Hi, I've Purchased WTV020-SD.
I use a Microsd 2GB, in this I've copied ad4 files audio.
I used this sketch:
Example: Control a WTV020-SD-16P module to play voices from an Arduino board.
Created by Diego J. Arevalo, August 6th, 2012.
Released into the public domain.
#include <Wtv020sd16p.h>
int resetPin = 2; // The pin number of the reset pin.
int clockPin = 3; // The pin number of the clock pin.
int dataPin = 4; // The pin number of the data pin.
int busyPin = 5; // The pin number of the busy pin.
Create an instance of the Wtv020sd16p class.
1st parameter: Reset pin number.
2nd parameter: Clock pin number.
3rd parameter: Data pin number.
4th parameter: Busy pin number.
Wtv020sd16p wtv020sd16p(resetPin,clockPin,dataPin,busyPin);
//Initializes the module.
wtv020sd16p.reset();
//Plays synchronously an audio file. Busy pin is used for this method.
wtv020sd16p.playVoice(0);
//Plays asynchronously an audio file.
wtv020sd16p.asyncPlayVoice(1);
//Plays audio file number 1 during 2 seconds.
delay(5000);
//Pauses audio file number 1 during 2 seconds.
wtv020sd16p.pauseVoice();
delay(5000);
//Resumes audio file number 1 during 2 seconds.
delay(5000);
//Stops current audio file playing.
wtv020sd16p.stopVoice();
wtv020sd16p.asyncPlayVoice(2);
delay(2000);
//Mutes audio file number 2 during 2 seconds.
wtv020sd16p.mute();
delay(2000);
//Unmutes audio file number 2 during 2 seconds.
wtv020sd16p.unmute();
delay(2000);
The problem is that can not hear anything!
Can you help me please? I'm going crazy.
Thanks in advance.
