avr-g++: error: missing filename after '-o'
exit status 1
Erreur lors de la compilation.
Bonjour, j'ai une erreur systématique depuis hier quand je veux compiler un projet, même un projet vide genre
J'ai regardé la trace des messages qui précèdent l'erreur :
Arduino : 1.6.6 (Windows 7), Carte : "Arduino/Genuino Uno"
D:\0\Programmes\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "D:\0\Programmes\Arduino\hardware" -hardware "C:\Users\f\AppData\Local\Arduino15\packages" -tools "D:\0\Programmes\Arduino\tools-builder" -tools "D:\0\Programmes\Arduino\hardware\tools\avr" -tools "C:\Users\f\AppData\Local\Arduino15\packages" -built-in-libraries "D:\0\Programmes\Arduino\libraries" -libraries "D:\Documents\Electronique\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10606 -build-path "C:\Users\f\AppData\Local\Temp\builda671e0fae08368fe1cc5d058096b7527.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "D:\Documents\Electronique\Arduino\test_trash_real\test_trash_real.ino"
D:\0\Programmes\Arduino\arduino-builder -compile -logger=machine -hardware "D:\0\Programmes\Arduino\hardware" -hardware "C:\Users\f\AppData\Local\Arduino15\packages" -tools "D:\0\Programmes\Arduino\tools-builder" -tools "D:\0\Programmes\Arduino\hardware\tools\avr" -tools "C:\Users\f\AppData\Local\Arduino15\packages" -built-in-libraries "D:\0\Programmes\Arduino\libraries" -libraries "D:\Documents\Electronique\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10606 -build-path "C:\Users\f\AppData\Local\Temp\builda671e0fae08368fe1cc5d058096b7527.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "D:\Documents\Electronique\Arduino\test_trash_real\test_trash_real.ino"
"D:\0\Programmes\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -M -MG -MP -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10606 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\f\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.10\cores\arduino" "-IC:\Users\f\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.10\variants\standard" "C:\Users\f\AppData\Local\Temp\builda671e0fae08368fe1cc5d058096b7527.tmp\sketch\test_trash_real.ino.cpp"
"D:\0\Programmes\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10606 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\f\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.10\cores\arduino" "-IC:\Users\f\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.10\variants\standard" "C:\Users\f\AppData\Local\Temp\builda671e0fae08368fe1cc5d058096b7527.tmp\sketch\test_trash_real.ino.cpp" -o ""
exit status 1
C'est vraiment tout à la fin que ça merdouille, à la fin de la dernière grande ligne, effectivement après le -o (qui correspond à un outfile, j'ai regardé la doc du compilateur) il y a des guillemets vides.
C'est bizarre j'ai l'impression que c'est venu comme ça sans rien avant. J'ai juste lancé CoolTerm pour enregistrer le port série mais j'ai l'impression que cela n'a rien à voir.
Evidemment la désinstallation et réinstallation de Arduino IDE n'a pas aidé.
Merci !
