I needed multiple buttons and Modulino gave an impression of being suitable.
Then the confusion starts. First you goodle lots of contradicting info then you see Modulino.h recently changed name to Arduino_Modulino, and importing its main header file Arduino_Modulino.h open the gates to never ending missing files. First it requires vl53l4cd_class.h, once you found it, next one vl53l4ed_class.h pops up then Arduino_LSM6DSOX.h, and so on. I gave up after five unmotivated files for all kinds of sensors (preassure, time of flight, etc etc.
I'm used to crazy software but what happens when a newbe tries to use these products promissing easy start up to play.
Long vacations at Arduino's QA department?
They ask questions here, get answers, and learn the product... I suppose.
I have no experience with Modulino. So consider me a beginner.
I had a look at the Modulino Knob. That page has a section Tutorials and in that section a link to How To Use The Modulino Knob.
I followed that link and found Installing The Modulino Library. I followed those instructions, chose "Install All" and after that I had no problem compiling the "Buttons_Basic" example for an Uno WiFi R4.
What you might (I do not know) have done wrong is not installing the dependencies.
I don't know; you also might have to define "recently". The page with the installation instructions was last update on 09/06/2025.
By ”recently” I mean there enough many tutorials out there pointing out the old name.
And I did not get the Install All option. Strange…
Can you give one or two links to those tutorials? I don't know anything about the history of the modulino but you are more than likely right about the renaming; Arduino_Modulino.h contains one line which includes the (possibly) "old" Modulino.h.
#include "Modulino.h"
No idea why it changed.
Did you install using library manager? Or did you search the web, found Arduino_Modulino.h on github and installed that. I did find GitHub - arduino-libraries/Arduino_Modulino; if you installed that ZIP you will indeed not get the prompt and the additional libraries are missing; the latter might be an oversight from Arduino. You will only get the prompt if you use the library manager.
In this experiment I used Uno R4 wifi and neither Modulino or Arduino_Modulino was preinstalled in the Arduino IDE 2, so I had to fetch from git as zip. And the next one and so on.
Before I seen the name change (and got dead links from Arduino docs) I used google:
https://docs.arduino.cc/tutorials/modulino-buttons/how-buttons-ardu/#how-to-use-your-modulino
tells you to install AIPIc_Opta
and the link in " ou need the official Modulino library available here to use the Modulino Buttons." is dead.
old name
and some other 3rd party tutorials
after I installed all the zips the library manager in Arduino IDE 2 finds them ;D
Not quite. It shows that as the first entry in the library manager but it also tells / shows you to filter for Modulino. I note that the date of the article has now changed to 17/10/2025
and the article also changed slightly.
Where did you find that link? I know that Arduino.cc on a regular basis breaks links.
Thanks for that link. The only way to get that fixed is to contact the author (digikey in this case) and inform them about the problem; if you're a registered user on that forum you can probably leave a reply at that topic.
On that page I could not find if they mentioned where to get the Modulino library.
Note that including "Modulino.h" more than likely will still work (not tested). But that does not solve the problem of finding the complete library.
It should have been there in the first place; when I installed it to help you this morning Arduino_Modulino was already there. And I did not install it before.
