Trying to play WAV file with Arduino - getting buzzing sound instead
Why is it not working ? I get a a buzzing sound instead of my sound. I suspect my circuit is wrong but don't know why.
--> Can someone please help ?
Here is the diagram :
The mosfet is the IRF520 Mosfet I got with the starter pack.
Here is the code :
#include <SPI.h>
#include <SD.h>
#include <TMRpcm.h>
TMRpcm tmrpcm;
#define DISABLE_SPEAKER2
#define SD_CS_PIN 4 // Chip Select pin for SD card
tmrpcm.speakerPin = 9; //5,6,11 or 46 on Mega, 9 on Uno, Nano, etc
Serial.print("SD Card init ...");
if (!SD.begin(SD_CS_PIN)) {
Serial.println("Init failed!");
while (1);
Serial.println("Init OK");
if (SD.exists("c6000_16.wav"))
Serial.println("File found !");
else {
Serial.println("File NOT found !");
while (1); // Stop if the file is not found
// *** WAV File Header Check ***
File wavFile = SD.open("c6000_16.wav");
if (!wavFile) {
Serial.println("Error opening WAV file!");
while (1);
// Read the first 44 bytes (typical WAV header size)
byte header[44];
if (wavFile.read(header, 44) != 44) {
Serial.println("Error reading WAV header!");
wavFile.close();
while (1);
// Print some header information (for debugging)
Serial.print("File Size: ");
Serial.println((uint32_t)&header[4]); // File size - 8 bytes
Serial.print("Sample Rate: ");
Serial.println((uint32_t)&header[24]); // Sample rate (Hz)
Serial.print("Bits per Sample: ");
Serial.println((uint16_t)&header[34]); // Bits per sample
wavFile.close();
Serial.println("Playing ...");
tmrpcm.play("c6000_16.wav"); // Try playing with TMRpcm
Serial.println("Stop");
delay(2000);
Serial.println("Loop");
tone(9, 440);
noTone(9);
And here is the output :
SD Card init ...Init OK
File found !
File Size: 2189
Sample Rate: 2209
Bits per Sample: 2219
Playing ...
Stop
Loop
You need a different MOSFET or a transistor.
Do you have any transistors?
If yes what are the part numbers
Does your speaker look like this?
Thank you for your reply.
Yes my speaker looks exactly like that one.
I just have the Arduino starter pack so that's the only transistor I have.
May I ask why that transistor will not work?
It may or may not work in certain applications because it needs 10V on the gate in order to turn it ON/OFF and the Uno is only 5V
It was a very poor choice to include in a starter kit.
Try this
Make R3 330 ohms.
Remove R1
Make R2 100 ohms
Try a simple sketch using tone() just for testing.
Sample Rate: 2209
Minimum sample rate for TMRpcm is 8000Hz.
