Buonasera a tutti,
Ho un problema con la striscia led ws2812 e il mio arduino uno r3
Innanzitutto il codice e' questo:
#define PIN A5
#define lightCount 300
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_RGB Pixels are wired for RGB bitstream
// NEO_GRB Pixels are wired for GRB bitstream
// NEO_HZ400 400 KHz bitstream (e.g. FLORA pixels)
// NEO_KHZ800 800 KHz bitstream (e.g. High Density LED strip)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(300, PIN, NEO_GRB + NEO_KHZ800);
//fadeThickness = 0; // CHANGE THICKNESS (0-10)
int vol = 0;
float total = 0;
int fadeCol = 0;
int val[25];
int volLast = 0;
int fadeAmt = 0;
int counter = 0;
strip.begin();
strip.show(); // Initialize all pixels to 'off'
//Serial.begin(9600);
fadeCol = 0;
total = 0;
for (int i = 0; i < 80; i++){
counter = 0;
do{
vol = analogRead(A0);
counter = counter + 1;
if (counter > 500){
rainbowCycle(10);
}while (vol == 0);
total = total + vol;
vol = total / 80;
// Serial.println(vol);
vol = map(vol,20,255,0,20);
if (volLast > vol) {
vol = volLast - 4;
volLast = vol;
fadeAmt = 0;
// Serial.print(vol);
for (int i = 0; i<25;i++){
if (i < vol){
strip.setPixelColor((i+25), strip.Color(0,255,0));
strip.setPixelColor((25-i), strip.Color(0,255,0));
else if (i < (vol + 8)) {
strip.setPixelColor((i+25), strip.Color(255,0,0));
strip.setPixelColor((25-i), strip.Color(255,0,0));
strip.setPixelColor((i+25), strip.Color(0,0,255));
strip.setPixelColor((25-i), strip.Color(0,0,255));
strip.show();
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
if (vol> 10) {
return;
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
La mia striscia e' da 300 led e di conseguenza ho messo 300 nel codice ma stranamente si illuminano solo i primi 49 led.. ed e' questo il problema.
Per il resto l'effetto che deve fare lo fa tranquillamente ma solo in questi primi led.
L'effetto che voglio e' il seguente del video: ws2812 led strip to music with arduino
Inoltre all'inizio del video si vede l'effetto del comando fadein e fadeout che nel codice non c'e' e non so dove inserirlo. Principalmente pero' mi interessa avere tutti i led funzionanti.
Altre informazioni sono:
-Alimentazione con batteria esterna a 5v e max 4.8A. (Negli esempi degli sketch tutto funziona regolare quindi non penso sia un problema di alimentazione)
-Condensatore 1000 microfarad 25v
-Tra il pin A5 e il data input della striscia ho messo una resistenza da 330ohm
Grazie mille anticipatamente per l'aiuto
