Salve a tutti,
Vi illustro il mio problema:
Dovrei collegare una cella di carico da 10kg a ponte di wheatstone da 10V massimo 15V.
Per il momento sto usando questo schema con l'unica differenza che non uso i 5v di arduino ma 12v da un alimentatore a muro, la resistenza di gain è da 10ohm.
E lo sketch è questo:
// Arduino as load cell amplifier
// by Christian Liljedahl
// christian.liljedahl.dk
// Load cells are linear. So once you have established two data pairs, you can interpolate the rest.
// Step 1: Upload this sketch to your arduino board
// You need two loads of well know weight. In this example A = 10 kg. B = 30 kg
// Put on load A
// read the analog value showing (this is analogvalA)
// put on load B
// read the analog value B
// Enter you own analog values here
float loadA = 1; // kg
int analogvalA = 200; // analog reading taken with load A on the load cell
float loadB = 10; // kg
int analogvalB = 600; // analog reading taken with load B on the load cell
// Upload the sketch again, and confirm, that the kilo-reading from the serial output now is correct, using your known loads
float analogValueAverage = 0;
// How often do we do readings?
long time = 0; //
int timeBetweenReadings = 200; // We want a reading every 200 ms;
int analogValue = analogRead(0);
// running average - We smooth the readings a little bit
analogValueAverage = 0.99*analogValueAverage + 0.01*analogValue;
// Is it time to print?
if(millis() > time + timeBetweenReadings){
float load = analogToLoad(analogValueAverage);
Serial.print("analogValue: ");Serial.println(analogValueAverage);
Serial.print(" load: ");Serial.println(load,5);
time = millis();
float analogToLoad(float analogval){
// using a custom map-function, because the standard arduino map function only uses int
float load = mapfloat(analogval, analogvalA, analogvalB, loadA, loadB);
return load;
float mapfloat(float x, float in_min, float in_max, float out_min, float out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Nonostante tutto è collegato perfettamente e leggo un valore, quest'ultimo non cambia se faccio pressione sulla cella di carico, ho provato altri schemi e sketch diversi ma nessuno ha funzionato,
Il datasheet della cella di carico è questo:
Qualcuno ha qualche consiglio da darmi?
Grazie a tutti dell'attenzione ![]()
