Bonjour
J ai installer arduino sur ubuntu 16.04 pas de souci et je viens de l installer sur fedora j ai un message d erreur
Merci pour votre aide ![]()
Copie en texte, pas d'image c'est illisible.
Si tu mets un lien rend le au moins cliquable, il y a une icône pour cela.
Le mieux est un couper coller.
bonjour
desolé mais j ai quand meme reussi a trouver comment copier le message d erreur
Arduino : 1.8.4 (Linux), Carte : "Arduino/Genuino Uno"
Parameter 'tools' is mandatory
Usage of /usr/share/arduino/arduino-builder:
-build-cache string
builds of 'core.a' are saved into this folder to be cached and reused
-build-options-file string
Instead of specifying --hardware, --tools etc every time, you can load all such options from a file
-build-path string
build path
-built-in-libraries value
Specify a built-in 'libraries' folder. These are low priority libraries. Can be added multiple times for specifying multiple built-in 'libraries' folders
-compile
compiles the given sketch
-core-api-version string
version of core APIs (used to populate ARDUINO #define) (default "10600")
-debug-level int
Turns on debugging messages. The higher, the chattier (default 5)
-dump-prefs
dumps build properties used when compiling
-fqbn string
fully qualified board name
-hardware value
Specify a 'hardware' folder. Can be added multiple times for specifying multiple 'hardware' folders
-ide-version string
[deprecated] use 'core-api-version' instead (default "10600")
-libraries value
Specify a 'libraries' folder. Can be added multiple times for specifying multiple 'libraries' folders
-logger string
Sets type of logger. Available values are 'human', 'machine' (default "human")
-prefs value
Specify a custom preference. Can be added multiple times for specifying multiple custom preferences
-preprocess
preprocess the given sketch
-quiet
if 'true' doesn't print any warnings or progress or whatever
-tools value
Specify a 'tools' folder. Can be added multiple times for specifying multiple 'tools' folders
-verbose
if 'true' prints lots of stuff
-version
prints version and exits
-vid-pid string
specify to use vid/pid specific build properties, as defined in boards.txt
-warnings string
Sets warnings level. Available values are 'none', 'default', 'more' and 'all'
Erreur de compilation pour la carte Arduino/Genuino Uno
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
Couper coller du terminal de l'IDE dans la réponse au forum. ![]()
Là je ne vois pas mais en fin de message d'erreur tu peux lire :
Ce rapport pourrait être plus détaillé avec l'option "Afficher les résultats détaillés de la compilation" activée dans Fichier -> Préférences.
Est ce qu'il n'y aurait pas une indication de fichiers introuvables ou manquants.
D'où sort ta version arduino pour Fedora ?
rpm ? tgz ? ou deb modifié en rpm avec alien ?
Elle est installée où ?
Les versions fournies par Arduino sont autonomes, par là je veux dire qu'elles installent tout, peu importe que des versions, même plus récentes, existent déjà dans ta partition usr
En particulier les versions arduino amènent avec elles (dans le répertoire de l'IDE) Java et GCC.
Perso je suis sous Debian.
La version dérivée de Debian, je veux dire (?)Ubuntu étant la version Linux la plus répandue il est possible que les paquets debian (deb) soient les plus débogués.
Alien est très bien pour transformer un paquet deb en rpm et vice versa.
En fait deb ou rpm c'est juste une organisation différentes des fichiers, les exécutables sont les mêmes.
