Hey there,
I have a problem using the TB6612FNG motor controller with arduino nano.
By using the instructions provided by sparkfun (TB6612FNG Hookup Guide - SparkFun Learn), I am able to control the motors, but not their speed.
I am using the serial monitor to send commands to activate a certain motor, with a certain speed. Unfortunately the motor only starts turning if I give 255, or -255 as an input.
Here is my code (you can ignore servo 1-3, they are working just fine):
#include <Servo.h>
#include <SparkFun_TB6612.h>
const unsigned int MAX_MESSAGE_LENGTH = 12;
//initialize the servos
Servo servo1;
Servo servo2;
Servo servo3;
//initialize all the servo info
String readString; //main captured String
int pos = 0;
String servo_id;
String servo_angle;
//locations of the , in the message
int ind1;
int ind2;
int ind3;
//initialize paremeters for stirrer and pump control
// these constants are used to allow you to make your motor configuration
// line up with function names like forward. Value can be 1 or -1
const int offsetA = 1;
const int offsetB = 1;
// Pins for all inputs, keep in mind the PWM defines must be on PWM pins
#define AIN1 2
#define BIN1 7
#define AIN2 4
#define BIN2 8
#define PWMA 9
#define PWMB 10
#define STBY 11
// Initializing motors. The library will allow you to initialize as many
// motors as you have memory for. If you are using functions like forward
// that take 2 motors as arguements you can either write new functions or
// call the function more than once.
Motor motor1 = Motor(AIN1, AIN2, PWMA, offsetA, STBY);
Motor motor2 = Motor(BIN1, BIN2, PWMB, offsetB, STBY);
servo1.attach(3);
servo2.attach(5);
servo3.attach(6);
//Check to see if anything is available in the serial receive buffer
while (Serial.available() > 0)
//Create a place to hold the incoming message
static char message[MAX_MESSAGE_LENGTH];
static unsigned int message_pos = 0;
//Read the next available byte in the serial receive buffer
char inByte = Serial.read();
//Message coming in (check not terminating character) and guard for over message size
if ( inByte != '\n' && (message_pos < MAX_MESSAGE_LENGTH - 1) )
//Add the incoming byte to our message
message[message_pos] = inByte;
message_pos++;
//Full message received...
//Add null character to string
message[message_pos] = '\0';
//Print the message (or do other things)
Serial.println(message);
//Or convert to integer and print
int number = atoi(message);
int servo_id = atoi(strtok(message, ","));
int servo_angle = atof(strtok(NULL, ","));
int motor_speed = atof(strtok(NULL, ","));
//Serial.println(number);
Serial.print("servo_id = ");
Serial.println(servo_id);
Serial.print("servo_angle = ");
Serial.println(servo_angle);
Serial.print("motor_speed = ");
Serial.println(motor_speed);
//Reset for the next message
message_pos = 0;
// execute motor functions
if (servo_id==1){
servo1.write(servo_angle);
Serial.println("Changing servo1 position");
else if (servo_id==2) {
servo2.write(servo_angle);
Serial.println("Changing servo2 position");
else if (servo_id==3) {
servo3.write(servo_angle);
Serial.println("Changing servo3 position");
else if (servo_id==4) {
//Use of the drive function which takes as arguements the speed
//and optional duration. A negative speed will cause it to go
//backwards. Speed can be from -255 to 255(servo_angle). Also use of the
//brake function which takes no arguements.
if (servo_angle==0) {
motor1.brake();
else {
motor1.drive(servo_angle,1000);
else if (servo_id==5) {
motor2.brake();
else {
motor2.drive(servo_angle);
else {
Serial.println("No motor logic here");
//int move_servo(){
// servo1.write(angle)
and here is the wiring diagram i drew:
I am banging my head against a wall for two days now and I am unable to solve this, so help is really appreaciated!
