Problemas con max6675 PID y accelstepper
`#include <AccelStepper.h>
#include <MultiStepper.h>
/*    Max6675 Module  ==>   Arduino
 *    CS              ==>     D10
 *    SO              ==>     D12
 *    SCK             ==>     D13
 *    Vcc             ==>     Vcc (5v)
 *    Gnd             ==>     Gnd      */
AccelStepper stepper(1,1,2);
//LCD config (i2c LCD screen, you need to install the LiquidCrystal_I2C if you don't have it )
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4);  //sometimes the adress is not 0x3f. Change to 0x27 if it dosn't work.
/*    i2c LCD Module  ==>   Arduino
 *    SCL             ==>     A5
 *    SDA             ==>     A4
 *    Vcc             ==>     Vcc (5v)
 *    Gnd             ==>     Gnd      */
#include <SPI.h>
//We define the SPI pìns
#define MAX6675_CS   10
#define MAX6675_SO   12
#define MAX6675_SCK  13
//Pins
int PWM_pin = 3;
//Variables
float temperature_read = 0.0;
float set_temperature = 100;
float PID_error = 0;
float previous_error = 0;
float elapsedTime, Time, timePrev;
int PID_value = 0;
unsigned long tiempo2 = 0;
//PID constantsc:\Users\PC producciones\Documents\Arduino\libraries\AccelStepper\examples\Blocking\Blocking.pde
int kp = 9.1;   int ki = 0.3;   int kd = 1.8;
int PID_p = 0;    int PID_i = 0;    int PID_d = 0;
  stepper.setMaxSpeed(100);
  stepper.setAcceleration(20);
  pinMode(PWM_pin,OUTPUT);
  pinMode(POT1,INPUT);
  TCCR2B = TCCR2B & B11111000 | 0x03;    // pin 3 and 11 PWM frequency of 980.39 Hz
  Time = millis();
  lcd.init();
  lcd.backlight();
  stepper.setSpeed(30);
  stepper.runSpeed();
 // First we read the real value of temperature
  temperature_read = readThermocouple();
  //Next we calculate the error between the setpoint and the real value
  PID_error = set_temperature - temperature_read;
  //Calculate the P value
  PID_p = kp * PID_error;
  //Calculate the I value in a range on +-3
  if(-3 < PID_error <3)
    PID_i = PID_i + (ki * PID_error);
  //For derivative we need real time to calculate speed change rate
  timePrev = Time;                            // the previous time is stored before the actual time read
  Time = millis();                            // actual time read
  elapsedTime = (Time - timePrev) / 1000;
  //Now we can calculate the D calue
  PID_d = kd*((PID_error - previous_error)/elapsedTime);
  //Final total PID value is the sum of P + I + D
  PID_value = PID_p + PID_i + PID_d;
  //We define PWM range between 0 and 255
  if(PID_value < 0)
  {    PID_value = 0;    }
  if(PID_value > 255)
  {    PID_value = 255;  }
  //Now we can write the PWM signal to the mosfet on digital pin D3
  analogWrite(PWM_pin,255-PID_value);
  previous_error = PID_error;     //Remember to store the previous error for next loop.
  delay(300);
  //lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("PID TEMP control");
  lcd.setCursor(0,1);
  lcd.print("S:");
  lcd.setCursor(2,1);
  lcd.print(set_temperature,1);
  lcd.setCursor(9,1);
  lcd.print("R:");
  lcd.setCursor(11,1);
  lcd.print(temperature_read,1);
double readThermocouple() {
  uint16_t v;
  pinMode(MAX6675_CS, OUTPUT);
  pinMode(MAX6675_SO, INPUT);
  pinMode(MAX6675_SCK, OUTPUT);
  digitalWrite(MAX6675_CS, LOW);
  delay(1);
  // Read in 16 bits,
  //  15    = 0 always
  //  14..2 = 0.25 degree counts MSB First
  //  2     = 1 if thermocouple is open circuit
  //  1..0  = uninteresting status
  v = shiftIn(MAX6675_SO, MAX6675_SCK, MSBFIRST);
  v <<= 8;
  v |= shiftIn(MAX6675_SO, MAX6675_SCK, MSBFIRST);
  digitalWrite(MAX6675_CS, HIGH);
  if (v & 0x4)
    // Bit 2 indicates if the thermocouple is disconnected
    return NAN;
  // The lower three bits (0,1,2) are discarded status bits
  v >>= 3;
  // The remaining bits are the number of 0.25 degree (C) counts
  return v*0.25;
estaba añadiendo un motor paso a paso a un código ya echo de PID, usando accelstepper el motor no está relacionado con el PID solo quiero que se mueva indefinidamente para jalar filamento, pero usando Setspeed() y cargando el código el motor va entrecortado sin embargo al usar runToNewPosition() el motor se mueve con normalidad.
Ayuda porfa
He trasladado su tema de una categoría de idioma inglés del foro a la categoría International > Español @raikodragon.
En adelante por favor usar la categoría apropiada a la lengua en que queráis publicar. Esto es importante para el uso responsable del foro, y esta explicado aquí la guía "How to get the best out of this forum".
Este guía contiene mucha información útil. Por favor leer.
De antemano, muchas gracias por cooperar.
