Problem
Hello.
My name is Clément, I'm French. I'm 18, I'm in the final year of high school, sector "STI2D". It was a project by year end we must submit to the oral, which was as base Arduino. This project is perform an automatic and autonomous portal. We are 4 in the project, and I have to open the doors with a L298 (I took it to the GHI electronics module). I managed to move the doors without problems but I do not know how I can program to an LED flash for its opening and especially how to stop it if overcurrent. The engines are "MFA Como drills" (that is what is written on it). and sorry for my english, it is not wonderful ... I will post the program :wink:
Thanks
Clément
The program for moving a door, and then move 2 doors :
//MOTEUR A
int ENA=5; //Connecté à Arduino pin 5(sortie pwm)
int IN1=1; //Connecté à Arduino pin 1
int IN2=2; //Connecté à Arduino pin 2
//MOTEUR B
int ENB=6; //Connecté à Arduino pin 6(Sortie pwm)
int IN3=3; //Connecté à Arduino pin 3
int IN4=4; //Connecté à Arduino pin 4
const int LED=12;                 // déclaration de la constante de broche, ici c'est la broche 12
 pinMode(LED,OUTPUT);//déclaration du type de connexion utilisé pour la LED, ici une sortie (output) reliée à la broche n°12
 pinMode(ENA,OUTPUT);//Configurer les broches comme sorties
 pinMode(ENB,OUTPUT);
 pinMode(IN1,OUTPUT);
 pinMode(IN2,OUTPUT);
 pinMode(IN3,OUTPUT);
 pinMode(IN4,OUTPUT);
 digitalWrite(ENA,LOW);// Moteur A - Ne pas tourner (désactivation moteur)
 digitalWrite(ENB,LOW);// Moteur B - Ne pas tourner (désactivation moteur)
  // Moteur A
  analogWrite(ENA,25);
  // Moteur B
  analogWrite(ENB,25);
  ouverture_1();
  fermeture_1();
  delay(10000);
  ouverture_2();
  fermeture_2();
  delay(60000);
void ouverture_1()
 digitalWrite(IN1,HIGH);
 delay(8300);
 digitalWrite(IN1,LOW);
 delay(2000);
void fermeture_1()
 digitalWrite(IN4,HIGH);
 delay(8500);
 digitalWrite(IN4,LOW);
void ouverture_2()
 digitalWrite(IN3,HIGH);
 delay(8930);
 digitalWrite(IN3,LOW);
 delay(2000);
void fermeture_2()
 digitalWrite(IN2,HIGH);
 delay(8850);
 digitalWrite(IN2,LOW);
the same with the LED (who doesn't work)
//MOTEUR A
//MOTEUR B
//LED
const int LEDpin=13;                 // déclaration de la constante de broche, ici c'est la broche 13
int EtatLED = LOW;                   // variable utilisée pour connaître l'état de la led
long Millisprecedentes = 0;          // variable servant à gérer le clignotement
long intervalle = 50;                // intervalle de clignotement
 pinMode(LEDpin,OUTPUT);             //déclaration du type de connexion utilisé pour la LED, ici une sortie (output) reliée à la broche n°12
 pinMode(ENA,OUTPUT);                //Configurer les broches comme sorties
  // Moteur A
  // Moteur B
  ouverture_1();
  fermeture_1();
  delay(10000);
  ouverture_2();
  fermeture_2();
  delay(60000);
void ouverture_1()
 if(IN1=HIGH)
    unsigned long Millisactuelles = millis();
    if(Millisactuelles - Millisprecedentes > intervalle)
    Millisprecedentes = Millisactuelles;   // sauvegarder le temps écoulé depuis le dernier clignotement
    if (EtatLED == LOW)                    // si la led est éteinte, l'allumer ou vice-versa
      EtatLED = HIGH;
      EtatLED = LOW;
 delay(8250);
 delay(2000);
void fermeture_1()
 if(IN4=HIGH)
      EtatLED = HIGH;
      EtatLED = LOW;
 delay(8500);
void ouverture_2()
 if(IN3=HIGH)
      EtatLED = HIGH;
      EtatLED = LOW;
 delay(8930);
 delay(2000);
void fermeture_2()
 if(IN2=HIGH)
      EtatLED = HIGH;
      EtatLED = LOW;
 delay(8850);
Somebody can help me please?
thanks
Clément
Post a drawing of all the wiring.
Perhaps you have the LED wired backwards, or it has already been destroyed by too much current, or backwards wiring.
The LED is functional, I think this is the "delay" that make it not working . but I do not know how to replace them , and I already have a function " millis " ...
I can not see in your code where you ever write the LED state to the LED pin.
digitalWrite(LEDpin, EtatLED)
