Upload fails: 'avrdude: ser_open(): can't open device "\.\COM9"'
Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM9 -b115200 -D -Uflash:w:C:\Users\user\AppData\Local\Temp\arduino_build_97673/SIK_Circuit_1A-Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM9
An error occurred while uploading the sketch
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "\.\COM9": The system cannot find the file specified.
avrdude done. Thank you.
option enabled in File -> Preferences.
i have a problem in uploading the sketch
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 940 bytes (2%) of program storage space. Maximum is 32256 bytes.
C:\Users\Dell\Desktop\arduino-1.8.5\hardware\tools\avr/bin/avrdude -CC:\Users\Dell\Desktop\arduino-1.8.5\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\Dell\AppData\Local\Temp\arduino_build_742949/blinking_led.ino.hex:i
System wide configuration file is "C:\Users\Dell\Desktop\arduino-1.8.5\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM1
avrdude: ser_open(): can't open device "\.\COM1": The system cannot find the file specified.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
skand_tripathi:
Select the port of your Arduino from the Tools > Port menu. If that menu is grayed out or the port of your Arduino board is not shown then one of the following may be the cause:
  • You may need to install the driver for the USB-serial chip on your Arduino. Determine which chip is used on your Arduino and install the driver.
  • You may be using a charge-only or defective USB cable. Test your cable on another device to confirm that it works for data.
  • Using a USB 3.0 port on your computer may cause problems. Try a USB 2.0 port or use a USB 2.0 hub plugged into your USB 3.0 port.
    a
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
sir i am getting the error while i tried to upload the empty loops to reset my arduino board.
pnkz:
Sketch uses 938 bytes (2%) of program storage space. Maximum is 32256 bytes.
avrdude: ser_open(): can't open device "\.\COM4": The system cannot find the file specified.
// this is my error
@mike12345
Are you using USB 2.0 or 3.0 ports and cables as Arduinos can be very hit and miss with USB 3.0 ?
Changing cables and ports is always a first stop in troubleshooting.
pert:
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the upload fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
it'll be great if i could get some help too
< Arduino: 1.8.7 (Mac OS X), Board: "Arduino/Genuino Uno"
Sketch uses 4300 bytes (13%) of program storage space. Maximum is 32256 bytes.
Global variables use 239 bytes (11%) of dynamic memory, leaving 1809 bytes for local variables. Maximum is 2048 bytes.
/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem1421 -b115200 -D -Uflash:w:/var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch_dec15a.ino.hex:i
avrdude: Version 6.3-20171130
System wide configuration file is "/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/ifrahs/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem1421
avrdude: ser_open(): can't open device "/dev/cu.usbmodem1421": No such file or directory
i'm using a DHT11 humidity sensor, my cable works as i have tried before i just have no idea why its giving me errors
i posted a query earlier with error message from " file>preferences>upload(checked)"
this is with 'compilation (checked)'
/Applications/Arduino 2.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino 2.app/Contents/Java/hardware -tools /Applications/Arduino 2.app/Contents/Java/tools-builder -tools /Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino 2.app/Contents/Java/libraries -libraries /Users/ifrahs/Documents/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10807 -build-path /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303 -warnings=none -build-cache /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_cache_725994 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -verbose /Users/ifrahs/Documents/Arduino/sketch_dec15a/sketch_dec15a.ino
/Applications/Arduino 2.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino 2.app/Contents/Java/hardware -tools /Applications/Arduino 2.app/Contents/Java/tools-builder -tools /Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino 2.app/Contents/Java/libraries -libraries /Users/ifrahs/Documents/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10807 -build-path /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303 -warnings=none -build-cache /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_cache_725994 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -verbose /Users/ifrahs/Documents/Arduino/sketch_dec15a/sketch_dec15a.ino
Using board 'uno' from platform in folder: /Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr
Using core 'arduino' from platform in folder: /Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr
Detecting libraries used...
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/variants/standard" /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch/sketch_dec15a.ino.cpp -o /dev/null
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/variants/standard" -I/Users/ifrahs/Documents/Arduino/libraries/DHTLib /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch/sketch_dec15a.ino.cpp -o /dev/null
Using cached library dependencies for file: /Users/ifrahs/Documents/Arduino/libraries/DHTLib/dht.cpp
Generating function prototypes...
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/variants/standard" -I/Users/ifrahs/Documents/Arduino/libraries/DHTLib /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch/sketch_dec15a.ino.cpp -o /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/preproc/ctags_target_for_gcc_minus_e.cpp
"/Applications/Arduino 2.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/variants/standard" -I/Users/ifrahs/Documents/Arduino/libraries/DHTLib /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch/sketch_dec15a.ino.cpp -o /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch/sketch_dec15a.ino.cpp.o
Compiling libraries...
Compiling library "DHTLib"
Using previously compiled file: /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/libraries/DHTLib/dht.cpp.o
Compiling core...
Using precompiled core: /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_cache_725994/core/core_arduino_avr_uno_a44201f00637cc7de5d2873b25582122.a
Linking everything together...
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch_dec15a.ino.elf /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch/sketch_dec15a.ino.cpp.o /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/libraries/DHTLib/dht.cpp.o /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/../arduino_cache_725994/core/core_arduino_avr_uno_a44201f00637cc7de5d2873b25582122.a -L/var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303 -lm
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch_dec15a.ino.elf /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch_dec15a.ino.eep
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy" -O ihex -R .eeprom /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch_dec15a.ino.elf /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch_dec15a.ino.hex
Using library DHTLib in folder: /Users/ifrahs/Documents/Arduino/libraries/DHTLib (legacy)
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-size" -A /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch_dec15a.ino.elf
SEND HELP
i'm heckin lost please help
Sketch uses 1806 bytes (5%) of program storage space. Maximum is 32256 bytes.
Global variables use 51 bytes (2%) of dynamic memory, leaving 1997 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\Isaac\AppData\Local\Temp\arduino_build_127520/Slots_test.ino.hex:i
         Using Port                    : COM4
avrdude: ser_open(): can't open device "\\.\COM4": The system cannot find the file specified.
ThePyroManiac:
SEND HELP
Using Port                    : COM4
Incorrect port selected. Select a port from tools -> port menu; it's got COM4 selected (which presumably you used previously), but it's saying that there is no COM4. Windows will often assign a different port number depending on which USB port a device is plugged into (and occasionally for no apparent reason), so you just need to select the correct port.
<Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
Build options changed, rebuilding all
Sketch uses 3316 bytes (10%) of program storage space. Maximum is 32256 bytes.
Global variables use 198 bytes (9%) of dynamic memory, leaving 1850 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\HP\AppData\Local\Temp\arduino_build_925352/task3.ino.ino.hex:i
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\HP\AppData\Local\Temp\arduino_build_925352/task3.ino.ino.hex"
avrdude: writing flash (3316 bytes):
Writing | ################################################## | 100% 0.54s
avrdude: 3316 bytes of flash written
avrdude: verifying flash memory against C:\Users\HP\AppData\Local\Temp\arduino_build_925352/task3.ino.ino.hex:
avrdude: load data flash data from input file C:\Users\HP\AppData\Local\Temp\arduino_build_925352/task3.ino.ino.hex:
avrdude: input file C:\Users\HP\AppData\Local\Temp\arduino_build_925352/task3.ino.ino.hex contains 3316 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.42s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0x62 != 0x0c
avrdude: verification error; content mismatch
the selected serial port avrdude done. Thank you.
does not exist or your board is not connected
Sketch uses 3164 bytes (9%) of program storage space. Maximum is 32256 bytes.
Global variables use 200 bytes (9%) of dynamic memory, leaving 1848 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\HP\AppData\Local\Temp\arduino_build_313488/usonic1.ino.hex:i
Using Port : COM5
avrdude: ser_open(): can't open device "\.\COM5": The system cannot find the file specified.
Arduino: 1.8.9 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\user\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10809 -build-path C:\Users\user\AppData\Local\Temp\arduino_build_280739 -warnings=none -build-cache C:\Users\user\AppData\Local\Temp\arduino_cache_684087 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\02.Digital\BlinkWithoutDelay\BlinkWithoutDelay.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\user\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10809 -build-path C:\Users\user\AppData\Local\Temp\arduino_build_280739 -warnings=none -build-cache C:\Users\user\AppData\Local\Temp\arduino_cache_684087 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\02.Digital\BlinkWithoutDelay\BlinkWithoutDelay.ino
Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\user\AppData\Local\Temp\arduino_build_280739\sketch\BlinkWithoutDelay.ino.cpp" -o nul
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\user\AppData\Local\Temp\arduino_build_280739\sketch\BlinkWithoutDelay.ino.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_280739\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\user\AppData\Local\Temp\arduino_build_280739\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\user\AppData\Local\Temp\arduino_build_280739\sketch\BlinkWithoutDelay.ino.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_280739\sketch\BlinkWithoutDelay.ino.cpp.o"
Compiling core...
Using precompiled core: C:\Users\user\AppData\Local\Temp\arduino_cache_684087\core\core_arduino_avr_nano_cpu_atmega328_0c812875ac70eb4a9b385d8fb077f54c.a
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\user\AppData\Local\Temp\arduino_build_280739/BlinkWithoutDelay.ino.elf" "C:\Users\user\AppData\Local\Temp\arduino_build_280739\sketch\BlinkWithoutDelay.ino.cpp.o" "C:\Users\user\AppData\Local\Temp\arduino_build_280739/..\arduino_cache_684087\core\core_arduino_avr_nano_cpu_atmega328_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\user\AppData\Local\Temp\arduino_build_280739" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\user\AppData\Local\Temp\arduino_build_280739/BlinkWithoutDelay.ino.elf" "C:\Users\user\AppData\Local\Temp\arduino_build_280739/BlinkWithoutDelay.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\user\AppData\Local\Temp\arduino_build_280739/BlinkWithoutDelay.ino.elf" "C:\Users\user\AppData\Local\Temp\arduino_build_280739/BlinkWithoutDelay.ino.hex"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-size" -A "C:\Users\user\AppData\Local\Temp\arduino_build_280739/BlinkWithoutDelay.ino.elf"
Sketch uses 858 bytes (2%) of program storage space. Maximum is 30720 bytes.
Global variables use 15 bytes (0%) of dynamic memory, leaving 2033 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\user\AppData\Local\Temp\arduino_build_280739/BlinkWithoutDelay.ino.hex:i
Using Port : COM4
pranayar:
Select the COM port of your Nano from the Arduino IDE's Tools > Port menu.
If you don’t know which port is your Arduino, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM9 -b115200 -D -Uflash:w:C:\Users\Robert\AppData\Local\Temp\arduino_build_615160/Blink.ino.hex:i
Using Port : COM9
ABRobert:
avrdude: ser_open(): can't open device "\\.\COM9": The system cannot find the file specified.
You need to select the port of your Arduino board from the Tools > Port menu. If you find multiple ports in the menu and don't know which is the Arduino, Try this:
  • With the Arduino board unplugged from the USB open the Tools > Port menu and note the listed ports. If the Port menu is gray and disabled then that means there are no ports available.
  • Close the Tools > Port menu.
  • Plug in the USB cable on the Arduino board
  • Wait a little while for the Arduino board to connect
  • Open Tools > Port, the new port on the list is your Arduino board. In some cases it will have the name of the board next to the port name but this doesn't happen with all boards. If the Port menu is gray and disabled then that means your Arduino board didn't install correctly. You may need to install a driver.
  • Select your Arduino's port from the menu.
Arduino: 1.8.10 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 882 bytes (2%) of program storage space. Maximum is 32256 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\user\AppData\Local\Temp\arduino_build_331621/sketch_jan17a.ino.hex:i
avrdude: Version 6.3-20190619
Using Port : COM5
avrdude: ser_open(): can't open device "\.\COM5": The semaphore timeout period has expired.
