Hello everyone! ![]()
I have some problems with my code. I'm using xbee modules (Xbee S2C) to get wireless comunication between a computer program and my arduino. I'm using v1 and v0 as variables to on and off a valve connected to the Arduino and then get data from flow sensor. After upload the project, arduino responds great to the command 'v1' (valve opened) and then 'v0' (valve closed), but after that, arduino doesn't respond anymore to the commands :o , they only work the first time when I upload the sketch or reboot the arduino. I think it could be a problem with interrupts, but I'm not sure. Thanks in advance for your help
, I'm using an Arduino UNO. Here's the code:
#include <SoftwareSerial.h>
#include <XBee.h>
#define ssRX 10 /* Rx pin for software serial */
#define ssTX 11 /* Tx pin for software serial */
SoftwareSerial xbee_ss(ssRX, ssTX); //RX,TX
volatile int numPulsos;
int pinSensor = 2;Â Â //Flow sensor connected to pin 2
int cuenta = 0;
float factorConversion = 7.5; //
float volumen = 0, caudal_L_m = 0;
const int valvula =Â 13;
long dt = 0;
long t0 = 0;
uint8_t bytes[sizeof(float)];
XBee xbee = XBee();
uint8_t payload_1[] = {0, 0};
uint8_t payload_2[] = {0, 0};
char comando[] = {' ',' '};
//Xbee coordinator address
XBeeAddress64 addr64 = XBeeAddress64(0x00000000, 0x00000000);
//Create objects to transmit payload
ZBTxRequest zbTx_1 = ZBTxRequest(addr64, payload_1, sizeof(payload_1));
ZBTxRequest zbTx_2 = ZBTxRequest(addr64, payload_2, sizeof(payload_2));
//Create object to get payload
ZBRxResponse rx = ZBRxResponse();
//Get status of payload
ZBTxStatusResponse txStatus = ZBTxStatusResponse();
//---Function during interrupt---------------
void ContarPulsos () {
 numPulsos++;
//---Get pulses frequency--------
int ObtenerFrecuencia() {
 int frecuencia;
 numPulsos = 0;
 interrupts();
 noInterrupts();
 frecuencia = numPulsos;
 return frecuencia;
 xbee_ss.begin(9600);
 xbee.setSerial(xbee_ss);
 pinMode(pinSensor, INPUT);
 pinMode(valvula, OUTPUT);
 attachInterrupt(digitalPinToInterrupt(pinSensor), ContarPulsos, RISING);
void loop () {
Â
 xbee.readPacket(); //read command
 if (xbee.getResponse().isAvailable()){
 Â
  if (xbee.getResponse().getApiId() == ZB_RX_RESPONSE) {
   // got a zb rx packet
   // now fill our zb rx class
   xbee.getResponse().getZBRxResponse(rx);
   for (int i = 0; i < rx.getDataLength(); i++) {
    comando[i] = rx.getData(i);
  Â
   if(comando[0] == 'v' && comando[1] == '1'){
    digitalWrite(valvula, HIGH);
    t0 = millis();
  Â
   if(comando[0] == 'v' && comando[1] == '0'){
    digitalWrite(valvula, LOW);
    volumen = 0;
Â
 if (comando[0] == 'v' && comando[1] == '1'){
 Â
  float frecuencia = ObtenerFrecuencia();
  caudal_L_m = frecuencia / factorConversion; // (L/m)
  dt = millis() - t0; //variación de tiempo
  t0 = millis();
 Â
  volumen += (caudal_L_m / 60) * (dt / 1000); // volumen(L)=caudal(L/s) * time(s)
 Â
  *(float*)(bytes) = volumen; //convert volumen to bytes before send data
 Â
  payload_1[0] = bytes[0];
  payload_1[1] = bytes[1];
  xbee.send(zbTx_1); //payload_1
 Â
  delay(100);
 Â
  payload_2[0] = bytes[2];
  payload_2[1] = bytes[3];
  xbee.send(zbTx_2); //payload_2
 Â
  xbee.readPacket();
 Â
  if (xbee.getResponse().isAvailable()) {
   // got a response!
   if (xbee.getResponse().getApiId() == ZB_TX_STATUS_RESPONSE) {
    xbee.getResponse().getZBTxStatusResponse(txStatus);
Â
    // get the delivery status, the fifth byte
    if (txStatus.getDeliveryStatus() == SUCCESS) {
     Serial.println("Succes!");
     // the remote XBee did not receive our packet. is it powered on?
     Serial.println("Error!");
Arduino_NodeRed.zip (5.96 KB)
