I'm trying to Connect a Nano to a Mega, Via. the Nrf24l01 modules, and Keep getting error message from the Mega "init failed"
I think the problem may be in that I may have to connect the nrf24l01 to different pins on the mega then On the nano, but this is my first time using a Mega and I'm still relatively new to most of this.
It may have something to do with the Mosi, ss, and miso pins on the Mega being different. also a conflict in the future where I may need 2 as the DFplayer mini uses them as well, but I don't really understand any of that quite yet.
(Ultimately I'm trying to create a remote control using a series of buttons and a joystick module on the nano to control several functions, leds, a DFplayermini, and motors on the Mega)
For learning purposes I was trying to follow a video online and did the following:
I'm using the Radiohead Server and client examples to test and get started.
I have the Nrf24l01(s) connected to both boards Via. the 5v adapter modules
Pins are as follows for BOTH:
ce 8
csn 10
sck 13
mo 11
mi 12
iro xx (not used)
I have the Mega running the "server" example
and the Nano (remote control) running the "client" example.
Sketches:
// nrf24_server.pde
// -- mode: C++ --
// Example sketch showing how to create a simple messageing server
// with the RH_NRF24 class. RH_NRF24 class does not provide for addressing or
// reliability, so you should only use RH_NRF24 if you do not need the higher
// level messaging abilities.
// It is designed to work with the other example nrf24_client
// Tested on Uno with Sparkfun NRF25L01 module
// Tested on Anarduino Mini (http://www.anarduino.com/mini/) with RFM73 module
// Tested on Arduino Mega with Sparkfun WRL-00691 NRF25L01 module
#include <SPI.h>
#include <RH_NRF24.h>
// Singleton instance of the radio driver
RH_NRF24 nrf24;
// RH_NRF24 nrf24(8, 7); // use this to be electrically compatible with Mirf
// RH_NRF24 nrf24(8, 10);// For Leonardo, need explicit SS pin
// RH_NRF24 nrf24(8, 7); // For RFM73 on Anarduino Mini
while (!Serial)
; // wait for serial port to connect. Needed for Leonardo only
if (!nrf24.init())
Serial.println("init failed");
// Defaults after init are 2.402 GHz (channel 2), 2Mbps, 0dBm
if (!nrf24.setChannel(1))
Serial.println("setChannel failed");
if (!nrf24.setRF(RH_NRF24::DataRate2Mbps, RH_NRF24::TransmitPower0dBm))
Serial.println("setRF failed");
if (nrf24.available())
// Should be a message for us now
uint8_t buf[RH_NRF24_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);
if (nrf24.recv(buf, &len))
// NRF24::printBuffer("request: ", buf, len);
Serial.print("got request: ");
Serial.println((char*)buf);
// Send a reply
uint8_t data[] = "And hello back to you";
nrf24.send(data, sizeof(data));
nrf24.waitPacketSent();
Serial.println("Sent a reply");
Serial.println("recv failed");
// nrf24_client.pde
// -- mode: C++ --
// Example sketch showing how to create a simple messageing client
// It is designed to work with the other example nrf24_server.
#include <SPI.h>
RH_NRF24 nrf24;
while (!Serial)
if (!nrf24.init())
Serial.println("Sending to nrf24_server");
// Send a message to nrf24_server
uint8_t data[] = "Hello World!";
// Now wait for a reply
if (nrf24.waitAvailableTimeout(500))
// Should be a reply message for us now
Serial.print("got reply: ");
Serial.println("No reply, is nrf24_server running?");
delay(400);
Can anyone help explain what Im doing wrong, if I'm on the right track, and/or if there is a simpler way to understand what I'm trying to do?
Thank you!
