Problems with encoder and digital potentiometer. HELP
Hello.
So, recently I have been working in signal generator project evolving AD9850 DDS module, with success I did it the module works and see the signal module through oscilloscope and change the frequency with rotative encoder. But my objective is control the level (or amplitude) pin out signal of DDS module (zout1,zout2,Qout1,Qout2).
My attempts I get control the signal level with a analog potentiometer, but I thought ''Would be possible use a digital potentiometer with encoder to control the signal level?''. So I bought another rotative encoder and x9c103s digital potentiometer. I did research about it but nothing that I could fix it in this project. I still have doubts and difficulties with the programming and connections at this stage with the digital potentiometer and encoder to control the signal level. With someone have idea or suggestion I appreciate.
The video that I found with similar function.
That too
Site and code that I did adapt to my project.
Thats my code for now
#include <AD9850SPI.h>
#include <SPI.h>
#include <Wire.h>
// Pinos do AD9850
const int W_CLK_PIN = 13;
const int FQ_UD_PIN = 8;
const int RESET_PIN = 9;
// Pinos do Encoder KY-040
const int CLK_PIN = 2;
const int DT_PIN = 3;
const int SW_PIN = 4;
// Pino do Potenciômetro
const int POT_PIN = A0;
// Variáveis de frequência e amplitude
double freq = 0;
double trimFreq = 124999500;
int phase = 0;
float amplitudeVolts = 0;
// Variáveis do encoder
int encoderPos = 0;
int lastCLKState = HIGH;
// Variáveis para filtragem de leitura do potenciômetro
const int numReadings = 10;
int readings[numReadings];
int readIndex = 0;
int total = 0;
// Inicializa o LCD I2C (20x4)
LiquidCrystal_I2C lcd(0x27, 20, 4);
  // Inicializa o AD9850
  DDS.begin(W_CLK_PIN, FQ_UD_PIN, RESET_PIN);
  DDS.calibrate(trimFreq);
  // Configura os pinos do encoder
  pinMode(CLK_PIN, INPUT);
  pinMode(DT_PIN, INPUT);
  pinMode(SW_PIN, INPUT_PULLUP);
  pinMode(POT_PIN, INPUT);
  for (int i = 0; i < numReadings; i++) {
    readings[i] = 0;
  // Inicializa o LCD
  lcd.init();
  lcd.backlight(); // Liga a luz de fundo do LCD
  lcd.setCursor(0, 0);
  lcd.print("Freq: 0 Hz");
  lcd.setCursor(0, 1);
  lcd.print("Amp: 0.00 V");
  // Leitura do encoder
  int currentCLKState = digitalRead(CLK_PIN);
  if (currentCLKState != lastCLKState) {
    // Se o estado do CLK mudou, o encoder foi girado
    if (digitalRead(DT_PIN) != currentCLKState) {
      // Sentido horário: aumenta a frequência
      freq += 100; // Incremento de 100 Hz
      // Sentido anti-horário: diminui a frequência
      freq -= 100; // Decremento de 100 Hz
    // Limita a frequência entre 0 Hz e 1 MHz
    if (freq < 0) freq = 0;
    if (freq > 1000000) freq = 1000000;
    // Atualiza a frequência no AD9850
    DDS.setfreq(freq, phase);
    // Exibe a frequência atual no LCD
    lcd.print("Freq: ");
    lcd.print(freq);
    lcd.print(" Hz   "); // Espaços para limpar caracteres antigos
  lastCLKState = currentCLKState;
  // Leitura do potenciômetro com filtragem (média móvel)
  total -= readings[readIndex]; // Subtrai a leitura mais antiga
  readings[readIndex] = analogRead(POT_PIN); // Lê o valor do potenciômetro
  total += readings[readIndex]; // Adiciona a nova leitura ao total
  readIndex = (readIndex + 1) % numReadings; // Avança o índice
  int averagePotValue = total / numReadings;
  amplitudeVolts = (averagePotValue * 5.0) / 1023.0;
  // Exibe a amplitude em volts no LCD
  lcd.print("Amp: ");
  lcd.print(amplitudeVolts, 2); // Exibe com 2 casas decimais
  lcd.print(" V   "); // Espaços para limpar caracteres antigos
  if (digitalRead(SW_PIN) == LOW) {
    // Se o botão for pressionado, redefine a frequência para 0 Hz
    freq = 0;
    lcd.print("Freq: 0 Hz    ");
    delay(500); // Debounce do botão
  // Pequeno delay para evitar leituras muito rápidas
  delay(10);
Please extract necessary information and post it here. Watching videos, projects etc makes less helpers interested in Your post.
More useful information is found here: How to get the best out of this forum - Development Tools / IDE 1.x - Arduino Forum
have a look at generating-am-signal-using-arduino-uno
