Problem with SparkFun Simultaneous RFID Reader M6E Nano
Hello there,
so I have this SRTR board from Spark fun and I have made it work successfully, the problem is that it's not working as I wanted it for my project. as the module's introduction says, it can read about 150 RFID tags per second, I want to be able to place for example, 15 tags in the antenna range and use this module to sense the presence of these tags. but the module only reads the closest tag in the antennas range, for example, if I place a tag in 20cm away from the antenna, and another one in 40cm, it will only read the first one and ignore the one that is further away.
I want to know is it the way the module works or is there hope to fix this problem in the code. The code is not mine and I dont know if I can share the whole thing here but if there's a specific part of the code you need to read I can share it.
I do not think anyone in this forum will be able to help you, especially because you have not shared any code.
I think you would have more success contacting Sparkfun about your problem. But first make sure you have read their guides for using the scanner, to make sure you have not missed the answer there.
I talked to the owner of the code and he said its ok to post it.
so here's the code:
#include <SoftwareSerial.h>  //Used for transmitting to the device
SoftwareSerial softSerial(2, 3);  //RX, TX
SoftwareSerial mySerial(7, 8);    //RX, TX
#include "SparkFun_UHF_RFID_Reader.h"  //Library for controlling the M6E Nano module
RFID nano;                             //Create instance
///#define BUZZER1 9
///#define BUZZER2 10
char c;
#define EPC_COUNT 50
#define EPC_ENTRY 12
uint8_t EPC_recv[EPC_COUNT][EPC_ENTRY];
bool enable_clr = false;
byte type_s;
byte addr[8];
int val1;
unsigned long previousMillis = 0;  // last time update
long interval = 2000;              // interval at which to do something (milliseconds)
#define PRMDEBUG 0
void setup(void) {
  mySerial.begin(115200);
  initialize_RFID();
  init_array();
void loop(void) {
  Check_EPC();
void initialize_RFID() {
retry:
  Serial.println(F("try to connect to RFID reader"));
  //Configure nano to run at certain speed
  int RunStatus = setupNano(38400);
  if (RunStatus == 0) {
    serialTrigger(F("Module failed to respond. Please check wiring."));
    yield();
    goto retry;
  if (RunStatus == 1) {  // was not yet in continues mode
    nano.setRegion(REGION_EUROPE);
    nano.setTagProtocol();  //Set protocol to GEN2
    nano.setAntennaPort();  //Set TX/RX antenna ports to 1
    nano.setReadPower(2000);  //10.00 dBm. Higher values may cause USB port to brown out
    //Max Read TX Power is 27.00 dBm and may cause temperature-limit throttling
  Serial.println("RFID shield initialized");
/* initialize/empty the array to capture detected EPC */
void init_array() {
  for (val1 = 0; val1 < EPC_COUNT; val1++) EPC_recv[val1][0] = 0;
  Serial.println("done");
void Check_EPC() {
  uint8_t myEPC[EPC_ENTRY];  // Most EPCs are 12 bytes
  //if (nano.check() == true) { // Check to see if any new data has come in from module
  byte responseType = nano.parseResponse();  //Break response into tag ID, RSSI, frequency, and timestamp
  if (responseType == RESPONSE_IS_KEEPALIVE) {
    if (PRMDEBUG > 1) Serial.println(F("scanning"));
    Serial.println("hi");
  else if (responseType == RESPONSE_IS_TAGFOUND) {
    for (byte x = 0; x < EPC_ENTRY; x++) {
      myEPC[x] = nano.msg[31 + x];
    add_ECP_entry(myEPC, EPC_ENTRY);
    if (PRMDEBUG > 0) {
      //If we have a full record we can pull out the fun bits
      int rssi = nano.getTagRSSI();  //Get the RSSI for this tag read
      long freq = nano.getTagFreq();  //Get the frequency this tag was detected at
      long timeStamp = nano.getTagTimestamp();  //Get the time this was read, (ms) since last keep-alive message
      byte tagEPCBytes = nano.getTagEPCBytes();  //Get the number of bytes of EPC from response
      Serial.print(F(" rssi["));
      Serial.print(rssi);
      Serial.print(F("]"));
      Serial.print(F(" freq["));
      Serial.print(freq);
      Serial.print(F(" time["));
      Serial.print(timeStamp);
      //Print EPC bytes,
      Serial.print(F(" epc["));
        if (myEPC[x] < 0x10) Serial.print(F("0"));  //Pretty print adding zero
        Serial.print(myEPC[x], HEX);
        Serial.print(F(" "));
      Serial.println("]");
    //Unknown response
    if (PRMDEBUG > 1) nano.printMessageArray();  //Print the response message. Look up errors in tmr__status_8h.html
//Gracefully handles a reader that is already configured and already reading continuously
int setupNano(long baudRate) {
  if (PRMDEBUG == 3) nano.enableDebugging(softSerial);
  nano.begin(softSerial);  //Tell the library to communicate over software serial port
  //Test to see if we are already connected to a module
  //This would be the case if the Arduino has been reprogrammed and the module has stayed powered
  softSerial.begin(baudRate);  //For this test, assume module is already at our desired baud rate
  while (!softSerial) yield();  //Wait for port to open
  //About 200ms from power on the module will send its firmware version at 115200. We need to ignore this.
  while (softSerial.available()) softSerial.read();
  val1 = 0;
  while (val1 < 2) {
    nano.getVersion();
    if (nano.msg[0] == ERROR_WRONG_OPCODE_RESPONSE) {
      if (PRMDEBUG > 1) Serial.println(F("Module continuously reading. Not Asking it to stop..."));
      return (2);
    else if (nano.msg[0] != ALL_GOOD) {
      if (PRMDEBUG > 1) Serial.println(F("Try reset RFID speed"));
      //The module did not respond so assume it's just been powered on and communicating at 115200bps
      softSerial.begin(115200);  //Start software serial at 115200
      nano.setBaud(baudRate);  //Tell the module to go to the chosen baud rate. Ignore the response msg
      softSerial.begin(baudRate);  //Start the software serial port, this time at user's chosen baud rate
    else {
      return (1);  // Responded, but have to be set in the right mode
    val1++;
  return (0);
void add_ECP_entry(uint8_t *msg, byte mlength) {
  byte j;
  val1 = 0;
  bool found;
  // as long as not end of list or end of array
  while (val1 < EPC_COUNT && EPC_recv[val1][0] != 0) {
    found = true;
    // check each entry for a match
    for (j = 0; j < mlength, j < EPC_ENTRY; j++) {
      if (EPC_recv[val1][j] != msg[j]) {
        found = false;  // indicate not fuond
        j = EPC_ENTRY;
    // if found
    if (found == true) {
      if (PRMDEBUG > 1) {
        Serial.print(F("FOUND EPC in array entry "));
        Serial.println(val1);
      return;
    val1++;  // next entry
  // Not found, can we still add?
  if (val1 == EPC_COUNT) {
    if (PRMDEBUG > 0) Serial.println(F("Can not add more to array"));
    return;
  // debug info
  if (PRMDEBUG > 1) {
    Serial.print(F("New entry number is "));
  // add entry to the array
  for (j = 0; j < mlength, j < EPC_ENTRY; j++) EPC_recv[val1][j] = msg[j];
void serialTrigger(String message) {
  Serial.println(message);
  while (!Serial.available())
  while (Serial.available()) Serial.read();
If I had written this code I would have said "do not post it, I am too embarrassed".
But I would not have used goto!
(I don't think using goto is the cause of the problem, but it does not give me confidence in the abilities of the author)
Have you tried any of the example sketches provided by Sparkfun?
Lmao, good that it's not mine
