Problems with custom SPI pins for a SD card with ESP32
before submitting my problem to the forum I tried to solve it by googling extensively but, since I'm an old newbie(74), my efforts were unsuccessful.
My problem: I was able to display on a 64x64 RGB LED matrix the data from a BME-280 (temp and hum) and time from a RTC DS3231 connected with an ESP32 using the GPxMatrix library.
However when i tried to add a SD card to save data ( since the system goes to deepsleep for 5 minutes) I found that the only available pins for SPI were pins 33, 34, 35, 21, 2, 0.
In fact pins 18 and 19 are used for I2C connection and all the remaining pins are already used by Led matrix through HUB 75 connection.
In order to avoid any possible conflict with the LED matrix I tried to run the code in a setup without the matrix but using the same pins that are supposed to work with SPI when the led matrix is connected.
Now, by using pin 35 as MISO, Pin 34 as MOSI, Pin 21 as CLK and pin 33 as CS I get on the serial monitor the following error messages
E(108) gpio: GPIO can only be used as input mode
Card Mount Failed
Failed to open file for writing
Failing to open file for appending.
I thought - but may be I'm wrong - that the pin involved in the error message coul be pin 33 ( the CS Pin) but when I tried to use pin 2 or pin 0 as CS pin I got the same result.
Keeping on trying to find whether the problem was in my code or in the hardware I defined custom pins as CLK 25, MISO 34, MOSI 21, CS 33 and the code worked fine and the same happens if I use as custom pins CLK 25, MISO 34, MOSI 26, CS 33.
However if I use for CLK - instead of pin 25 pin 21 or pin 34 - I get the error message Card Mount failed
Pins 34 and 35 are input only.
GPIO 0 might be unpractical as it is a strapping pin. GPIO 2 tends to have the built in LED connected to it.
GPIO 34 & 35 are Input only as stated before. What kind of board are you actually using (link & picture please)
And what (sample) code to manage the SD card ?
Ideally i would avoid GPIO 34 & 35, but if needed then only for MISO (master in slave out)
Probably easiest to use GPIO 0 & 2 for CS & CLK and use 33 / 25 for MISO & MOSI.
Also it may be useful to move something else to the input only pins and free up something.
Hi, thanks for the info.
I'd followed the tutorial of RNT Lab but I must admit that I'd forgotten it because it was some months ago when I tried to enter this fascinating world of microcontrollers.
I'll read carefully again
after many faulty attempts, at the end I was able use a SD card with the following custom pins : PIN_CLK 0 PIN_MISO 34 PIN_MOSI_21 PIN_CS 33 ( that seems to be the only working combination). Here is the code ( it has also a couple of images ( one of them is of my wife)
// ATTENTION REMEMBER TO USE THE I2C PINS SDA 18 AND  SCL 19
#include <SPI.h> //for the SD card
#include "FS.h"
#include <SD.h>
#include <Wire.h>
#define I2C_SDA 18
#define I2C_SCL 19
TwoWire I2Cbus(0); // Create a new I2C bus object
#define Wire I2Cbus
#include <RTClib.h> // for the RTC
RTC_DS3231 rtc;
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
TwoWire I2CBME = TwoWire(0);
Adafruit_BME280 bme;
#define PIN_CLK 0
#define PIN_MISO 34
#define PIN_MOSI 21
#define PIN_CS_CARD 33
bool sdOK = false;
#include <GPxMatrix.h>
#define P_A    23
#define P_B    22
#define P_C    5
#define P_D    17
#define P_E    32
#define P_CLK  16
#define P_LAT  4
#define P_OE   15
uint8_t listrgbpins[6] = {25, 26, 27, 14, 12, 13};
GPxMatrix *matrix = new GPxMatrix(P_A, P_B, P_C, P_D, P_E, P_CLK, P_LAT, P_OE, true, 64, listrgbpins);
#define clear()          fillScreen(0)
#define show()           swapBuffers(true)
#define Color(x,y,z)     Color888(x,y,z)
// Define matrix width and height.
#define mw 64  // original was 128
#define mh 64
#define LED_BLACK           0
#define LED_RED_VERYLOW    (3 <<  11)
#define LED_RED_LOW        (7 <<  11)
#define LED_RED_MEDIUM     (15 << 11)
#define LED_RED_HIGH       (31 << 11)
#define LED_GREEN_VERYLOW  (1 <<  5)
#define LED_GREEN_LOW      (15 << 5)
#define LED_GREEN_MEDIUM   (31 << 5)
#define LED_GREEN_HIGH     (63 << 5)
#define LED_BLUE_VERYLOW     3
#define LED_BLUE_LOW         7
#define LED_BLUE_MEDIUM     15
#define LED_BLUE_HIGH       31
#define LED_ORANGE_VERYLOW (LED_RED_VERYLOW + LED_GREEN_VERYLOW)
#define LED_ORANGE_LOW     (LED_RED_LOW     + LED_GREEN_LOW)
#define LED_ORANGE_MEDIUM  (LED_RED_MEDIUM  + LED_GREEN_MEDIUM)
#define LED_ORANGE_HIGH    (LED_RED_HIGH    + LED_GREEN_HIGH)
#define LED_PURPLE_VERYLOW (LED_RED_VERYLOW + LED_BLUE_VERYLOW)
#define LED_PURPLE_LOW     (LED_RED_LOW     + LED_BLUE_LOW)
#define LED_PURPLE_MEDIUM  (LED_RED_MEDIUM  + LED_BLUE_MEDIUM)
#define LED_PURPLE_HIGH    (LED_RED_HIGH    + LED_BLUE_HIGH)
#define LED_CYAN_VERYLOW   (LED_GREEN_VERYLOW + LED_BLUE_VERYLOW)
#define LED_CYAN_LOW       (LED_GREEN_LOW     + LED_BLUE_LOW)
#define LED_CYAN_MEDIUM    (LED_GREEN_MEDIUM  + LED_BLUE_MEDIUM)
#define LED_CYAN_HIGH      (LED_GREEN_HIGH    + LED_BLUE_HIGH)
#define LED_WHITE_VERYLOW  (LED_RED_VERYLOW + LED_GREEN_VERYLOW + LED_BLUE_VERYLOW)
#define LED_WHITE_LOW      (LED_RED_LOW     + LED_GREEN_LOW     + LED_BLUE_LOW)
#define LED_WHITE_MEDIUM   (LED_RED_MEDIUM  + LED_GREEN_MEDIUM  + LED_BLUE_MEDIUM)
#define LED_WHITE_HIGH     (LED_RED_HIGH    + LED_GREEN_HIGH    + LED_BLUE_HIGH)
#define LED_YELLOW_MEDIUM  (LED_RED_LOW  + LED_GREEN_MEDIUM)
#define LED_YELLOW_HIGH    (LED_RED_LOW  + LED_GREEN_HIGH)
void fixdrawRGBBitmap(int16_t x, int16_t y, const uint16_t *bitmap, int16_t w, int16_t h) {
 // Convert a BGR 4/4/4 bitmap to RGB 5/6/5 used by Adafruit_GFX
   uint16_t RGB_bmp_fixed[w * h];
    for (uint16_t pixel=0; pixel<w*h; pixel++) {
        uint8_t r,g,b;
        uint16_t color = pgm_read_word(bitmap + pixel);
        //Serial.print(color, HEX);
        b = (color & 0xF00) >> 8;
        g = (color & 0x0F0) >> 4;
        r = color & 0x00F;
        //Serial.print(" ");
        //Serial.print(b);
        //Serial.print("/");
        //Serial.print(g);
        //Serial.print(r);
        //Serial.print(" -> ");
        // expand from 4/4/4 bits per color to 5/6/5
        b = map(b, 0, 15, 0, 31);
        g = map(g, 0, 15, 0, 63);
        r = map(r, 0, 15, 0, 31);
        //Serial.print(r);
        //Serial.print(g);
        //Serial.print(b);
        RGB_bmp_fixed[pixel] = (r << 11) + (g << 5) + b;
        //Serial.println(RGB_bmp_fixed[pixel], HEX);
    matrix->drawRGBBitmap(x, y, RGB_bmp_fixed, w, h);
const unsigned short heart32[1024] PROGMEM={
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF9E7, 0xFA69, 0xF986, 0xF945, 0xF986, 0xF9E7, 0xF9C7, 0xFA28, 0x0000, 0x0000, 0x0000,   // 0x0010 (16) pixels
0x0000, 0x0000, 0x0000, 0xFA28, 0xFA08, 0xF9A6, 0xF986, 0xF965, 0xF9C7, 0xFA08, 0xFA08, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0020 (32) pixels
0x0000, 0x0000, 0x0000, 0xFA69, 0xF9C7, 0xF924, 0xF8C3, 0xF841, 0xF841, 0xF861, 0xF861, 0xF8E3, 0xF945, 0xF9E7, 0x0000, 0x0000,   // 0x0030 (48) pixels
0x0000, 0x0000, 0xF9E7, 0xF945, 0xF8C3, 0xF861, 0xF861, 0xF861, 0xF861, 0xF8C3, 0xF945, 0xF9E7, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0040 (64) pixels
0x0000, 0x0000, 0xF9E7, 0xF9A6, 0xF8C3, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF841, 0xF904, 0xF9E7, 0x0000,   // 0x0050 (80) pixels
0xFA08, 0xF9A6, 0xF8E3, 0xF841, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF841, 0xF8E3, 0xF9A6, 0xFA28, 0x0000, 0x0000,   // 0x0060 (96) pixels
0x0000, 0x0000, 0xF9C7, 0xF8A2, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF8E3, 0xFA08,   // 0x0070 (112) pixels
0xF9C7, 0xF8C3, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8C3, 0xF9E7, 0x0000, 0x0000,   // 0x0080 (128) pixels
0x0000, 0xF9C7, 0xF8E3, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF924,   // 0x0090 (144) pixels
0xF904, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF904, 0xFA28, 0x0000,   // 0x00A0 (160) pixels
0xFA8A, 0xF945, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF841,   // 0x00B0 (176) pixels
0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF861, 0xF986, 0xFACB,   // 0x00C0 (192) pixels
0xF9A6, 0xF8E3, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x00D0 (208) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF924, 0xFA08,   // 0x00E0 (224) pixels
0xF9C7, 0xF841, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x00F0 (240) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8A2, 0xFA08,   // 0x0100 (256) pixels
0xF965, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0110 (272) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF9E7,   // 0x0120 (288) pixels
0xF924, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0130 (304) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF9A6,   // 0x0140 (320) pixels
0xF924, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0150 (336) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF9A6,   // 0x0160 (352) pixels
0xF965, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0170 (368) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF841, 0xF9E7,   // 0x0180 (384) pixels
0xF9E7, 0xF861, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0190 (400) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8C3, 0xFA08,   // 0x01A0 (416) pixels
0xF9A6, 0xF8C3, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x01B0 (432) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF904, 0xFA28,   // 0x01C0 (448) pixels
0xFA28, 0xF924, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x01D0 (464) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF965, 0xFAEB,   // 0x01E0 (480) pixels
0x0000, 0xF9A6, 0xF882, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x01F0 (496) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8C3, 0xFA28, 0x0000,   // 0x0200 (512) pixels
0x0000, 0xFA28, 0xF924, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0210 (528) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF861, 0xF986, 0xFA69, 0x0000,   // 0x0220 (544) pixels
0x0000, 0x0000, 0xF9A6, 0xF8C3, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0230 (560) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF924, 0xFA49, 0x0000, 0x0000,   // 0x0240 (576) pixels
0x0000, 0x0000, 0xFA08, 0xF986, 0xF882, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0250 (592) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8E3, 0xFA08, 0x0000, 0x0000, 0x0000,   // 0x0260 (608) pixels
0x0000, 0x0000, 0x0000, 0xFA69, 0xF965, 0xF882, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0270 (624) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8C3, 0xF9C7, 0xFA69, 0x0000, 0x0000, 0x0000,   // 0x0280 (640) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0xFA08, 0xF945, 0xF861, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0290 (656) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8C3, 0xF9A6, 0xFA49, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02A0 (672) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF9C7, 0xF945, 0xF882, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x02B0 (688) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8C3, 0xF9C7, 0xFA8A, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02C0 (704) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA08, 0xF945, 0xF882, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x02D0 (720) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8C3, 0xF9A6, 0xFAAA, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02E0 (736) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA08, 0xF965, 0xF882, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x02F0 (752) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8E3, 0xF9C7, 0xFA49, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0300 (768) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF9E7, 0xF965, 0xF8A2, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0310 (784) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8E3, 0xF986, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0320 (800) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA49, 0xF986, 0xF8A2, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0330 (816) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF8C3, 0xF9C7, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0340 (832) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA49, 0xF986, 0xF882, 0xF800, 0xF800, 0xF800,   // 0x0350 (848) pixels
0xF800, 0xF800, 0xF800, 0xF8E3, 0xF9A6, 0xFA69, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0360 (864) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF9E7, 0xF965, 0xF861, 0xF800, 0xF800,   // 0x0370 (880) pixels
0xF800, 0xF800, 0xF8C3, 0xF9E7, 0xFACB, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0380 (896) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA28, 0xF945, 0xF841, 0xF800,   // 0x0390 (912) pixels
0xF800, 0xF861, 0xF9A6, 0xFAEB, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03A0 (928) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF9C7, 0xF904, 0xF800,   // 0x03B0 (944) pixels
0xF820, 0xF945, 0xFA28, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03C0 (960) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF9A6, 0xF8C3,   // 0x03D0 (976) pixels
0xF904, 0xF9E7, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03E0 (992) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA69, 0xF9C7,   // 0x03F0 (1008) pixels
0xF9E7, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0400 (1024) pixels
const unsigned short ORNELBIS[4096] PROGMEM={
0xC618, 0xC618, 0xC618, 0xC618, 0xC618, 0xC618, 0xC618, 0xA4F4, 0xB596, 0xBDB7, 0xBDD7, 0xAD35, 0xAD55, 0x8C51, 0x738E, 0x738E,   // 0x0010 (16) pixels
0x9CF3, 0xA514, 0xAD55, 0xAD75, 0xB596, 0xB575, 0xB575, 0xB5B6, 0xB595, 0xBDF7, 0xBDD6, 0xC637, 0xC5F6, 0xBDB6, 0xC5F7, 0xC5F8,   // 0x0020 (32) pixels
0xBD97, 0x9452, 0x83EF, 0x83CF, 0xAD35, 0x6B4D, 0x62EC, 0x8C51, 0x8C10, 0x6B4D, 0x8C30, 0x840F, 0x5A8A, 0x6B4D, 0x39A7, 0x736E,   // 0x0030 (48) pixels
0x6B2D, 0x8C52, 0xB597, 0xB596, 0xAD56, 0xBDD8, 0xBDB7, 0xC5F9, 0xAD15, 0xBDB8, 0xC619, 0xC5F8, 0xC5F9, 0xC619, 0xC618, 0xC618,   // 0x0040 (64) pixels
0xC618, 0xC618, 0xC618, 0xC618, 0xC618, 0xC5F7, 0xC5F7, 0x9CD3, 0x9CD3, 0xB596, 0xAD34, 0xA4D3, 0x7BAF, 0x8C31, 0x736E, 0x6B2C,   // 0x0050 (80) pixels
0xA4D3, 0xB595, 0x94B2, 0x8C51, 0x8410, 0x9CF4, 0xBDF8, 0xC638, 0xC618, 0xC618, 0xC638, 0xBDD7, 0xBDB7, 0x9CB3, 0x8BF0, 0xA4B3,   // 0x0060 (96) pixels
0xA4F3, 0x83CF, 0x6B4C, 0x7B8D, 0x6B2C, 0x62AB, 0x41E7, 0x8C30, 0x83CF, 0x5269, 0x7BAE, 0x83F0, 0x83CF, 0x83AF, 0x734D, 0x9431,   // 0x0070 (112) pixels
0x5A6A, 0x4A09, 0x6B6D, 0x94B2, 0xAD75, 0xAD55, 0xB596, 0xB576, 0xAD35, 0xAD36, 0xAD35, 0xB597, 0xBDD8, 0xC5F9, 0xC5F8, 0xC5F8,   // 0x0080 (128) pixels
0xC618, 0xC618, 0xC618, 0xC618, 0xC618, 0xC5F7, 0xC5F7, 0xBDB6, 0xBDB6, 0xA4F4, 0x83EF, 0x5269, 0x9451, 0x9C72, 0x5A8A, 0x6B0C,   // 0x0090 (144) pixels
0x9C92, 0x4A49, 0x4A49, 0x73AE, 0x9492, 0xAD75, 0xB575, 0xA534, 0x9CB2, 0xA514, 0x7BCF, 0x8C71, 0x83EF, 0x3986, 0x4A08, 0x5249,   // 0x00A0 (160) pixels
0x6B0C, 0x734D, 0x7BAE, 0x4A08, 0x41C7, 0x6B0C, 0x7B8E, 0x6B0C, 0x7B6E, 0x8C31, 0x83F0, 0x734D, 0x62CB, 0x4A08, 0x4A08, 0x8BF0,   // 0x00B0 (176) pixels
0x6B0C, 0x5229, 0x5249, 0x738E, 0x9492, 0x94B3, 0x9CD3, 0x8431, 0x9492, 0x9CD4, 0xB597, 0xBDF8, 0xC5F8, 0xC5F8, 0xC5F9, 0xC5F9,   // 0x00C0 (192) pixels
0xC618, 0xC618, 0xC618, 0xC618, 0xC618, 0xC5F8, 0xBDB6, 0xB575, 0xB575, 0x8C51, 0x528A, 0x6B0C, 0x62CB, 0x6B2C, 0x4A08, 0x7B8E,   // 0x00D0 (208) pixels
0x62EB, 0x2945, 0x2124, 0x31A6, 0x39C6, 0x736C, 0x4A48, 0x5289, 0x7BCE, 0x5ACA, 0x5289, 0x840F, 0x630B, 0x4207, 0x3145, 0x3965,   // 0x00E0 (224) pixels
0x3104, 0x4186, 0x3945, 0x41C7, 0x9C51, 0xC5D7, 0x9C92, 0x6AEC, 0x7B8E, 0x9451, 0x9CB3, 0x62EC, 0x734D, 0x5A8A, 0x3145, 0x49E8,   // 0x00F0 (240) pixels
0x4187, 0x4A08, 0x4A08, 0x4A29, 0x5AAB, 0x6B4D, 0x528B, 0x630C, 0x83F0, 0x83F0, 0xB597, 0xAD76, 0xBDD8, 0xC5F8, 0xC5F8, 0xC5D8,   // 0x0100 (256) pixels
0xC618, 0xC618, 0xC5F8, 0xC618, 0xC618, 0xBDD7, 0xAD34, 0x8C51, 0x8C30, 0x62EB, 0x5AAA, 0x2924, 0x3145, 0x3125, 0x3986, 0x3165,   // 0x0110 (272) pixels
0x5249, 0x39A6, 0x20C3, 0x20E3, 0x3124, 0x4A07, 0x5227, 0x4A27, 0x4A48, 0x4A07, 0x39A5, 0x4A28, 0x62EA, 0x20E3, 0x20C2, 0x20C3,   // 0x0120 (288) pixels
0x20C3, 0x3125, 0x3104, 0x732C, 0xB555, 0x9C92, 0x9451, 0x8C10, 0x8C10, 0xA4F4, 0x9431, 0x9472, 0x62CB, 0x3145, 0x736E, 0x734D,   // 0x0130 (304) pixels
0x2904, 0x3125, 0x6AEC, 0x62AB, 0x5229, 0x5229, 0x5A6A, 0x5229, 0x62AB, 0x83CF, 0xB556, 0xAD56, 0xBDD8, 0xBDF8, 0xBDD8, 0xC5F8,   // 0x0140 (320) pixels
0xC618, 0xC618, 0xC618, 0xC5F8, 0xAD55, 0xB596, 0xB596, 0xC5F7, 0xB575, 0x83EF, 0x7B8E, 0x732C, 0x49C7, 0x3145, 0x3124, 0x3145,   // 0x0150 (336) pixels
0x62AA, 0x62CB, 0x628A, 0x49E7, 0x62AA, 0x49E7, 0x5227, 0x5A48, 0x41A5, 0x41A6, 0x4186, 0x49E7, 0x4A28, 0x2944, 0x20E3, 0x1061,   // 0x0160 (352) pixels
0x1862, 0x1862, 0x3986, 0x7BAE, 0x9C92, 0x6B0C, 0x5ACB, 0x7B8E, 0x8C31, 0x8C51, 0x736D, 0x41A7, 0x5229, 0x3145, 0x83F0, 0x3165,   // 0x0170 (368) pixels
0x20E4, 0x41C7, 0x5A6A, 0x734D, 0x628A, 0x6B0C, 0x6ACB, 0x4186, 0x6ACB, 0x5249, 0x7BAF, 0xA4F4, 0xB597, 0xBDF8, 0xBE18, 0xC619,   // 0x0180 (384) pixels
0xC5F7, 0xC5F7, 0xB575, 0x9CD3, 0x8410, 0xB596, 0xA514, 0x9CB2, 0xA4D2, 0xB575, 0x9430, 0x7B4D, 0x838E, 0xA4B2, 0x9410, 0x83AE,   // 0x0190 (400) pixels
0x734D, 0x83EF, 0xB555, 0xAD34, 0xA4F3, 0x9451, 0x734C, 0x732C, 0x9C92, 0x9C91, 0x8BEF, 0xAD13, 0x5289, 0x41E7, 0x3145, 0x3165,   // 0x01A0 (416) pixels
0x1021, 0x3165, 0x4A08, 0x4A08, 0x736E, 0x5AAA, 0x41C7, 0x5269, 0x5ACB, 0x632C, 0x41C7, 0x4A08, 0x6B2D, 0x7B8E, 0x8C31, 0x3986,   // 0x01B0 (432) pixels
0x4A08, 0x5249, 0x83AF, 0x9472, 0x5A8A, 0x41C7, 0x49E7, 0x62CB, 0x7B6D, 0x5A69, 0x62AB, 0x62AB, 0x9CB4, 0xBDB7, 0xBDD7, 0xC618,   // 0x01C0 (448) pixels
0xBDD7, 0xAD35, 0x9CB2, 0xA4F3, 0x8C50, 0x7BAE, 0x9CD2, 0xB575, 0xAD34, 0x736D, 0x8C10, 0xA4B2, 0xB554, 0x9C91, 0x8C10, 0xB575,   // 0x01D0 (464) pixels
0xBDD6, 0xB595, 0xB5B6, 0x94B2, 0x9CD2, 0x73AE, 0x5AEB, 0x39C7, 0x736D, 0xA4D2, 0xAD33, 0xA512, 0x9CB1, 0x39A6, 0x2904, 0x41C7,   // 0x01E0 (480) pixels
0x28E4, 0x3145, 0x1021, 0x1021, 0x18A3, 0x3166, 0x41E7, 0x41E8, 0x39C7, 0x4A49, 0x3145, 0x20C3, 0x6B0C, 0x83AF, 0x3166, 0x3986,   // 0x01F0 (496) pixels
0x5AAB, 0x8410, 0x5AAA, 0x41E7, 0x2925, 0x2904, 0x3145, 0x62CB, 0x8C10, 0x6AEC, 0x628A, 0x734E, 0x5A8B, 0x9452, 0xAD76, 0xBDF8,   // 0x0200 (512) pixels
0xAD34, 0xA514, 0xA4F3, 0xA513, 0xAD54, 0xB575, 0x9C91, 0xBD95, 0xBD96, 0x83CE, 0x8410, 0xA514, 0x738D, 0x5289, 0x5AAA, 0x62EB,   // 0x0210 (528) pixels
0x9CB2, 0xBDD7, 0xAD34, 0x630B, 0x52CA, 0x2145, 0x2125, 0x2125, 0x0841, 0x1040, 0x3185, 0x5288, 0x5289, 0x5AAA, 0x3145, 0x18A3,   // 0x0220 (544) pixels
0x3986, 0x1882, 0x3145, 0x2904, 0x18A3, 0x1882, 0x2924, 0x39C7, 0x41C7, 0x3166, 0x2904, 0x3145, 0x5AAB, 0x3986, 0x3145, 0x2904,   // 0x0230 (560) pixels
0x5A8A, 0x7BAE, 0x7BAE, 0x62CB, 0x4A08, 0x526A, 0x20C3, 0x39A6, 0x5289, 0x7B8E, 0x5209, 0x4A08, 0x5A6A, 0x7B8F, 0x8C31, 0xAD55,   // 0x0240 (576) pixels
0x8410, 0x9492, 0x9CD2, 0xB595, 0xBDB6, 0xBDD6, 0xA4F3, 0xC5F6, 0xBDD6, 0xAD13, 0x7BAE, 0x41E7, 0x31A6, 0x526A, 0x5AAA, 0x62EB,   // 0x0250 (592) pixels
0x2945, 0x41E7, 0x39A7, 0x2945, 0x18A3, 0x1042, 0x0842, 0x0841, 0x0841, 0x1081, 0x1061, 0x39C6, 0x5ACA, 0x8C0F, 0x5AAA, 0x4A29,   // 0x0260 (608) pixels
0x4208, 0x0820, 0x20E3, 0x39A7, 0x5249, 0x4A28, 0x3986, 0x4A29, 0x39A7, 0x2925, 0x2904, 0x1882, 0x18A3, 0x3145, 0x5269, 0x526A,   // 0x0270 (624) pixels
0x83CF, 0x5AEB, 0x8C31, 0x4A09, 0x41C8, 0x3145, 0x18A3, 0x2924, 0x49E7, 0x5A8A, 0x5249, 0x4A08, 0x5229, 0x83AF, 0x9471, 0x9CD3,   // 0x0280 (640) pixels
0xB576, 0x8410, 0x8C71, 0xBDD6, 0xC5F7, 0xCE38, 0xBDD6, 0xBDB6, 0x9CB2, 0x5AAA, 0x2924, 0x1061, 0x0820, 0x41E8, 0x18A2, 0x1041,   // 0x0290 (656) pixels
0x18A2, 0x3125, 0x20C3, 0x3145, 0x28E4, 0x18A3, 0x0821, 0x1021, 0x1882, 0x3986, 0x7BAE, 0x7B8D, 0x5AA9, 0x62CA, 0x5269, 0x4A29,   // 0x02A0 (672) pixels
0x1061, 0x0000, 0x0000, 0x18A2, 0x3165, 0x18A2, 0x0800, 0x62CB, 0x8C10, 0x8C30, 0x734C, 0x630B, 0x20E3, 0x1041, 0x5A8A, 0xBD96,   // 0x02B0 (688) pixels
0x5A8A, 0x5AAB, 0x39C8, 0x1883, 0x20A3, 0x20C4, 0x2904, 0x28E4, 0x2904, 0x41C7, 0x3966, 0x3966, 0x4A08, 0x7BAE, 0xA4F3, 0xA4F4,   // 0x02C0 (704) pixels
0x9451, 0xBDB6, 0xB596, 0xA4F3, 0x8C51, 0xBDD6, 0xAD54, 0x9470, 0x62CA, 0x41E7, 0x28E3, 0x20A3, 0x1883, 0x1021, 0x1862, 0x1021,   // 0x02D0 (720) pixels
0x2083, 0x1041, 0x1041, 0x20A3, 0x1042, 0x0801, 0x1021, 0x1862, 0x2904, 0x5A69, 0x7B8D, 0x7B8D, 0x5A89, 0x5248, 0x2104, 0x0821,   // 0x02E0 (736) pixels
0x0000, 0x0020, 0x0000, 0x0000, 0x0841, 0x1062, 0x1041, 0x41E7, 0x8C30, 0x83EF, 0x736C, 0xAD33, 0x5268, 0x2903, 0x4A29, 0x5269,   // 0x02F0 (752) pixels
0x2925, 0x3166, 0x3186, 0x3166, 0x736E, 0x8C10, 0x3145, 0x41C7, 0x3145, 0x3166, 0x49E8, 0x41C7, 0x736E, 0x9CB3, 0xBDB6, 0xB576,   // 0x0300 (768) pixels
0xA513, 0x8C51, 0xA513, 0x9471, 0x9492, 0xB5B6, 0x840F, 0x8C0E, 0x62E8, 0x5246, 0x3103, 0x2062, 0x2082, 0x1861, 0x1861, 0x1041,   // 0x0310 (784) pixels
0x1021, 0x0800, 0x0820, 0x0800, 0x0800, 0x1041, 0x1041, 0x18A2, 0x3145, 0x5269, 0x62AA, 0x6B0B, 0x4A28, 0x3145, 0x1082, 0x0820,   // 0x0320 (800) pixels
0x0820, 0x20E3, 0x0000, 0x0820, 0x0821, 0x0800, 0x1041, 0x1061, 0x4A28, 0x738D, 0x6B2B, 0x83CE, 0x62CA, 0x41A6, 0x2903, 0x3124,   // 0x0330 (816) pixels
0x3985, 0x2924, 0x2904, 0x2904, 0x8C10, 0xAD14, 0x6B2D, 0x9451, 0x9C92, 0x528A, 0x3986, 0x1883, 0xA4D3, 0x8C31, 0x9CD3, 0x9471,   // 0x0340 (832) pixels
0xA514, 0xAD55, 0xAD34, 0xAD55, 0x9451, 0x83F0, 0x736D, 0x6B0A, 0x5A87, 0x49C5, 0x3103, 0x1861, 0x1861, 0x2061, 0x1841, 0x0820,   // 0x0350 (848) pixels
0x0800, 0x0800, 0x0800, 0x1062, 0x0800, 0x20A3, 0x1041, 0x1882, 0x2903, 0x3104, 0x3104, 0x3165, 0x3185, 0x2945, 0x1082, 0x0861,   // 0x0360 (864) pixels
0x0020, 0x0820, 0x0000, 0x0820, 0x0820, 0x0800, 0x20C3, 0x1041, 0x3165, 0x5ACA, 0x736C, 0x734C, 0x6B2C, 0x7B8E, 0x734C, 0x6B0B,   // 0x0370 (880) pixels
0x6B0C, 0x5A89, 0x5A8A, 0x9C92, 0x9C92, 0x83CF, 0x5AAA, 0x39C7, 0x528A, 0x39C7, 0x20E3, 0x4A28, 0x9CB2, 0x4A28, 0x6B4D, 0xA4F3,   // 0x0380 (896) pixels
0xB595, 0xAD14, 0x83CF, 0x6B0C, 0x6B0C, 0x5229, 0x41C6, 0x3144, 0x3985, 0x28E3, 0x20A2, 0x2082, 0x28C3, 0x20A2, 0x1841, 0x0800,   // 0x0390 (912) pixels
0x0800, 0x0000, 0x0821, 0x1882, 0x1862, 0x20C3, 0x20A3, 0x1841, 0x2082, 0x2061, 0x2082, 0x20A2, 0x1040, 0x1861, 0x1081, 0x0000,   // 0x03A0 (928) pixels
0x0800, 0x0820, 0x0800, 0x0000, 0x1062, 0x39A7, 0x3145, 0x0820, 0x2904, 0x5269, 0x4A27, 0x630B, 0x5ACB, 0x5ACB, 0x4A28, 0x4208,   // 0x03B0 (944) pixels
0x630C, 0x630C, 0x62EC, 0x9C93, 0x9492, 0x8C51, 0x8410, 0x738E, 0x3186, 0x4A28, 0x8C30, 0xA4F3, 0x736D, 0x4A48, 0x5AAA, 0x8410,   // 0x03C0 (960) pixels
0x9CB2, 0x8C30, 0x7B8E, 0x6AEC, 0x5249, 0x49E8, 0x3965, 0x41C7, 0x6AEC, 0x41A7, 0x2082, 0x28A2, 0x20A2, 0x28C3, 0x2061, 0x1020,   // 0x03D0 (976) pixels
0x0800, 0x1000, 0x1020, 0x1821, 0x1001, 0x1842, 0x28C3, 0x28A3, 0x30A3, 0x28A3, 0x2882, 0x28C2, 0x30E3, 0x2061, 0x1861, 0x1821,   // 0x03E0 (992) pixels
0x1821, 0x2062, 0x2042, 0x2062, 0x28E3, 0x39A6, 0x39C6, 0x1882, 0x41A7, 0x4A08, 0x41E6, 0x18A1, 0x1082, 0x2104, 0x18A2, 0x0841,   // 0x03F0 (1008) pixels
0x0841, 0x18C3, 0x2946, 0x5ACC, 0x5ACB, 0x4A29, 0x5ACB, 0x734D, 0x734D, 0x734D, 0x83F0, 0x62AB, 0x5A8B, 0x41E8, 0x6B4D, 0xA513,   // 0x0400 (1024) pixels
0xB576, 0x9472, 0x6B2C, 0x49E7, 0x4186, 0x4166, 0x3124, 0x28E3, 0x1841, 0x1862, 0x20C3, 0x20A2, 0x28C2, 0x3103, 0x2882, 0x30A3,   // 0x0410 (1040) pixels
0x30C3, 0x30C3, 0x30A3, 0x30C4, 0x30C5, 0x3926, 0x4967, 0x4967, 0x4966, 0x4946, 0x4945, 0x3903, 0x30C2, 0x2881, 0x2882, 0x2862,   // 0x0420 (1056) pixels
0x2062, 0x30C3, 0x3905, 0x4146, 0x4145, 0x3965, 0x41E6, 0x4A07, 0x41C7, 0x2965, 0x10A2, 0x0000, 0x0000, 0x0820, 0x0820, 0x0841,   // 0x0430 (1072) pixels
0x0000, 0x0841, 0x20E4, 0x2966, 0x18A3, 0x20E4, 0x41C7, 0x41E8, 0x7BAF, 0x6B2D, 0x5AAB, 0x5229, 0x4A29, 0x738E, 0x9471, 0xA514,   // 0x0440 (1088) pixels
0xAD35, 0x9472, 0x7BAF, 0x7B6D, 0x49E7, 0x3124, 0x20A2, 0x20E2, 0x1861, 0x0800, 0x1020, 0x1000, 0x1821, 0x30C3, 0x4125, 0x5166,   // 0x0450 (1104) pixels
0x5167, 0x5987, 0x59A8, 0x59C9, 0x59E9, 0x59E9, 0x59E9, 0x59E9, 0x59C9, 0x59C8, 0x51A7, 0x4966, 0x4124, 0x38E3, 0x30C3, 0x30C3,   // 0x0460 (1120) pixels
0x3904, 0x2062, 0x30C3, 0x30C3, 0x30E4, 0x3945, 0x3986, 0x5249, 0x20E3, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0820,   // 0x0470 (1136) pixels
0x1062, 0x1082, 0x0821, 0x0842, 0x1083, 0x2925, 0x3166, 0x49E8, 0x28E4, 0x2925, 0x3987, 0x39A7, 0x734E, 0x83F0, 0x9492, 0x5AEC,   // 0x0480 (1152) pixels
0xBD97, 0x7BCF, 0x6B2C, 0x8C30, 0x83CF, 0x41A6, 0x3104, 0x2903, 0x20C3, 0x1862, 0x1021, 0x1020, 0x20A3, 0x49A7, 0x624A, 0x6A4A,   // 0x0490 (1168) pixels
0x6A2A, 0x6A4B, 0x6A4B, 0x6A6B, 0x6A6B, 0x626B, 0x624A, 0x624B, 0x622B, 0x620A, 0x59E9, 0x51A7, 0x5166, 0x5166, 0x4945, 0x3904,   // 0x04A0 (1184) pixels
0x30C3, 0x2862, 0x38E4, 0x3925, 0x3925, 0x1001, 0x20A3, 0x41C7, 0x1061, 0x0820, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0820,   // 0x04B0 (1200) pixels
0x1061, 0x1082, 0x0000, 0x0000, 0x1062, 0x3146, 0x4A29, 0x3166, 0x41A7, 0x4A29, 0x3166, 0x20E4, 0x3146, 0x4A29, 0x4A6A, 0x73D0,   // 0x04C0 (1216) pixels
0xAD35, 0xA4F4, 0xA4F3, 0x736D, 0x5A8A, 0x41A7, 0x4166, 0x49C7, 0x20C3, 0x1041, 0x1000, 0x1821, 0x4146, 0x6A6A, 0x72CC, 0x72CC,   // 0x04D0 (1232) pixels
0x72AC, 0x72AC, 0x728C, 0x6A8C, 0x6A8C, 0x6AAC, 0x6A8C, 0x6A6B, 0x6A4B, 0x620A, 0x61E9, 0x61C9, 0x5987, 0x5166, 0x5145, 0x4944,   // 0x04E0 (1248) pixels
0x4103, 0x30C3, 0x3904, 0x6249, 0x3104, 0x1821, 0x1001, 0x0801, 0x0821, 0x0841, 0x0820, 0x0000, 0x0841, 0x0821, 0x0820, 0x0821,   // 0x04F0 (1264) pixels
0x0800, 0x0821, 0x0000, 0x0821, 0x1062, 0x20E4, 0x7BAF, 0x9CB3, 0x630C, 0x6B2D, 0x8C51, 0x7BCF, 0x630C, 0x8410, 0x9492, 0x7BF0,   // 0x0500 (1280) pixels
0xBDB7, 0xBD97, 0xBD96, 0x9472, 0x6B0C, 0x5AAB, 0x5229, 0x49E8, 0x28C3, 0x28E3, 0x1000, 0x2882, 0x6208, 0x7B0D, 0x7B0D, 0x730D,   // 0x0510 (1296) pixels
0x72ED, 0x72AC, 0x72AC, 0x728C, 0x72AC, 0x72CC, 0x72CC, 0x6A8B, 0x6A4A, 0x620A, 0x61C9, 0x61C9, 0x5987, 0x5966, 0x5985, 0x5185,   // 0x0520 (1312) pixels
0x5164, 0x4103, 0x3903, 0x3904, 0x2041, 0x2062, 0x1822, 0x0801, 0x0801, 0x0841, 0x0841, 0x0000, 0x0800, 0x0821, 0x1041, 0x1062,   // 0x0530 (1328) pixels
0x0820, 0x0800, 0x1021, 0x1021, 0x1882, 0x1882, 0x2925, 0x3165, 0x6B4D, 0x8410, 0x8451, 0x8430, 0x8C91, 0x8C51, 0x8C50, 0x9CB2,   // 0x0540 (1344) pixels
0xAD35, 0xB596, 0xB576, 0x7BAF, 0x6B0C, 0x7B8E, 0x5A8A, 0x41C7, 0x5249, 0x39A6, 0x1041, 0x3104, 0x728B, 0x834E, 0x7B0D, 0x72ED,   // 0x0550 (1360) pixels
0x72CC, 0x72AC, 0x72AC, 0x72AC, 0x6A8C, 0x72AC, 0x72CC, 0x728B, 0x622A, 0x61E9, 0x61C8, 0x61C8, 0x61C7, 0x61A6, 0x59A5, 0x5184,   // 0x0560 (1376) pixels
0x5164, 0x4924, 0x38E3, 0x4104, 0x3904, 0x28A3, 0x1821, 0x1001, 0x0800, 0x0821, 0x0841, 0x0000, 0x0000, 0x0821, 0x1061, 0x1882,   // 0x0570 (1392) pixels
0x1882, 0x1882, 0x1041, 0x0800, 0x0800, 0x1862, 0x20E3, 0x5269, 0x4228, 0x4208, 0x2945, 0x4228, 0x5AEB, 0x4A49, 0x526A, 0x4208,   // 0x0580 (1408) pixels
0xAD35, 0xAD35, 0xA4D3, 0x9492, 0x9CB3, 0xBD97, 0xA514, 0xA4F3, 0x6B2C, 0x3965, 0x1040, 0x51C7, 0x7AEC, 0x8B4E, 0x7B0D, 0x72CC,   // 0x0590 (1424) pixels
0x6AAC, 0x72AC, 0x72AC, 0x6A8B, 0x6A6B, 0x72AC, 0x72AC, 0x6A8B, 0x6229, 0x6208, 0x61E8, 0x61A8, 0x61A7, 0x59A7, 0x61A7, 0x5986,   // 0x05A0 (1440) pixels
0x5965, 0x5165, 0x4945, 0x4125, 0x3904, 0x28C3, 0x1862, 0x0800, 0x0800, 0x0820, 0x0820, 0x0000, 0x0800, 0x0800, 0x0800, 0x1041,   // 0x05B0 (1456) pixels
0x1061, 0x1882, 0x1041, 0x0821, 0x0800, 0x0821, 0x18A3, 0x2924, 0x2945, 0x3165, 0x3186, 0x39C7, 0x39C7, 0x20E4, 0x18C3, 0x20E4,   // 0x05C0 (1472) pixels
0xBD96, 0x9492, 0x7BAF, 0x9CD4, 0xA4D4, 0x736E, 0x6B4D, 0x630B, 0x734C, 0x4A07, 0x28E3, 0x6249, 0x7AEC, 0x834E, 0x7B0E, 0x7AEE,   // 0x05D0 (1488) pixels
0x72AD, 0x7AAC, 0x7A8C, 0x728C, 0x728C, 0x7ACD, 0x7ACD, 0x72AC, 0x6A4B, 0x6A2A, 0x61E9, 0x61C8, 0x61C7, 0x59A7, 0x59A7, 0x59A7,   // 0x05E0 (1504) pixels
0x5986, 0x5166, 0x5145, 0x4925, 0x4104, 0x38E3, 0x2882, 0x2062, 0x1000, 0x0820, 0x0820, 0x0801, 0x0841, 0x0000, 0x0000, 0x0000,   // 0x05F0 (1520) pixels
0x1082, 0x0820, 0x0000, 0x0000, 0x0000, 0x0821, 0x2925, 0x18A3, 0x18A3, 0x1062, 0x2925, 0x2104, 0x20E4, 0x2925, 0x3166, 0x20E4,   // 0x0600 (1536) pixels
0xBDD7, 0xA4F4, 0x9472, 0x8410, 0x8C30, 0x6B4D, 0x7BCE, 0x5A88, 0x62C9, 0x4A06, 0x3923, 0x6AAB, 0x834E, 0x836F, 0x836F, 0x8B90,   // 0x0610 (1552) pixels
0x834F, 0x7AEE, 0x7ACD, 0x72AC, 0x72AC, 0x7ACC, 0x7ACD, 0x72AC, 0x728C, 0x728C, 0x6A29, 0x61C8, 0x61C8, 0x59A7, 0x59A7, 0x59A7,   // 0x0620 (1568) pixels
0x5987, 0x59A7, 0x5186, 0x5146, 0x4924, 0x40E3, 0x38E3, 0x30C3, 0x28A3, 0x2062, 0x1020, 0x0801, 0x0841, 0x0000, 0x0000, 0x0820,   // 0x0630 (1584) pixels
0x0020, 0x0000, 0x0000, 0x0020, 0x0841, 0x1062, 0x0841, 0x0000, 0x0841, 0x1083, 0x1062, 0x1062, 0x1082, 0x2946, 0x39A7, 0x3186,   // 0x0640 (1600) pixels
0xC5F7, 0xB596, 0x9CB2, 0x8C30, 0x9CB2, 0x736D, 0x738D, 0x734B, 0x5A88, 0x4A06, 0x3965, 0x730C, 0x8BAF, 0x8BB0, 0x8BB0, 0x8BB0,   // 0x0650 (1616) pixels
0x8BB0, 0x7B2E, 0x7B0E, 0x830E, 0x728C, 0x7ACD, 0x8B2E, 0x7AED, 0x7AED, 0x728C, 0x6A09, 0x61C8, 0x61C8, 0x59C8, 0x59A7, 0x59A7,   // 0x0660 (1632) pixels
0x59A7, 0x59A6, 0x5186, 0x5166, 0x5165, 0x4944, 0x4924, 0x4104, 0x30A3, 0x2021, 0x1000, 0x0800, 0x0000, 0x0020, 0x0000, 0x0000,   // 0x0670 (1648) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0821, 0x0821, 0x0821, 0x1082, 0x20C4, 0x1083, 0x1042, 0x20E4,   // 0x0680 (1664) pixels
0xC618, 0xC618, 0xBDD7, 0x83EF, 0x6B2C, 0x9491, 0x9471, 0x7BAE, 0x7B8D, 0x5A69, 0x3124, 0x7B6D, 0x9410, 0x9411, 0x838F, 0x8390,   // 0x0690 (1680) pixels
0x8BD0, 0x7B0D, 0x7AED, 0x8B4E, 0x832E, 0x9BD0, 0x8B6F, 0x830D, 0x7AAC, 0x6209, 0x61C8, 0x61E8, 0x61E9, 0x61EA, 0x61C9, 0x59C9,   // 0x06A0 (1696) pixels
0x51A8, 0x5187, 0x5166, 0x5166, 0x5165, 0x5144, 0x4924, 0x4924, 0x4904, 0x38C2, 0x1821, 0x0800, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x06B0 (1712) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0001, 0x0862, 0x18A3, 0x1062, 0x0020, 0x0020, 0x0000, 0x0000,   // 0x06C0 (1728) pixels
0xC618, 0xC618, 0xC5F8, 0xB575, 0x9CD3, 0x9CD2, 0x9CD2, 0x7BCE, 0x5269, 0x28E3, 0x1861, 0x9430, 0xB514, 0xA493, 0x8BB0, 0x838F,   // 0x06D0 (1744) pixels
0x8BB0, 0x7AEC, 0x7ACC, 0x830D, 0x8B4E, 0xA410, 0x9BD0, 0x728B, 0x6A49, 0x6208, 0x6229, 0x5A08, 0x51C8, 0x4167, 0x38E5, 0x28A4,   // 0x06E0 (1760) pixels
0x2884, 0x2883, 0x30C4, 0x4946, 0x5185, 0x5165, 0x5144, 0x4924, 0x4944, 0x4103, 0x30E3, 0x1861, 0x0800, 0x0800, 0x0000, 0x0000,   // 0x06F0 (1776) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0700 (1792) pixels
0xC618, 0xC618, 0xC618, 0xC5D7, 0xB555, 0xA514, 0x9492, 0x5A8A, 0x2925, 0x1862, 0x2924, 0xB534, 0xACF4, 0xB515, 0x8BD0, 0x7B4E,   // 0x0710 (1808) pixels
0x93CF, 0x7AAB, 0x726A, 0x7AAB, 0x8B0C, 0x830C, 0x8B0C, 0x724A, 0x6208, 0x59E8, 0x49A6, 0x28E3, 0x1861, 0x1000, 0x0801, 0x1001,   // 0x0720 (1824) pixels
0x1800, 0x2001, 0x2841, 0x3882, 0x4903, 0x5185, 0x5165, 0x4944, 0x4943, 0x4123, 0x38E2, 0x30C2, 0x2082, 0x3124, 0x20C3, 0x0000,   // 0x0730 (1840) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0740 (1856) pixels
0xC618, 0xC618, 0xC5F8, 0xC5F7, 0xBDD7, 0xA514, 0x738E, 0x3166, 0x1062, 0x0801, 0x41C7, 0x732C, 0x5A49, 0x5209, 0x3125, 0x3905,   // 0x0750 (1872) pixels
0x51A7, 0x6A28, 0x7249, 0x82CB, 0x82AB, 0x7A8A, 0x7249, 0x7249, 0x5166, 0x3082, 0x2021, 0x1820, 0x1841, 0x1841, 0x1821, 0x2062,   // 0x0760 (1888) pixels
0x3904, 0x59A6, 0x69E7, 0x61A6, 0x5165, 0x5185, 0x5986, 0x5165, 0x4945, 0x4924, 0x4124, 0x38E3, 0x30C3, 0x4186, 0x5229, 0x20C3,   // 0x0770 (1904) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0780 (1920) pixels
0xC618, 0xC618, 0xC618, 0xC5F8, 0xBDB6, 0x73AE, 0x39C7, 0x18C3, 0x0842, 0x0000, 0x2904, 0x628A, 0x3105, 0x1863, 0x1842, 0x1821,   // 0x0790 (1936) pixels
0x2041, 0x38C3, 0x4104, 0x59A7, 0x7A8A, 0x7208, 0x6186, 0x5104, 0x40C3, 0x38A3, 0x4124, 0x30E3, 0x2061, 0x1841, 0x1000, 0x1020,   // 0x07A0 (1952) pixels
0x28A2, 0x4965, 0x59C6, 0x6A06, 0x6A06, 0x61C6, 0x61C6, 0x59A6, 0x5186, 0x4925, 0x4104, 0x40E3, 0x38A3, 0x2042, 0x20C3, 0x41C7,   // 0x07B0 (1968) pixels
0x1062, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x07C0 (1984) pixels
0xC619, 0xC618, 0xC5F7, 0xB576, 0x8C51, 0x4A28, 0x2124, 0x1082, 0x0000, 0x0000, 0x3145, 0x9C51, 0x41C8, 0x0821, 0x0021, 0x0000,   // 0x07D0 (2000) pixels
0x0000, 0x0000, 0x1020, 0x38E4, 0x6A4A, 0x6A09, 0x69A7, 0x5925, 0x40C3, 0x3081, 0x28A2, 0x1000, 0x1021, 0x20E4, 0x0821, 0x0841,   // 0x07E0 (2016) pixels
0x0821, 0x0800, 0x2061, 0x5185, 0x61E6, 0x61E6, 0x61C6, 0x59A6, 0x5985, 0x5165, 0x4924, 0x40E3, 0x38A3, 0x2862, 0x1000, 0x2925,   // 0x07F0 (2032) pixels
0x3986, 0x0800, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0800 (2048) pixels
0x9CB3, 0xA4F4, 0x9CD3, 0x8C30, 0x5ACB, 0x2945, 0x18A3, 0x1083, 0x0000, 0x0000, 0x4A28, 0x8BEF, 0x20A2, 0x1041, 0x3187, 0x1062,   // 0x0810 (2064) pixels
0x1062, 0x1021, 0x1020, 0x2062, 0x834E, 0x8B6E, 0x61C7, 0x5125, 0x38A2, 0x2861, 0x2041, 0x1821, 0x2083, 0x3946, 0x2083, 0x2082,   // 0x0820 (2080) pixels
0x28C3, 0x30E3, 0x30A3, 0x40E3, 0x5985, 0x61E6, 0x61C6, 0x59A6, 0x5986, 0x5965, 0x5145, 0x5124, 0x40C3, 0x3083, 0x1820, 0x1020,   // 0x0830 (2096) pixels
0x41C7, 0x3125, 0x0800, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0840 (2112) pixels
0x8C31, 0x9492, 0xB596, 0x736E, 0x5ACB, 0x3166, 0x1883, 0x0821, 0x0800, 0x1020, 0x5A49, 0x7B0C, 0x51C7, 0x51E8, 0x4166, 0x4987,   // 0x0850 (2128) pixels
0x5187, 0x4945, 0x40E4, 0x5A4A, 0xC597, 0xB4D4, 0x6208, 0x5145, 0x38C2, 0x3081, 0x2882, 0x38C3, 0x5125, 0x5166, 0x59C7, 0x5186,   // 0x0860 (2144) pixels
0x59A6, 0x5985, 0x5945, 0x5965, 0x5144, 0x5985, 0x59A6, 0x59A6, 0x5985, 0x5985, 0x5964, 0x5124, 0x48C3, 0x38A2, 0x2021, 0x1020,   // 0x0870 (2160) pixels
0x30E3, 0x49C7, 0x1841, 0x0801, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0880 (2176) pixels
0xB596, 0xAD35, 0x9CD3, 0x6B2C, 0x736E, 0x2904, 0x1042, 0x1001, 0x1861, 0x3103, 0x3944, 0x836D, 0x836D, 0x7B0C, 0x72AA, 0x7A8A,   // 0x0890 (2192) pixels
0x7249, 0x61E7, 0x5986, 0xB4D4, 0xCDD8, 0xCD97, 0x6209, 0x5146, 0x4904, 0x40C3, 0x3082, 0x38A3, 0x4905, 0x59A7, 0x61E8, 0x6A07,   // 0x08A0 (2208) pixels
0x69E7, 0x61A6, 0x61A6, 0x5986, 0x5985, 0x5965, 0x5985, 0x5965, 0x5965, 0x5965, 0x5144, 0x5124, 0x40C3, 0x3882, 0x2840, 0x1820,   // 0x08B0 (2224) pixels
0x28C3, 0x49C7, 0x28C3, 0x1862, 0x0800, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x08C0 (2240) pixels
0xCE18, 0xB596, 0x7BEF, 0x83CF, 0x6B0C, 0x20C3, 0x20A3, 0x2904, 0x3945, 0x3924, 0x30E3, 0x9430, 0xC596, 0x8B8E, 0x7ACB, 0x7AAA,   // 0x08D0 (2256) pixels
0x7249, 0x61E7, 0x72AA, 0xCDD8, 0xC5B8, 0xB4F4, 0x59C8, 0x5946, 0x5146, 0x5125, 0x4104, 0x4105, 0x40E5, 0x5166, 0x59A7, 0x61E7,   // 0x08E0 (2272) pixels
0x61C7, 0x61A6, 0x61A6, 0x6186, 0x5966, 0x5945, 0x5965, 0x5944, 0x5944, 0x5945, 0x5124, 0x5103, 0x40C3, 0x3882, 0x2841, 0x2862,   // 0x08F0 (2288) pixels
0x4166, 0x49E7, 0x28E3, 0x28E4, 0x18A3, 0x0841, 0x0021, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0900 (2304) pixels
0xC5F7, 0xB575, 0x7BCF, 0x6B2D, 0x4A08, 0x41A7, 0x5A6A, 0x4186, 0x3124, 0x28C3, 0x2082, 0xACF4, 0xC5B7, 0xB4F4, 0x72CC, 0x726B,   // 0x0910 (2320) pixels
0x6A09, 0x5A09, 0x9C51, 0xCDD8, 0xC5D8, 0x8BD0, 0x69E8, 0x6967, 0x6166, 0x5946, 0x5145, 0x5146, 0x4906, 0x4926, 0x5167, 0x59A7,   // 0x0920 (2336) pixels
0x61A7, 0x6187, 0x61A7, 0x6166, 0x5946, 0x5925, 0x5945, 0x5924, 0x5944, 0x5104, 0x50E4, 0x48C3, 0x48C3, 0x40A2, 0x3082, 0x4165,   // 0x0930 (2352) pixels
0x49C7, 0x4185, 0x3964, 0x3145, 0x3986, 0x2925, 0x20E4, 0x1883, 0x0821, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0940 (2368) pixels
0xC5F8, 0xBDB6, 0x6B4D, 0x6B2C, 0x5249, 0x62CB, 0x5269, 0x3965, 0x28C3, 0x28A2, 0x28E4, 0xB535, 0xCDB7, 0xCDB7, 0xA452, 0x728C,   // 0x0950 (2384) pixels
0x726C, 0x6A8C, 0xBD97, 0xC5F9, 0xBD76, 0x8B8F, 0x726A, 0x69A8, 0x6187, 0x5966, 0x5946, 0x5966, 0x5967, 0x5167, 0x5167, 0x59A7,   // 0x0960 (2400) pixels
0x5987, 0x61A7, 0x61A7, 0x6186, 0x6146, 0x5905, 0x6125, 0x6124, 0x6124, 0x5904, 0x50E4, 0x48C3, 0x40C3, 0x40C3, 0x4145, 0x4165,   // 0x0970 (2416) pixels
0x3945, 0x3924, 0x3124, 0x3945, 0x3145, 0x39A6, 0x3966, 0x3125, 0x1882, 0x0800, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0980 (2432) pixels
0xB596, 0xA514, 0x630C, 0x4A49, 0x630C, 0x6B2C, 0x528A, 0x3185, 0x2904, 0x2082, 0x20A3, 0xB534, 0xC596, 0xC576, 0xBD55, 0x93B0,   // 0x0990 (2448) pixels
0x72CD, 0x8BD1, 0xC5F8, 0xBDF8, 0xBD56, 0xA3F1, 0x7A8B, 0x61C8, 0x5966, 0x6166, 0x6187, 0x5987, 0x5967, 0x5987, 0x59A8, 0x5188,   // 0x09A0 (2464) pixels
0x59A8, 0x61A7, 0x6187, 0x6186, 0x6146, 0x6146, 0x6145, 0x6145, 0x6145, 0x5945, 0x5965, 0x5946, 0x5186, 0x51A7, 0x4965, 0x3945,   // 0x09B0 (2480) pixels
0x28A2, 0x28A2, 0x3103, 0x3924, 0x3965, 0x4186, 0x49C8, 0x49E8, 0x41A7, 0x1882, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x09C0 (2496) pixels
0xB597, 0xAD76, 0x8C51, 0x630C, 0x738E, 0x7BCF, 0x5269, 0x3165, 0x3124, 0x1821, 0x1862, 0xA4B2, 0xC596, 0xC5B7, 0xBD76, 0xB4D4,   // 0x09D0 (2512) pixels
0x7AEE, 0xACD5, 0xC5F8, 0xC5D7, 0xB4D4, 0x934E, 0x69E9, 0x61A7, 0x5987, 0x5946, 0x5966, 0x5966, 0x5966, 0x59A7, 0x59C8, 0x59C9,   // 0x09E0 (2528) pixels
0x6188, 0x6187, 0x6187, 0x6966, 0x6125, 0x6986, 0x71C7, 0x69C6, 0x69A6, 0x61C7, 0x61C7, 0x59A7, 0x5186, 0x4966, 0x4125, 0x2061,   // 0x09F0 (2544) pixels
0x1820, 0x2041, 0x2882, 0x30C3, 0x30A2, 0x2883, 0x2082, 0x3145, 0x41A7, 0x2904, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0A00 (2560) pixels
0xBDF8, 0xAD55, 0xAD76, 0x738E, 0x8C51, 0x738E, 0x528A, 0x3986, 0x20A2, 0x1841, 0x1841, 0x9C72, 0xC5B6, 0xC596, 0xC596, 0xACB3,   // 0x0A10 (2576) pixels
0x93B0, 0xCDB7, 0xC5F7, 0xBD96, 0xAC53, 0x8A8C, 0x69A8, 0x71E8, 0x9B6E, 0x69E8, 0x5966, 0x5166, 0x61A7, 0x59A7, 0x59C8, 0x61E8,   // 0x0A20 (2592) pixels
0x61C8, 0x61A7, 0x61A7, 0x6166, 0x7208, 0x69C7, 0x6165, 0x61A6, 0x6165, 0x6186, 0x5124, 0x5105, 0x4905, 0x3882, 0x2841, 0x2020,   // 0x0A30 (2608) pixels
0x1800, 0x1800, 0x2000, 0x2041, 0x2021, 0x2042, 0x2042, 0x3104, 0x3145, 0x2925, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0A40 (2624) pixels
0xC5F8, 0xBDD7, 0xBDD7, 0xA514, 0x9492, 0x8C31, 0x7B8E, 0x5A89, 0x20E3, 0x1020, 0x1020, 0x6B0C, 0xC596, 0xBD76, 0xBD75, 0x9C51,   // 0x0A50 (2640) pixels
0x93B0, 0xD5D8, 0xB515, 0x9BF0, 0x7A4A, 0x79E9, 0x71E8, 0x71E8, 0x7208, 0x69C7, 0x6186, 0x5985, 0x61C7, 0x7248, 0x7A6A, 0x8B0C,   // 0x0A60 (2656) pixels
0x6A49, 0x61C7, 0x7229, 0x6A29, 0x69E8, 0x6186, 0x6165, 0x7207, 0x5965, 0x6145, 0x5924, 0x50C3, 0x4082, 0x3862, 0x2820, 0x2000,   // 0x0A70 (2672) pixels
0x1800, 0x1800, 0x2021, 0x2862, 0x2862, 0x2062, 0x3105, 0x3966, 0x3166, 0x20E4, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0A80 (2688) pixels
0xC5F8, 0xBDB7, 0xB576, 0x9CD4, 0x9CB3, 0x7BCF, 0x630C, 0x41C7, 0x3986, 0x3104, 0x1841, 0x3124, 0xBD35, 0xB4F4, 0xAC92, 0x8B8E,   // 0x0A90 (2704) pixels
0x7AAB, 0x9BF0, 0x830C, 0x7249, 0x7A08, 0x79E7, 0x69A6, 0x5123, 0x5924, 0x69A6, 0x5964, 0x5144, 0x5944, 0x69E7, 0x7208, 0x69E8,   // 0x0AA0 (2720) pixels
0x6A08, 0x6A28, 0x7A49, 0x69E8, 0x6186, 0x6986, 0x6945, 0x71C7, 0x6186, 0x6165, 0x58E3, 0x48A2, 0x4081, 0x3861, 0x3040, 0x2820,   // 0x0AB0 (2736) pixels
0x2000, 0x1820, 0x2041, 0x2882, 0x28A3, 0x28C4, 0x2905, 0x3966, 0x3146, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0001,   // 0x0AC0 (2752) pixels
0xBDD7, 0xB596, 0xBD97, 0xB556, 0x8410, 0x4A29, 0x3186, 0x20C3, 0x28E3, 0x3104, 0x28E3, 0x18A2, 0x9C51, 0xAC72, 0x936E, 0x8AEC,   // 0x0AD0 (2768) pixels
0x828A, 0x6A08, 0xA451, 0x93AE, 0x828A, 0x71C7, 0x5904, 0x5124, 0x5944, 0x6124, 0x5124, 0x5164, 0x5965, 0x5965, 0x61C6, 0x6A07,   // 0x0AE0 (2784) pixels
0x7228, 0x7A48, 0x7228, 0x71C7, 0x6965, 0x6965, 0x6966, 0x7A49, 0x6146, 0x5924, 0x50E3, 0x50C3, 0x40A2, 0x3881, 0x3041, 0x2800,   // 0x0AF0 (2800) pixels
0x2000, 0x1820, 0x2061, 0x2082, 0x28E4, 0x28C4, 0x3125, 0x39A7, 0x1082, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0B00 (2816) pixels
0xC5F8, 0xC5F8, 0xBDF8, 0xA514, 0x526A, 0x39C7, 0x39A6, 0x3125, 0x20A2, 0x20A3, 0x28C3, 0x3125, 0x834D, 0xAC72, 0x934E, 0x8ACB,   // 0x0B10 (2832) pixels
0x82CB, 0x8B6D, 0xCDB7, 0x9C31, 0x724A, 0x6987, 0x5925, 0x5946, 0x6146, 0x5926, 0x5946, 0x5986, 0x5986, 0x61A7, 0x61C7, 0x7248,   // 0x0B20 (2848) pixels
0x7A69, 0x7A69, 0x7A49, 0x8248, 0x79A6, 0x69A6, 0x8B2C, 0x9B6E, 0x5945, 0x5103, 0x58E3, 0x50C3, 0x4081, 0x3881, 0x3040, 0x2820,   // 0x0B30 (2864) pixels
0x2020, 0x2061, 0x1841, 0x0800, 0x3966, 0x3125, 0x41C8, 0x2905, 0x1062, 0x0021, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x0B40 (2880) pixels
0xBD97, 0xBDB7, 0xB596, 0xA4F4, 0x630C, 0x41E7, 0x41C7, 0x3125, 0x2904, 0x28C4, 0x4187, 0x5A6A, 0x49A7, 0x8B8E, 0x9B6E, 0x92EC,   // 0x0B50 (2896) pixels
0x7A69, 0x9C51, 0xCDF8, 0xA4F4, 0x6A8A, 0x61A8, 0x5986, 0x5966, 0x5966, 0x5946, 0x61C7, 0x82EC, 0x832D, 0x830C, 0x832C, 0x936D,   // 0x0B60 (2912) pixels
0xA3CE, 0x82AA, 0x7A29, 0x8249, 0x7A08, 0x8ACA, 0x7A69, 0x61A6, 0x5924, 0x5923, 0x50E3, 0x50C2, 0x48A1, 0x4081, 0x3060, 0x2840,   // 0x0B70 (2928) pixels
0x2020, 0x2062, 0x1862, 0x0800, 0x3146, 0x49E8, 0x4A29, 0x3166, 0x1062, 0x0021, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0B80 (2944) pixels
0xC5F8, 0xBDD7, 0xBDF8, 0x8431, 0x83EF, 0x83CE, 0x4A07, 0x2904, 0x3986, 0x4166, 0x730C, 0x62CB, 0x3165, 0x5208, 0x9BAF, 0x8AEB,   // 0x0B90 (2960) pixels
0x7289, 0xACB2, 0xC5F8, 0xBD97, 0x6AAB, 0x61E9, 0x61A8, 0x5987, 0x61A7, 0x5966, 0x5987, 0x61E8, 0x6A29, 0x59C7, 0x6A28, 0x61E7,   // 0x0BA0 (2976) pixels
0x7228, 0x8AEB, 0xA3AE, 0x8269, 0x8269, 0x8289, 0x6165, 0x6165, 0x5944, 0x5943, 0x5903, 0x50E2, 0x48A1, 0x4081, 0x3060, 0x2840,   // 0x0BB0 (2992) pixels
0x2020, 0x2882, 0x20A2, 0x0000, 0x20A4, 0x4A2A, 0x4A4A, 0x41C9, 0x1043, 0x0001, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0BC0 (3008) pixels
0xAD76, 0x9CD3, 0xB5B7, 0x630C, 0x736D, 0x62EB, 0x7B6D, 0x41C7, 0x49E7, 0x5228, 0x7B6D, 0x4A48, 0x3165, 0x1862, 0x8B6E, 0x8B2C,   // 0x0BD0 (3024) pixels
0x72CA, 0xA451, 0xCDD8, 0xCDD9, 0x832E, 0x720A, 0x6967, 0x6146, 0x6166, 0x5946, 0x5966, 0x61A7, 0x6A08, 0x830B, 0x934C, 0x7248,   // 0x0BE0 (3040) pixels
0x7248, 0x82EA, 0x71E7, 0x79E7, 0x71C6, 0x69A5, 0x6984, 0x6164, 0x6144, 0x5923, 0x5903, 0x50C2, 0x48A2, 0x3881, 0x3881, 0x2840,   // 0x0BF0 (3056) pixels
0x2020, 0x28A2, 0x1882, 0x0800, 0x1862, 0x41C9, 0x526B, 0x4A0A, 0x1884, 0x0001, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0C00 (3072) pixels
0xC618, 0xA514, 0xAD55, 0x5AEB, 0x6B2C, 0x5AAA, 0x5A89, 0x3124, 0x49C6, 0x5228, 0x7B8C, 0x4A07, 0x18A2, 0x0800, 0x626A, 0x8B4D,   // 0x0C10 (3088) pixels
0x7ACA, 0x8B6D, 0x93D0, 0x6A6A, 0x69E8, 0x6986, 0x60E4, 0x58E4, 0x58E4, 0x5905, 0x5925, 0x5966, 0x61A7, 0x61C6, 0x61C6, 0x61E6,   // 0x0C20 (3104) pixels
0x61C5, 0x69E6, 0x7206, 0x7206, 0x71C5, 0x69A5, 0x69A5, 0x6985, 0x8248, 0x6164, 0x5903, 0x50E2, 0x48C2, 0x40A1, 0x3881, 0x2840,   // 0x0C30 (3120) pixels
0x2020, 0x2882, 0x28E3, 0x0800, 0x2083, 0x3987, 0x5A6A, 0x4A09, 0x2104, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0C40 (3136) pixels
0xC618, 0xBDB6, 0xB575, 0x8410, 0x738D, 0x5269, 0x3165, 0x3104, 0x5208, 0x41A6, 0x3985, 0x4A06, 0x1881, 0x0800, 0x3945, 0x93AE,   // 0x0C50 (3152) pixels
0x7ACA, 0x82CA, 0x7AAB, 0x59C8, 0x5125, 0x50C4, 0x4883, 0x4862, 0x4062, 0x4082, 0x40A3, 0x38A2, 0x40E3, 0x5144, 0x61C5, 0x61C5,   // 0x0C60 (3168) pixels
0x61C4, 0x69C5, 0x7205, 0x69E5, 0x69C5, 0x69A5, 0x6985, 0x6985, 0x6985, 0x5943, 0x5923, 0x50E3, 0x48C2, 0x40A1, 0x3060, 0x2841,   // 0x0C70 (3184) pixels
0x2020, 0x1820, 0x2904, 0x0801, 0x30E4, 0x41A6, 0x5229, 0x5249, 0x2924, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0C80 (3200) pixels
0xC618, 0xC618, 0xA4F3, 0x8C30, 0x5ACA, 0x9CD3, 0x7BAE, 0x4A07, 0x6269, 0x3925, 0x1020, 0x2923, 0x3144, 0x1861, 0x1020, 0x7B6C,   // 0x0C90 (3216) pixels
0x7B2B, 0x7AAA, 0xA431, 0xB4B4, 0x830E, 0x5106, 0x4885, 0x4863, 0x3863, 0x3883, 0x38A3, 0x40E4, 0x5145, 0x5965, 0x6185, 0x61C5,   // 0x0CA0 (3232) pixels
0x69C4, 0x69C4, 0x69E5, 0x69C5, 0x69C5, 0x69C5, 0x69C6, 0x61A6, 0x6185, 0x5943, 0x5103, 0x5103, 0x48C2, 0x38A1, 0x3060, 0x2840,   // 0x0CB0 (3248) pixels
0x2061, 0x2041, 0x20C4, 0x1021, 0x3104, 0x5228, 0x41A7, 0x5229, 0x2945, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0CC0 (3264) pixels
0xBDB6, 0xB596, 0xAD14, 0x9CB2, 0x7BAE, 0x5AAA, 0x5AAA, 0x3965, 0x5A28, 0x3104, 0x1040, 0x18A1, 0x3144, 0x3124, 0x1882, 0x49E7,   // 0x0CD0 (3280) pixels
0x8BCD, 0x7AEA, 0xA431, 0xC576, 0xBCF5, 0x82AC, 0x6947, 0x6126, 0x6146, 0x6966, 0x6186, 0x69A7, 0x69A7, 0x69C6, 0x69A5, 0x6184,   // 0x0CE0 (3296) pixels
0x69C5, 0x69C5, 0x69E5, 0x69C5, 0x69E5, 0x61C5, 0x61A5, 0x61A6, 0x5964, 0x5143, 0x4902, 0x4903, 0x40C2, 0x3881, 0x3081, 0x2861,   // 0x0CF0 (3312) pixels
0x2020, 0x2062, 0x28E5, 0x1021, 0x3104, 0x49C7, 0x4186, 0x41E8, 0x3166, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D00 (3328) pixels
0xBDD7, 0xA4F3, 0x9CB2, 0x9471, 0x62EB, 0x62EB, 0x41E7, 0x41A5, 0x4165, 0x3104, 0x1861, 0x1061, 0x1861, 0x49E7, 0x1882, 0x1841,   // 0x0D10 (3344) pixels
0x7B0B, 0x832B, 0x834C, 0xBD34, 0x834D, 0x82EC, 0x824A, 0x79E7, 0x71C6, 0x71A5, 0x69A5, 0x71C6, 0x71E6, 0x69C6, 0x69A5, 0x69A5,   // 0x0D20 (3360) pixels
0x69C5, 0x69C5, 0x69C5, 0x69C5, 0x61A5, 0x61C5, 0x61A5, 0x61A5, 0x5964, 0x5984, 0x4922, 0x40E2, 0x38A1, 0x3881, 0x3081, 0x2861,   // 0x0D30 (3376) pixels
0x2041, 0x2082, 0x20A3, 0x1842, 0x3125, 0x41C7, 0x41A6, 0x3966, 0x2945, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D40 (3392) pixels
0xB575, 0xA4F4, 0x9472, 0x7BAE, 0x738E, 0x6B2C, 0x62AA, 0x5A68, 0x41A6, 0x1861, 0x1041, 0x1041, 0x1020, 0x3986, 0x3145, 0x1841,   // 0x0D50 (3408) pixels
0x3965, 0x836C, 0x830B, 0x9C0F, 0x93EE, 0x72AA, 0x7A28, 0x7A07, 0x7205, 0x69E5, 0x71E5, 0x7206, 0x69C5, 0x69C5, 0x69E5, 0x69C5,   // 0x0D60 (3424) pixels
0x69C5, 0x69A5, 0x69C5, 0x69C5, 0x69C5, 0x69C5, 0x69C5, 0x61A5, 0x5964, 0x5143, 0x4102, 0x40C1, 0x38A1, 0x38A1, 0x3061, 0x2882,   // 0x0D70 (3440) pixels
0x2841, 0x2062, 0x1841, 0x20C4, 0x2905, 0x4A29, 0x3145, 0x39A6, 0x20E3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D80 (3456) pixels
0x9CD3, 0x7BCF, 0x630C, 0x5249, 0x5AAA, 0x6B2D, 0x6AEC, 0x5228, 0x730C, 0x5248, 0x1861, 0x1020, 0x1020, 0x2904, 0x4A08, 0x1882,   // 0x0D90 (3472) pixels
0x1841, 0x6ACA, 0x836D, 0x838D, 0x8BAD, 0x72CA, 0x7228, 0x69C6, 0x61C5, 0x6185, 0x61A5, 0x69C6, 0x61A6, 0x61A6, 0x61C5, 0x61C5,   // 0x0DA0 (3488) pixels
0x61A5, 0x69C6, 0x69C6, 0x69C6, 0x69E6, 0x69C5, 0x61A4, 0x6184, 0x5143, 0x4902, 0x4102, 0x40C2, 0x40E2, 0x38A1, 0x3081, 0x30A2,   // 0x0DB0 (3504) pixels
0x2862, 0x2882, 0x1862, 0x2083, 0x2905, 0x5229, 0x39A7, 0x3986, 0x18A2, 0x1061, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0DC0 (3520) pixels
0xA4F3, 0x7BCF, 0x83EF, 0x6B2C, 0x5ACB, 0x6B4D, 0x730C, 0x628A, 0x51E7, 0x6269, 0x6269, 0x20C2, 0x0820, 0x1841, 0x4A08, 0x3125,   // 0x0DD0 (3536) pixels
0x1882, 0x3104, 0x8BCF, 0x8BAF, 0xACD3, 0x7B0C, 0x7229, 0x69A7, 0x5966, 0x5965, 0x5966, 0x61A6, 0x59A5, 0x59A5, 0x59A6, 0x61C6,   // 0x0DE0 (3552) pixels
0x61A6, 0x69A6, 0x69C6, 0x69C6, 0x69E6, 0x69C5, 0x6184, 0x5943, 0x5122, 0x40E2, 0x4102, 0x4903, 0x4903, 0x38A1, 0x38C2, 0x3082,   // 0x0DF0 (3568) pixels
0x2882, 0x2041, 0x1862, 0x2083, 0x2905, 0x4A29, 0x4A08, 0x39A6, 0x2904, 0x0841, 0x0821, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E00 (3584) pixels
0xA514, 0x8C51, 0x5ACB, 0x62AA, 0x5229, 0x5229, 0x5A8A, 0x5A69, 0x5A69, 0x4185, 0x41A5, 0x5A68, 0x3124, 0x1020, 0x1882, 0x41C7,   // 0x0E10 (3600) pixels
0x1861, 0x1861, 0x62CB, 0xB534, 0xC5B6, 0x8BAF, 0x724A, 0x71E9, 0x69A7, 0x6186, 0x6186, 0x61A6, 0x61A6, 0x61A6, 0x61C6, 0x61C6,   // 0x0E20 (3616) pixels
0x69C6, 0x69A6, 0x69C6, 0x69A5, 0x69C5, 0x61A4, 0x5984, 0x5943, 0x5143, 0x5123, 0x5123, 0x5123, 0x40C2, 0x40E2, 0x38A2, 0x30A2,   // 0x0E30 (3632) pixels
0x2881, 0x28C2, 0x1820, 0x28C3, 0x2083, 0x49E7, 0x5269, 0x41A6, 0x3145, 0x1882, 0x1041, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E40 (3648) pixels
0xA534, 0xAD55, 0xA4F4, 0x526A, 0x526A, 0x5249, 0x5229, 0x5249, 0x5229, 0x5208, 0x3124, 0x49E6, 0x5227, 0x3964, 0x1020, 0x41A6,   // 0x0E50 (3664) pixels
0x3165, 0x1882, 0x1862, 0xA4B2, 0xBD96, 0x93F0, 0x82AB, 0x7A29, 0x79E8, 0x71A7, 0x71A6, 0x69A6, 0x69C6, 0x69C6, 0x69C6, 0x69E6,   // 0x0E60 (3680) pixels
0x69E6, 0x69C6, 0x69A5, 0x61A5, 0x61A4, 0x5984, 0x5984, 0x5143, 0x5143, 0x5143, 0x5964, 0x5123, 0x4903, 0x40E2, 0x38C2, 0x38C2,   // 0x0E70 (3696) pixels
0x2881, 0x2881, 0x2041, 0x2882, 0x28C4, 0x28E3, 0x4A07, 0x49C7, 0x3965, 0x18A2, 0x1061, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E80 (3712) pixels
0x9492, 0xAD76, 0x9CD3, 0x5AEC, 0x528B, 0x526B, 0x41C8, 0x41E8, 0x5A6A, 0x6B0C, 0x41A6, 0x3123, 0x5227, 0x4A06, 0x2902, 0x1881,   // 0x0E90 (3728) pixels
0x4A07, 0x28E3, 0x1021, 0x3986, 0x9C93, 0x93CF, 0x8B0C, 0x8AAA, 0x8228, 0x79E7, 0x71E6, 0x71E6, 0x71E6, 0x71E6, 0x71E6, 0x71E6,   // 0x0EA0 (3744) pixels
0x69C5, 0x69C5, 0x69C5, 0x69C5, 0x61C5, 0x61A4, 0x5984, 0x5963, 0x5964, 0x5964, 0x5143, 0x5123, 0x4902, 0x40E2, 0x40E2, 0x30C2,   // 0x0EB0 (3760) pixels
0x30C2, 0x2061, 0x28A2, 0x1841, 0x3105, 0x20A3, 0x2904, 0x49E8, 0x49C7, 0x3145, 0x18A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0EC0 (3776) pixels
0xB5B6, 0x8C51, 0x8431, 0x528B, 0x4A6A, 0x4A4A, 0x39A7, 0x39A7, 0x524A, 0x5A6A, 0x5228, 0x49E6, 0x49E6, 0x5A46, 0x41A4, 0x1840,   // 0x0ED0 (3792) pixels
0x1861, 0x3124, 0x3125, 0x1841, 0x41C7, 0x838E, 0x8B4D, 0x82EB, 0x82EA, 0x7AA9, 0x7AA9, 0x7A89, 0x7A68, 0x7A47, 0x7A47, 0x7A47,   // 0x0EE0 (3808) pixels
0x7A47, 0x7A47, 0x7A46, 0x7205, 0x61A4, 0x5984, 0x5984, 0x5984, 0x5984, 0x5964, 0x5143, 0x5123, 0x48E2, 0x4903, 0x38C2, 0x38E3,   // 0x0EF0 (3824) pixels
0x30A2, 0x2882, 0x28A2, 0x2083, 0x20A3, 0x28E4, 0x41A6, 0x49E7, 0x5228, 0x3145, 0x0820, 0x0000, 0x0000, 0x0000, 0x0000, 0x0820,   // 0x0F00 (3840) pixels
0xB596, 0xA555, 0x630C, 0x5ACB, 0x526A, 0x524A, 0x2925, 0x20E5, 0x528B, 0x5A8A, 0x5A48, 0x5227, 0x5A47, 0x6AE9, 0x49E5, 0x20A1,   // 0x0F10 (3856) pixels
0x1820, 0x1841, 0x2082, 0x4166, 0x28C3, 0x1020, 0x28E3, 0x3965, 0x3965, 0x3944, 0x28E3, 0x3103, 0x7B0B, 0x830B, 0x82E9, 0x82A8,   // 0x0F20 (3872) pixels
0x7A87, 0x7A67, 0x7A67, 0x7206, 0x61A5, 0x5985, 0x5985, 0x61A5, 0x5984, 0x5163, 0x5143, 0x4923, 0x4903, 0x40E3, 0x38C3, 0x30A2,   // 0x0F30 (3888) pixels
0x30C3, 0x30C3, 0x28A3, 0x2083, 0x3105, 0x2905, 0x3125, 0x39A6, 0x41C6, 0x20E3, 0x0820, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841,   // 0x0F40 (3904) pixels
0xA514, 0x5AEB, 0x4A49, 0x52AA, 0x4A29, 0x524A, 0x2945, 0x1083, 0x41E9, 0x5A8B, 0x5228, 0x5248, 0x5A68, 0x734B, 0x5A88, 0x3103,   // 0x0F50 (3920) pixels
0x1860, 0x2082, 0x1841, 0x1841, 0x49E7, 0x3103, 0x1000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x3144, 0x836C, 0x82E9, 0x7A88,   // 0x0F60 (3936) pixels
0x82A8, 0x82A9, 0x7A88, 0x7227, 0x61C5, 0x61A5, 0x61A5, 0x61A5, 0x5984, 0x5163, 0x5143, 0x5144, 0x4903, 0x40E3, 0x40E3, 0x30C3,   // 0x0F70 (3952) pixels
0x38E3, 0x38E4, 0x30E4, 0x3105, 0x3926, 0x3125, 0x3146, 0x49E8, 0x3985, 0x1882, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0821,   // 0x0F80 (3968) pixels
0x9CF3, 0x4A8A, 0x4229, 0x4A49, 0x41C8, 0x524A, 0x3166, 0x1083, 0x2105, 0x4A08, 0x41A6, 0x5228, 0x5A69, 0x732B, 0x6AEA, 0x41A5,   // 0x0F90 (3984) pixels
0x28E2, 0x2062, 0x1841, 0x2062, 0x28C2, 0x51E7, 0x3124, 0x0800, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x41C6, 0x830B, 0x7AA8,   // 0x0FA0 (4000) pixels
0x7A68, 0x7AA9, 0x7AA9, 0x7268, 0x6A06, 0x61E6, 0x61C5, 0x5984, 0x5984, 0x5984, 0x5984, 0x5144, 0x4923, 0x4924, 0x40E3, 0x4104,   // 0x0FB0 (4016) pixels
0x3904, 0x3904, 0x4145, 0x3946, 0x41A8, 0x5209, 0x522A, 0x41A7, 0x20A3, 0x0820, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0FC0 (4032) pixels
0x8451, 0x632D, 0x4208, 0x4A29, 0x39A7, 0x4A29, 0x2945, 0x0862, 0x20C4, 0x41C8, 0x41A7, 0x4A08, 0x62AA, 0x7B2C, 0x72EA, 0x6267,   // 0x0FD0 (4048) pixels
0x49E6, 0x28E2, 0x1861, 0x28E3, 0x30E3, 0x3124, 0x4186, 0x3124, 0x1061, 0x0820, 0x0800, 0x0000, 0x0000, 0x1020, 0x72EA, 0x82C9,   // 0x0FE0 (4064) pixels
0x7247, 0x7A88, 0x82C9, 0x7A88, 0x7227, 0x6A06, 0x61E6, 0x61A5, 0x5984, 0x5984, 0x5164, 0x5143, 0x5144, 0x4903, 0x4104, 0x4145,   // 0x0FF0 (4080) pixels
0x3904, 0x4186, 0x730C, 0x5A49, 0x49C8, 0x3966, 0x3105, 0x28A3, 0x2062, 0x1841, 0x0821, 0x0820, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1000 (4096) pixels
const unsigned short sleeping[3840] PROGMEM={
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0010 (16) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000,   // 0x0020 (32) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0030 (48) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0040 (64) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0050 (80) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000,   // 0x0060 (96) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0070 (112) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0080 (128) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0090 (144) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0xF7B8,   // 0x00A0 (160) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00B0 (176) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00C0 (192) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00D0 (208) pixels
0x0000, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x00E0 (224) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00F0 (240) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0100 (256) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0110 (272) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x0120 (288) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0130 (304) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0140 (320) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF7B8,   // 0x0150 (336) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x0160 (352) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0170 (368) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0180 (384) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF7B8,   // 0x0190 (400) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF798, 0xEF18, 0xDE98, 0xCDF7, 0xC537, 0xB457, 0xF798, 0xF7B8,   // 0x01A0 (416) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01B0 (432) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01C0 (448) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF7B8, 0xF7B8,   // 0x01D0 (464) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xE718, 0xCD97, 0xBCD7, 0xABF7, 0xABF7, 0xABF7, 0xABF7, 0xABF7, 0xABF7, 0xEF38, 0xF7B8,   // 0x01E0 (480) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01F0 (496) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0200 (512) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF7B8, 0xF7B8,   // 0x0210 (528) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xE718, 0xABF7, 0xABF7, 0xABF7, 0xABF7, 0xABF7, 0xABF7, 0xABF7, 0xABF7, 0xE6D8, 0xF7B8,   // 0x0220 (544) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0230 (560) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0240 (576) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF7B8, 0xF7B8,   // 0x0250 (592) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF798, 0xAC17, 0xABF7, 0xAC17, 0xBD17, 0xC557, 0xABF7, 0xABF7, 0xAC37, 0xEF38, 0xF7B8,   // 0x0260 (608) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0270 (624) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0280 (640) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF7B8,   // 0x0290 (656) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xE6D8, 0xEF38, 0xF7B8, 0xF7B8, 0xC557, 0xABF7, 0xABF7, 0xDE78, 0xF7B8, 0xF7B8,   // 0x02A0 (672) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xE717, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A50, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02B0 (688) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02C0 (704) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF7B8,   // 0x02D0 (720) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xDE98, 0xABF7, 0xABF7, 0xC577, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x02E0 (736) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xA574, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A50, 0x0000, 0x0000, 0x0000,   // 0x02F0 (752) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0300 (768) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF7B8,   // 0x0310 (784) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xEF58, 0xB437, 0xABF7, 0xB477, 0xEF78, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x0320 (800) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xBE15, 0x1A70, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x0000,   // 0x0330 (816) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0340 (832) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF7B8, 0xF7B8,   // 0x0350 (848) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xC557, 0xABF7, 0xABF7, 0xE6F8, 0xF7B8, 0xEF58, 0xDEB8, 0xEF58,   // 0x0360 (864) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xD6B6, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0370 (880) pixels
0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0380 (896) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF7B8, 0xF7B8,   // 0x0390 (912) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xDE98, 0xABF7, 0xABF7, 0xB497, 0xC577, 0xB477, 0xABF7, 0xABF7, 0xDE78,   // 0x03A0 (928) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x63B1, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x03B0 (944) pixels
0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03C0 (960) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF7B8,   // 0x03D0 (976) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xB437, 0xABF7, 0xABF7, 0xABF7, 0xABF7, 0xABF7, 0xABF7, 0xABF7, 0xCDD7,   // 0x03E0 (992) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x6BF1, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A70, 0x5372, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x03F0 (1008) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0400 (1024) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF7B8,   // 0x0410 (1040) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xB4B7, 0xABF7, 0xABF7, 0xABF7, 0xABF7, 0xABF7, 0xABF7, 0xBCB7, 0xD618,   // 0x0420 (1056) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xD6B6, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x8495, 0xEF9E, 0x8495, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0430 (1072) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A50, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0440 (1088) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A70, 0x2270,   // 0x0450 (1104) pixels
0xADB4, 0xDEF7, 0xE737, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xC577, 0xB4B7, 0xC577, 0xD618, 0xDE98, 0xEF38, 0xF798, 0xF7B8, 0xF7B8,   // 0x0460 (1120) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xD6B6, 0x3AF0, 0x1A4F, 0x1A4F, 0x1A4F, 0x4B31, 0xF7DF, 0xC63A, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0470 (1136) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0480 (1152) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A50, 0x1A4F, 0x1A4F,   // 0x0490 (1168) pixels
0x1A4F, 0x1A4F, 0xA574, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x04A0 (1184) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xDEF7, 0x2AB0, 0x1A4F, 0x1A4F, 0x1A4F, 0xA557, 0xFFFF, 0xA557, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x04B0 (1200) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04C0 (1216) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x04D0 (1232) pixels
0x1A4F, 0x1A4F, 0x7412, 0xF7B8, 0xF7B8, 0xF7B8, 0xF798, 0xCEB6, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x04E0 (1248) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x7C52, 0x1A4F, 0x1A4F, 0x1A4F, 0xB5D8, 0xFFFF, 0xADB8, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x04F0 (1264) pixels
0x1A4F, 0x1A6F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0500 (1280) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0510 (1296) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0xA554, 0xDF17, 0xCE96, 0x7411, 0x2AB0, 0xC655, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xEF58, 0xBE15, 0xF7B8,   // 0x0520 (1312) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xEF78, 0x4B30, 0x1A4F, 0x1A4F, 0x1A4F, 0x8474, 0xFFFF, 0xE73D, 0x2270, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0530 (1328) pixels
0x1A70, 0x8DF9, 0x4392, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0540 (1344) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0550 (1360) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x7411, 0xAD94, 0xBE15, 0xA554, 0x4B10, 0x1A4F, 0xA574,   // 0x0560 (1376) pixels
0xDF17, 0xE757, 0xD6B6, 0x7C32, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A6F, 0xD6DB, 0xFFFF, 0xD6BB, 0x5372, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0570 (1392) pixels
0x1A70, 0x7D77, 0x3311, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0580 (1408) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0590 (1424) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x05A0 (1440) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x2AB0, 0x2290, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A70, 0xA577, 0xCE9B, 0xB5D9, 0x3AF1, 0x1A4F, 0x1A4F,   // 0x05B0 (1456) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x5B71, 0x8472, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x05C0 (1472) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x05D0 (1488) pixels
0x1A4F, 0x1A4F, 0x32F1, 0x4392, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x05E0 (1504) pixels
0x1A4F, 0x1A4F, 0x9513, 0xF798, 0xEF58, 0x63B1, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x05F0 (1520) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x4B30, 0xE757, 0xF7B8, 0x63D1, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0600 (1536) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0610 (1552) pixels
0x1A4F, 0x1A70, 0x8E19, 0x965A, 0x2AD0, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0620 (1568) pixels
0x1A4F, 0x1A4F, 0xADB4, 0xF7B8, 0xF7B8, 0x7432, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0630 (1584) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0xB5F5, 0xF7B8, 0xF7B8, 0x7432, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0640 (1600) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0650 (1616) pixels
0x1A4F, 0x1A4F, 0x64B5, 0x6CD5, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0660 (1632) pixels
0x1A4F, 0x1A4F, 0x1A6F, 0x6BF1, 0x5B91, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0670 (1648) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A6F, 0xEF58, 0xF7B8, 0xF7B8, 0x6BF1, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0680 (1664) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0690 (1680) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x06A0 (1696) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x06B0 (1712) pixels
0x32B0, 0x7C52, 0xAD94, 0xCE96, 0xF7B8, 0xF7B8, 0xEF78, 0x2270, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x06C0 (1728) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x06D0 (1744) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x2290, 0x7557, 0x2AB0, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x06E0 (1760) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x2270, 0x8472, 0xB5D5, 0xD6D6,   // 0x06F0 (1776) pixels
0xF798, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xC635, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0700 (1792) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0710 (1808) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A70, 0x6CD5, 0x2AB0, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0720 (1824) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x226F, 0x328F, 0x1A4F, 0x1A4F, 0x1A6F, 0x7C52, 0xC655, 0xEF78, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x0730 (1840) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xC635, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0740 (1856) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0750 (1872) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0760 (1888) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x2A8F, 0xD591, 0xEE11, 0xBD11, 0xA574, 0xE717, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x0770 (1904) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x7432, 0x1A4F, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0780 (1920) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0790 (1936) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x07A0 (1952) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x7390, 0xEE11, 0xEE11, 0xEE11, 0xF798, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x07B0 (1968) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xDED7, 0x1A4F, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x07C0 (1984) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x07D0 (2000) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x07E0 (2016) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x6350, 0xB4B0, 0xEE11, 0xEE11, 0xEE31, 0xF6B4, 0xF6D5, 0xEEF5, 0xF798, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x07F0 (2032) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x8CD3, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0800 (2048) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0810 (2064) pixels
0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0820 (2080) pixels
0x1A4F, 0x7BB0, 0xD571, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEDD0, 0xD4CB, 0xE693, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x0830 (2096) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xD6B6, 0x1A4F, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0840 (2112) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0850 (2128) pixels
0x1A6F, 0x4BB1, 0x5C8F, 0x5CEF, 0x7D53, 0x7D13, 0x7D13, 0x4331, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x226F,   // 0x0860 (2144) pixels
0xB4D0, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xE5B0, 0xCC48, 0xD56E, 0xF777, 0xF7B8,   // 0x0870 (2160) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x5B71, 0x1A4F, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0880 (2176) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x4B91, 0x7D95,   // 0x0890 (2192) pixels
0x8E78, 0xAEF6, 0x7E4E, 0x864F, 0xAF16, 0xB717, 0xB717, 0x9DD7, 0x9576, 0x7494, 0x3B11, 0x1A4F, 0x1A4F, 0x1A4F, 0x3AB0, 0xCD51,   // 0x08A0 (2208) pixels
0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xDD2D, 0xCC48, 0xD50C, 0xF777,   // 0x08B0 (2224) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xB5B4, 0x1A50, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x08C0 (2240) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x2AF0, 0x654F, 0xA6D5, 0x8E99,   // 0x08D0 (2256) pixels
0xA6D8, 0xA6D4, 0x7E4E, 0x8E91, 0xB717, 0xB717, 0xAED7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DB7, 0x7CF5, 0x4331, 0x1A4F, 0xBD11, 0xEE11,   // 0x08E0 (2272) pixels
0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEDF1, 0xEE11, 0xEDF1, 0xCC48, 0xCC48, 0xD50D,   // 0x08F0 (2288) pixels
0xF798, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xEF78, 0xF798, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0900 (2304) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x5C31, 0x7E0F, 0x864F, 0xB716, 0x7E5A,   // 0x0910 (2320) pixels
0xAEF7, 0x9EB3, 0x7E4E, 0x9EB3, 0xB717, 0xB717, 0xAE97, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DB7, 0xA513, 0xEE11, 0xEE11,   // 0x0920 (2336) pixels
0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEDD0, 0xE590, 0xEE11, 0xEE11, 0xEE11, 0xEDD0, 0xDD2D, 0xEE11, 0xDCEC, 0xCC48, 0xCC48,   // 0x0930 (2352) pixels
0xE632, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0940 (2368) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x9E55, 0xA6D5, 0x7E4E, 0x8E70, 0xB717, 0x765A,   // 0x0950 (2384) pixels
0xB717, 0x9691, 0x7E4E, 0xA6D5, 0xB717, 0xB717, 0xA657, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0xE612, 0xEE11, 0xEE11,   // 0x0960 (2400) pixels
0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xDD4F, 0xD54F, 0xEE11, 0xEDB0, 0xE5AF, 0xCC48, 0xE56E, 0xE56E, 0xCC48, 0xCC48,   // 0x0970 (2416) pixels
0xCC69, 0xF777, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0980 (2432) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x661B, 0xA6D7, 0x9EB4, 0x7E4E, 0x9692, 0xAEF7, 0x7E5A,   // 0x0990 (2448) pixels
0xB717, 0x8E70, 0x7E4E, 0xAEF5, 0xB717, 0xB717, 0x9E17, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0xB5D6, 0xEE11, 0xEE11, 0xEE11,   // 0x09A0 (2464) pixels
0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xC46C, 0xEE11, 0xE58F, 0xDD0D, 0xCC89, 0xCC48, 0xD48A, 0xCC48, 0xCC48,   // 0x09B0 (2480) pixels
0xCC48, 0xE694, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x09C0 (2496) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xB717, 0x7E5A, 0xAEF7, 0x9EB3, 0x7E4E, 0x9EB3, 0xAEF7, 0x867A,   // 0x09D0 (2512) pixels
0xB717, 0x8E70, 0x7E4E, 0xAEF6, 0xB717, 0xB717, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0xC5F5, 0xEE11, 0xEE11, 0xEE11,   // 0x09E0 (2528) pixels
0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xDD6F, 0xDD6F, 0xEE11, 0xE58F, 0xCC48, 0xD4EC, 0xCC48, 0xCC48, 0xCC48, 0xCC48,   // 0x09F0 (2544) pixels
0xCC48, 0xDD8F, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0A00 (2560) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x7E4E, 0xAEF6, 0x7E5A, 0xB717, 0x9EB3, 0x7E4E, 0x9EB4, 0xA6F7, 0x8679,   // 0x0A10 (2576) pixels
0xB717, 0x8E70, 0x7E4E, 0xAEF6, 0xB717, 0xAEF7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0xD5F4, 0xEE11, 0xEDF1, 0xE5B0,   // 0x0A20 (2592) pixels
0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEDF1, 0xE5B0, 0xEE11, 0xEE11, 0xE58F, 0xCC48, 0xCC69, 0xCC48, 0xCC48, 0xCC48, 0xCC48,   // 0x0A30 (2608) pixels
0xCC48, 0xD50D, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0A40 (2624) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x864F, 0x7E4E, 0xAEF6, 0x765A, 0xB717, 0x9692, 0x7E4E, 0x9EB4, 0xA6D8, 0x8E99,   // 0x0A50 (2640) pixels
0xB717, 0x8E70, 0x7E4E, 0xAF16, 0xB717, 0xAED7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0xD5F3, 0xEE11, 0xC48C, 0xEDF1,   // 0x0A60 (2656) pixels
0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xE5AF, 0xCC48, 0xCC48, 0xCC48, 0xCC48, 0xCC48, 0xCC48,   // 0x0A70 (2672) pixels
0xCC48, 0xD50C, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0A80 (2688) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x7E4E, 0x7E4E, 0xAF16, 0x765A, 0xB717, 0x9692, 0x7E4E, 0x9EB4, 0xA6D8, 0x8679,   // 0x0A90 (2704) pixels
0xB717, 0x8E70, 0x7E4E, 0xAEF6, 0xB717, 0xAEB7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0xD5F3, 0xE5B0, 0xCCED, 0xEE11,   // 0x0AA0 (2720) pixels
0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xE5B0, 0xCC48, 0xCC48, 0xCC48, 0xCC48, 0xCC48, 0xCC48,   // 0x0AB0 (2736) pixels
0xCC48, 0xD50D, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0AC0 (2752) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xB717, 0x864F, 0x7E4E, 0xAF16, 0x7E5A, 0xB717, 0x9EB3, 0x7E4E, 0x9EB4, 0xA6D7, 0x867A,   // 0x0AD0 (2768) pixels
0xB717, 0x8E70, 0x7E4E, 0xAEF6, 0xB717, 0xAE97, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0x9DD7, 0xCDF4, 0xEE11, 0xCCEE, 0xEE11,   // 0x0AE0 (2784) pixels
0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEDF1, 0xCC48, 0xCC48, 0xCC48, 0xCC48, 0xCC48, 0xCC48,   // 0x0AF0 (2800) pixels
0xCC48, 0xD56E, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000,   // 0x0B00 (2816) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0xB717, 0xB717, 0x864F, 0x7E4E, 0xAF16, 0x7E5A, 0xB717, 0x9EB3, 0x7E4E, 0x9692, 0xAEF7, 0x7E7A,   // 0x0B10 (2832) pixels
0xB717, 0x8E71, 0x7E4E, 0xA6D5, 0xB717, 0xAEB7, 0x9596, 0x8D35, 0x9DD7, 0x9DD7, 0x8D35, 0x7CD4, 0xA534, 0xEE11, 0xEDF1, 0xE5B0,   // 0x0B20 (2848) pixels
0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xD48A, 0xCC48, 0xCC48, 0xCC48, 0xCC48, 0xCC48,   // 0x0B30 (2864) pixels
0xCC48, 0xE673, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000,   // 0x0B40 (2880) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x9EB8, 0xB717, 0x864F, 0x7E4E, 0xAEF6, 0x867A, 0xAEF7, 0xA6D4, 0x7E4E, 0x9691, 0xB717, 0x7E5A,   // 0x0B50 (2896) pixels
0xB717, 0x9692, 0x7E4E, 0xA6D4, 0xB717, 0xA676, 0x1A70, 0x1A4F, 0x8D36, 0x9DD7, 0x84F5, 0x1A4F, 0x226F, 0xE5D1, 0xEE11, 0xEE11,   // 0x0B60 (2912) pixels
0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xDD6F, 0xD52E, 0xEE11, 0xEE11, 0xDD0C, 0xCC48, 0xCC48, 0xCC48, 0xCC48, 0xCC48,   // 0x0B70 (2928) pixels
0xCC48, 0xF777, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000,   // 0x0B80 (2944) pixels
0x0000, 0x0000, 0x0000, 0x9679, 0x867A, 0xB717, 0x8E70, 0x7E4E, 0xAEF6, 0x8E99, 0xA6D8, 0xA6D5, 0x7E4E, 0x8670, 0xB717, 0x7E5A,   // 0x0B90 (2960) pixels
0xAEF7, 0x9EB3, 0x7E4E, 0x9692, 0xB717, 0xAED6, 0x1A6F, 0x1A4F, 0x5BF2, 0x9DD7, 0x9DB7, 0x4B71, 0x1A4F, 0xA470, 0xEE11, 0xEE11,   // 0x0BA0 (2976) pixels
0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xCCED, 0xE5B0, 0xEE11, 0xE58F, 0xCC48, 0xCC48, 0xCC48, 0xCC48, 0xCC48,   // 0x0BB0 (2992) pixels
0xDDD0, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000,   // 0x0BC0 (3008) pixels
0x0000, 0xEE11, 0xEE11, 0xCEB5, 0x7E5A, 0xB717, 0x9691, 0x7E4E, 0xA6D5, 0x9EB8, 0x96B8, 0xAEF6, 0x7E4E, 0x7E4E, 0xAF16, 0x8E99,   // 0x0BD0 (3024) pixels
0xA6D8, 0xAEF5, 0x7E4E, 0x8670, 0xB717, 0xB717, 0x4371, 0x1A4F, 0x1A6F, 0x8D35, 0x9DD7, 0x9576, 0x3AF0, 0x1A4F, 0xCD51, 0xEE11,   // 0x0BE0 (3040) pixels
0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xD50E, 0xE5B0, 0xEE11, 0xEE11, 0xD48A, 0xCC48, 0xCC48, 0xCC48, 0xD4CB,   // 0x0BF0 (3056) pixels
0xF777, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000,   // 0x0C00 (3072) pixels
0x0000, 0xEE11, 0xEE11, 0xB6F6, 0x7E5A, 0xB717, 0x9EB3, 0x7E4E, 0x9EB3, 0xA6F7, 0x867A, 0xB717, 0x8E71, 0x7E4E, 0xA6D5, 0x9ED8,   // 0x0C10 (3088) pixels
0x8E99, 0xB717, 0x864F, 0x7E4E, 0xAEF6, 0xB717, 0x6CB2, 0x1A4F, 0x1A4F, 0x3B11, 0x9596, 0x9DD7, 0x8D56, 0x3B11, 0x4AF0, 0xDDB1,   // 0x0C20 (3104) pixels
0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xE5D0, 0xDD6F, 0xEE11, 0xEE11, 0xEE11, 0xE56F, 0xCC48, 0xCC48, 0xCC8A, 0xEF36,   // 0x0C30 (3120) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000,   // 0x0C40 (3136) pixels
0xEE11, 0xEE11, 0xEE11, 0xB717, 0x867A, 0xAEF7, 0xA6D5, 0x7E4E, 0x8E91, 0xB717, 0x765A, 0xAF17, 0x9EB3, 0x7E4E, 0x9692, 0xAEF7,   // 0x0C50 (3152) pixels
0x7E5A, 0xB717, 0x9692, 0x7E4E, 0x9EB4, 0xB717, 0x9E35, 0x1A4F, 0x1A4F, 0x1A4F, 0x4351, 0x9576, 0x9DD7, 0x9DB7, 0x7CF5, 0x7453,   // 0x0C60 (3168) pixels
0xDDD2, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xD4CB, 0xD4CB, 0xEF36, 0xF7B8,   // 0x0C70 (3184) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x0C80 (3200) pixels
0xEE11, 0xEE11, 0xEE11, 0xB717, 0x96B9, 0x9EB8, 0xAEF6, 0x7E4E, 0x7E4E, 0xAEF6, 0x8E99, 0xA6D8, 0xAEF5, 0x7E4E, 0x864F, 0xB717,   // 0x0C90 (3216) pixels
0x7E7A, 0xAEF7, 0xA6D4, 0x7E4E, 0x8E91, 0xB717, 0xB717, 0xAEF6, 0x1A4F, 0x1A4F, 0x1A4F, 0x2A90, 0x6C53, 0x8515, 0x9596, 0x9596,   // 0x0CA0 (3232) pixels
0xADF7, 0xE695, 0xEE32, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEE11, 0xEEB4, 0xF798, 0xF7B8, 0xF7B8,   // 0x0CB0 (3248) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x0CC0 (3264) pixels
0x0000, 0xEE11, 0xEE11, 0xB6F6, 0xAEF7, 0x867A, 0xB717, 0x8E71, 0x7E4E, 0xA6D4, 0x9ED8, 0x8E99, 0xB717, 0x864F, 0x7E4E, 0xA6D5,   // 0x0CD0 (3280) pixels
0x96B8, 0x9EB8, 0xAEF6, 0x7E4E, 0x7E4E, 0xAEF6, 0xB717, 0xB717, 0x0000, 0x0000, 0x0000, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F, 0x1A4F,   // 0x0CE0 (3296) pixels
0xD6B6, 0xF7B8, 0xF798, 0xF736, 0xF6B4, 0xF673, 0xEE32, 0xEE32, 0xF673, 0xF6B4, 0xF715, 0xF798, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x0CF0 (3312) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF798, 0xEF57, 0xE737, 0xE6F6, 0xDED6, 0xEF57, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x0D00 (3328) pixels
0x0000, 0xEE11, 0xEE11, 0xBED6, 0xB717, 0x7E5A, 0xAF17, 0x9EB4, 0x7E4E, 0x9692, 0xAEF7, 0x765A, 0xB717, 0x9692, 0x7E4E, 0x9693,   // 0x0D10 (3344) pixels
0xAEF7, 0x867A, 0xB717, 0x8E91, 0x7E4E, 0xA6D4, 0xB717, 0xB717, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D20 (3360) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF798, 0xE737, 0xDED6,   // 0x0D30 (3376) pixels
0xD675, 0xCE15, 0xC5B4, 0xBD73, 0xBD73, 0xC5D4, 0xDEB6, 0xEF78, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x0D40 (3392) pixels
0x0000, 0xEE11, 0xEE11, 0xB717, 0xB717, 0x8E99, 0xA6D8, 0xAEF6, 0x7E4E, 0x864F, 0xAEF6, 0x8679, 0xA6D7, 0xA6D5, 0x7E4E, 0x866F,   // 0x0D50 (3408) pixels
0xB717, 0x7E7A, 0xAEF7, 0xA6D4, 0x7E4E, 0x9691, 0xB717, 0xB717, 0xB717, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D60 (3424) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF798, 0xE6F7, 0xD675, 0xC5D4, 0xBD73, 0xBD73, 0xBD73,   // 0x0D70 (3440) pixels
0xBD73, 0xBD73, 0xCE14, 0xDEB6, 0xEF57, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D80 (3456) pixels
0x0000, 0x0000, 0x0000, 0xB717, 0xB717, 0xA6D8, 0x8E99, 0xB717, 0x8E70, 0x7E4E, 0xA6D4, 0x9ED8, 0x8E99, 0xB717, 0x864F, 0x7E4E,   // 0x0D90 (3472) pixels
0xAEF6, 0x96B8, 0xA6D8, 0xAEF6, 0x7E4E, 0x864F, 0xAEF6, 0xB717, 0xB717, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0DA0 (3488) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF798, 0xDED6, 0xCE14, 0xBD73, 0xBD73, 0xC593, 0xC5D4, 0xCE15, 0xD675, 0xDED6,   // 0x0DB0 (3504) pixels
0xEF37, 0xF798, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0DC0 (3520) pixels
0x0000, 0x0000, 0x0000, 0xB717, 0xB717, 0xB717, 0x7E5A, 0xB717, 0x9EB3, 0x7E4E, 0x9692, 0xAEF7, 0x7E5A, 0xB717, 0x9EB4, 0x0000,   // 0x0DD0 (3536) pixels
0x0000, 0x0000, 0x0000, 0xB6F7, 0x864F, 0x864F, 0xA6D5, 0xB717, 0xB717, 0xB717, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0DE0 (3552) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xEF78, 0xEF78, 0xEF78, 0xF798, 0xF798, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8,   // 0x0DF0 (3568) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E00 (3584) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xAEF6, 0xA6D4, 0x864E, 0x8E71, 0xAEF7, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E10 (3600) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E20 (3616) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000,   // 0x0E30 (3632) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E40 (3648) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E50 (3664) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E60 (3680) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E70 (3696) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E80 (3712) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E90 (3728) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0EA0 (3744) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0EB0 (3760) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0EC0 (3776) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0ED0 (3792) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0EE0 (3808) pixels
0xF7B8, 0xF7B8, 0xF7B8, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0EF0 (3824) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0F00 (3840) pixels
// variables to define sleep time; the first multiplies the value to get seconds from microseconds; the second says the sleep time in seconds (1200 = 20 minutes)
uint64_t uS_TO_S_FACTOR = 1000000;
uint64_t TIME_TO_SLEEP = 60; //sleep for 1 minute
String dataMessage;
// setting a counter for data readings; it will increase every time data from sensors are collected
RTC_DATA_ATTR int sensor_data = 0;
// initializing string data to save data collected from sensors
String Data;
#define sensor_data(temp,hum);
  delay(100);
 SPI.begin(PIN_CLK, PIN_MISO, PIN_MOSI);
// Initialize I2C with custom pins
    Wire.begin(I2C_SDA, I2C_SCL);
// initializing BME280
    bool status;
  status = bme.begin(0x76, &Wire);
  if (!status) {
    Serial.println("Could not find a valid BME280 sensor, check wiring!");
    while (1);
   // initializing the rtc
  if (!rtc.begin()) {
    Serial.println("Couldn't find RTC");
    Serial.flush();
    while (1) delay(10);
  if (rtc.lostPower()) {
    Serial.println("RTC lost power, let's set the time!");
    // When time needs to be set on a new device, or after a power loss, the
    // following line sets the RTC to the date & time this sketch was compiled
  rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
   // This line sets the RTC with an explicit date & time, for example to set
    // January 21, 2014 at 3am you would call:
  //rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
     DateTime now = rtc.now();
    char dateBuffer[12];
  sprintf(dateBuffer,"%02u-%02u-%04u ",now.day(),now.month(),now.year());
  Serial.print(dateBuffer);
  sprintf(dateBuffer,"%02u:%02u:%02u ",now.hour(),now.minute(),now.second());
  Serial.println(dateBuffer);
  //initializing SD card
      if (!SD.begin(PIN_CS_CARD) ) {
        sdOK = false;
        Serial.println("Card Mount Failed");
        sdOK = true;
        Serial.println("SDcard initialized!!");
  File file = SD.open("/data.txt");
  if(!file) {
    Serial.println("File doens't exist");
    Serial.println("Creating file...");
    writeFile(SD, "/data.txt", "dataMessage \r\n");
  else {
    Serial.println("File already exists");
  file.close();
  matrix->begin();
  matrix->clear();
  Read_TempHum();
  gettimeStamp();
  logSDCard();
  displayContent();
    // increasing the counter for the next data readings
  sensor_data++;
      // ESP32 going to sleep for the specified time
  esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
  Serial.println("Going to sleep...");
  delay(100); // Allow time for serial output
  esp_deep_sleep_start();
void gettimeStamp() {
void Read_TempHum(){
  Serial.print("Temperature = ");
  Serial.print(bme.readTemperature());
  Serial.println(" *C");
  Serial.print("Humidity = ");
  Serial.print(bme.readHumidity());
  Serial.println(" %");
  delay(5000);
  void logSDCard() {
dataMessage =  String(sensor_data) + ";"+String(dateBuffer)+ ";" +
              String(bme.readTemperature()) + ";" + String(bme.readHumidity()) + "\r\n";
  Serial.print("Save data: ");
  Serial.println(dataMessage);
  appendFile(SD, "/data.txt", dataMessage.c_str());
// Write to the SD card (DON'T MODIFY THIS FUNCTION)
void writeFile(fs::FS &fs, const char * path, const char * message) {
  Serial.printf("Writing file: %s\n", path);
  File file = fs.open(path, FILE_WRITE);
  if(!file) {
    Serial.println("Failed to open file for writing");
    return;
  if(file.print(message)) {
    Serial.println("File written");
    Serial.println("Write failed");
  file.close();
  // Append data to the SD card (DON'T MODIFY THIS FUNCTION)
void appendFile(fs::FS &fs, const char * path, const char * message) {
  Serial.printf("Appending to file: %s\n", path);
  File file = fs.open(path, FILE_APPEND);
  if(!file) {
    Serial.println("Failed to open file for appending");
    return;
    Serial.println("Message appended");
    Serial.println("Append failed");
  file.close();
void displayContent() {
  matrix->begin();
  matrix->setTextWrap(false);
  matrix->fillScreen(matrix->Color(0,255,0));
  matrix->show();
  matrix->clear();
  matrix->setTextWrap(true);  // we don't wrap text so it scrolls nicely
  matrix->setTextSize(1); // size 1 == 8 pixels high
  matrix->setCursor(2,0);
  matrix->setTextColor(LED_ORANGE_HIGH);
  matrix->print("T= ");// Don't wrap at end of line - will do ourselves
  matrix->setCursor(20, 0);
  matrix->print(bme.readTemperature());
  matrix->println(" C");
  matrix->setCursor(2, 10);
  matrix->setTextColor(LED_CYAN_HIGH);
  matrix->print("H= ");// Don't wrap at end of line - will do ourselves
  matrix->setCursor(20, 10);
  matrix->print(bme.readHumidity());
  matrix->println(" %");
  matrix->setCursor(2,20);
  matrix->setTextColor(LED_GREEN_HIGH);
  matrix->print(dateBuffer);
  matrix->setCursor(2,30);
  matrix->setRotation(0);
  matrix->setCursor(2,40);
  matrix->setTextColor(matrix->Color(255, 0,0));
  matrix->print("Ornella   e' bella e  buona");
  matrix->show();
  delay(5000);
  matrix->fillScreen(LED_BLACK);
  matrix->show();
  delay(100);
  matrix->drawRGBBitmap(1, 0, heart32, 64, 64);
  matrix->fillRect(0, 16, 64, 64, (matrix->Color(0, 32, 0)));
  matrix->setCursor(2,24);
  matrix->setTextColor(matrix->Color(255, 0, 0));
  matrix->print("W Ornella!");
  matrix->drawRGBBitmap(1, 40, heart32, 64, 64);
  matrix->fillRect(0, 56, 64, 64, (matrix->Color(0, 32, 0)));
  matrix->show();
  delay(2000);
  matrix->clear();
  matrix->drawRGBBitmap(0, 0, ORNELBIS, 64, 64);
  matrix->show();
  delay(3000);
  matrix->clear();
  matrix->fillScreen(matrix->Color(0, 0, 0));
  matrix->show();
  matrix->clear();
  matrix->setTextColor(matrix->Color(0, 255, 0));
  matrix->print("sleeping");
  matrix->setCursor(2,34);
  matrix->print("for 3 min");
  matrix->show();
  delay(2000);
  matrix->clear();
  matrix->show();
  matrix->clear();
  matrix->drawRGBBitmap(0, 0, sleeping, 64, 64);
  matrix->show();
  delay(4000);
  matrix->clear();
  matrix->show();
  matrix->clear();
Thanks for your help and have a nice day
