problema termostato wifi
codice trasmittente
#include <VirtualWire.h>;
const short sensore=0;
int temp=0;
    Serial.begin(9600);	// inizializa monitor seriale
    // Inizializza trasmettitore
    vw_setup(2000);	 // Bits per sec
    vw_rx_start();       // Start the receiver PLL running
temp=(analogRead(sensore)*5/1023.0*100);
delay(10);
Serial.print("temperatura ");
Serial.print(temp);
Serial.print(" ");
     char msg[10] = "";                     //variabile di char
    itoa (temp,msg,10);
    Serial.println(msg);
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    digitalWrite(13, true); // Flash led 13 quando trasmetti
    vw_send((uint8_t *)msg, strlen(msg));
    vw_wait_tx(); // Wait until the whole message is gone
    Serial.println("Sent");
    digitalWrite(13, false);
    // Wait at most 200ms for a reply
    if (vw_wait_rx_max(200))
	if (vw_get_message(buf, &buflen)) // Non-blocking
	    int i;
	    // Message with a good checksum received, dump it.
	    Serial.print("Got: ");
	    for (i = 0; i < buflen; i++)
		Serial.print(buf[i], HEX);
		Serial.print(" ");
	    Serial.println("");
	Serial.println("Timout");
delay(5000);
codice ricevente
#include <LiquidCrystal.h>
int temperaturaimpostata=62;
int temperaturaeffetiva=0;
#define rele1 9
#define rele2 8
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
const int timeout = 5100;              // 5 sec.              fuori dal looop()
unsigned long millisTime=0;            //                        fuori dal looop()
  pinMode(rele1, OUTPUT);
  pinMode(rele2, OUTPUT);
  pinMode(12, INPUT);//pulsante aumento temp.impostata
  pinMode(10, INPUT);//pulsante diminuzione temp. impostata
  lcd.begin(16, 2);
  lcd.setCursor(0, 0);
  lcd.print("Temp. Impo:");
  lcd.setCursor(0,1);
  lcd.print("Temp. Effe:");
  digitalWrite(rele1, LOW);
  digitalWrite(rele2, HIGH);
   if(digitalRead(12)==HIGH)
     temperaturaimpostata=temperaturaimpostata+1;
   if(digitalRead(10)==HIGH)
     temperaturaimpostata=temperaturaimpostata-1;
   lcd.setCursor(12, 0);
  lcd.print(temperaturaimpostata);
    // Wait for a message
       millisTime = millis();
	int i;
	const char *msg = "prova";
        digitalWrite(13, true); // Flash a light to show received good message
char buffer[10] = "";
   	for (i = 0; i < buflen; i++) {
            buffer[i]=(buf[i]);
  temperaturaeffetiva = atoi(buffer);
  lcd.setCursor(12,1);
           lcd.print("    ");
           lcd.print(buffer);
          Serial.print(buffer);
          Serial.println(" ");
	// Send a reply
    else{
     if( millis() > millisTime + timeout ) {
       digitalWrite(rele2, LOW);//qui fai la segnalazione allarme
       Serial.println("MANCA SEGNALE");
     if (temperaturaeffetiva >= temperaturaimpostata)
       digitalWrite(rele1, HIGH);
     else if(temperaturaeffetiva <=(temperaturaimpostata-2))
  delay(200);
Allora attualmente ogni 11 ricezioni mi accende il rele2 per una frazione di secondo..
cmq io avevo bisogno che se non riceve il segnale per un qualsiasi motivo ( ma non una cosa immediata anche magari dopo un tempo di alcuni minuti) mi poerta il rele 2 in LOW e quando riceve il segnale il rele2 sia in posizione HIGH...
Spero di essermi spiegato...
Nessuno ha consigli?
Non so come fare...
in teoria è quello che dovrebbe fare.
non capisco da dove escano le 11 ricezioni :relaxed:
mi pare che la sonda trasmette più o meno ogni 5 sec, per cui il tempo di timeout nel ricevitore devi portarlo almeno a 15-20 sec. altrimenti è molto probabile che gli allarmi di mancata ricezione arrivino più o meno ad ogni trasmissione
Le undici ricezioni sono circa 55 secondi non capisco perche ma ciclicamente mi accende il rele2 per una frazione di secondo...
lo avevo messo a 20 secondi ma mi faceva aggiornamento temperatura ogni 20 seondi...
praticamente sembrava avere dato un delay 20000...
Il timeout fa fermare il resto delle funzioni di arduino?
