Problem with wi-fi extender
Hello,
I need to connect an Arduino Ethernet Shild to be placed in a site where I don't have a phisical internet connection.
Previously I used a wi-fi extender (Aigital WN532N2) with also a LAN port available but now it is not working anymore (probably it has been damaged because of a lightning).
I bought another extender, apparently the same model, but unfortunately the LAN port is not available (maybe they changed the firmware in the meantime).
Does anybody know what sort of wi-fi extender could I buy instead?
I also tried to use power lines but they don't work in my house.
Thank you very much.
Best regards
@gianluca1
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Please tell us what distances your are having trouble with. My laptops regularly see WIFI from the neighbors 1/4 to 3/4 miles away.
Paul
Probably you didn't read my post carefully. In fact this is not an answer to my question.
I have no problem with distance because I don't have to cover more that 4 meters. The problem is that I need a port to connect the Ethernet shield!
gianluca1:
Not sure I understand the problem or why its an Arduino issue ?
Finding such a device is easy enough, try as search on eBay perhaps ?
