G1 X3.62 Y4.22 F3500.00
G1 X2.79 Y5.30 F3500.00
G1 X1.50 Y5.96 F3500.00
G1 X-0.29 Y6.17 F3500.00
G1 X-2.13 Y5.98 F3500.00
G1 X-3.39 Y5.38 F3500.00
G1 X-4.12 Y4.51 F3500.00
G1 X-4.36 Y3.47 F3500.00
G1 X-4.19 Y2.58 F3500.00
G1 X-3.67 Y1.87 F3500.00
G1 X-2.45 Y1.24 F3500.00
G1 X-0.14 Y0.59 F3500.00
G1 X3.78 Y-0.56 F3500.00
G1 X5.12 Y-1.38 F3500.00
G1 X6.06 Y-2.40 F3500.00
G1 X6.61 Y-3.60 F3500.00
G1 X6.80 Y-4.96 F3500.00
G1 X6.59 Y-6.36 F3500.00
G1 X5.99 Y-7.67 F3500.00
G1 X5.00 Y-8.81 F3500.00
G1 X3.66 Y-9.65 F3500.00
G1 X2.05 Y-10.18 F3500.00
G1 X0.25 Y-10.36 F3500.00
G1 X-1.96 Y-10.18 F3500.00
G1 X-3.78 Y-9.65 F3500.00
G1 X-5.23 Y-8.75 F3500.00
G1 X-6.32 Y-7.50 F3500.00
G1 X-7.03 Y-5.98 F3500.00
M300 S30 (pen up)
(end of print job)
M300 S50.00 (pen up)
M300 S255 (turn off servo)
G1 X0 Y0 F3500.00
G1 Z0.00 F150.00 (go up to finished level)
G1 X0.00 Y0.00 F3500.00 (go home)
M18 (drives off)
//same gcode which the machine runs
X range is from -20.00 to 20.00 mm.
Y range is from -20.00 to 20.00 mm.
Loading file...
User selected C:\Users\sgosw\OneDrive\Desktop\S.gcode
ok
ok
G21 (metric ftw)
ok
G90 (absolute mode)
ok
ok
ok
ok
M300 S50 (pen down)
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
M300 S30 (pen up)
Could You post a link to the dstasheet of the servo motor? Any end or limit swiches involved?
Schematics for the servo motor parts could be va,uable.
I tried instructions from this website to make it.. and make exactly whats there given.
I don't accept cookies.. Please extract the requested data for the servo motor.
I cant able to upload as I'm a new user....
I'm providing you the drive link of the servo SG90 dataset
Also, today I figure out one thing that its not about any code that stops the gcode, its actually the servo, whenever the servo moves whether for pen up or pen down, the gcode doesn't continue anymore,.... please help
So you power the stepper motor from the 5volt rail of the Uno? (through the L293 shield).
And how is the Uno powered.
Leo..
I have power the Arduino which is connected to motor shield with 5V 1A adapter
I know you power the shield (the stepper motors) with 5volt (on the screw terminal),
but I asked how you did power the Arduino (and the servo).
Leo..
I just connect the printer cable from laptop to arduino.. thats it and above that the shield which connects steppers and servo which is powered by that adapter... thats it, apart from this I haven't use any other power source
Did you remove the jumper, next to the screw terminal?
So the laptop powers the Uno (and the servo). Yes, servo power comes from the 5volt pin of the Arduino, which is basically a design fault of that shield.
I would remove the jumper (if not already removed).
Then lift the red wire of the servo out of it's connector (use a needle to lift the lock).
Then extend the red (power) wire of the servo to +5volt of the screw connector.
Now the servo is powered from the external 5volt supply instead of from the laptop.
Maybe upload a picture before you power it up.
Leo..
Yes I have removed the jumper already.. ok let me try the rest what you have suggested and see.
So, you are suggesting me to connect red(M+) of the shield to the middle red wire if servo?
Try to lift the red wire out of that connector first.
Leo..
Ok.. and then extend it to the 5v 1A adapter and connect with red +ve socket wire?
Yes.
I'm not saying it will fix your problem, but it's worth a try to power the servo from the 5volt adapter instead of the Arduino 5volt rail.
Leo..
Bro, the prob is fixed, thank you so much. Power issue was there. When I now connect the red(+ve) end of the servo directly to the red end of the adapter supply and runs the gcode the pen up and down works properly. Thanks a lot!!!!!!!!!!!
Good to hear you got it fixed.
Leo..
