Problems with setting a PID controller
Hello everyone,
I recently started working with Arduino. I am trying to program a speed control system. For this, I have a Nema23 with the TB6600 driver, the Arduino, and the target speed is set via an encoder. Everything has worked so far, and I was able to achieve speeds from -200 to 200 mm/s, but I noticed that at low speeds such as 5 mm/s, the speed is not actually 5 mm/s, but slower. In my case, the rotated object theoretically needs 25 seconds for one revolution, but in practice, one revolution takes about 5-6 seconds longer. For this reason, I purchased the AMT102 V2 to measure the actual speed and compensate for this control difference with the help of a PID controller. However, nothing happens when I change the constants of the P, I, and D components. According to the plot, my actual speed is always in the range of -2 and 2, even at a target speed of 5 mm/s. I'm slowly running out of ideas, as everything is actually connected correctly.
I'll add the code and maybe someone will find the error or can share their experience with me. I would be very grateful and look forward to a response.
#include <AccelStepper.h>
#include <PID_v1.h>
#include <Wire.h>
   MOTORPARAMETER
const int motorFullSteps = 200;
const int microsteps     = 16;
const float rohrDurchmesser = 41;
const int stepsPerRev = motorFullSteps * microsteps;
const float mmPerRev  = 3.1416 * rohrDurchmesser;
const float mmPerStep = mmPerRev / stepsPerRev;
/* ── Encoder Parameter ─────────────────────── */
const int encoderPPR = 1000; // Pulses per Revolution (ANPASSEN!)
const float mmPerEncStep = mmPerRev / encoderPPR;
/* ── Pins ───────────────────────────── */
const int encA = 18;
const int encB = 19;
const int rotaryCLK = 2;
const int rotaryDT  = 4;
const int rotarySW  = 5;
const int dirPin = 6;
const int stepPin = 7;
/* ── Variablen ──────────────────────── */
volatile long motorEncoderCount = 0;
long lastEncoderCount = 0;
float measuredSpeed = 0;
int lastRotaryCLK;
volatile int rotaryValue = 0;
float targetSpeed = 0;
float mmPerSecPerClick = 1.0;
/* ── PID Variablen ──────────────────── */
double input, output, setpoint;
double Kp = 10, Ki = 0.5, Kd = 0.0;
PID myPID(&input, &output, &setpoint, Kp, Ki, Kd, DIRECT);
/* ── Zusatz für Glättung / Deadband ───────── */
float filtSpeed = 0;
const float alpha = 0.3;
const float deadband_mmps = 0.5;
const float min_cmd_steps = 400;   // erstmal 0 zum Testen!
/* ── Objekte ────────────────────────── */
LiquidCrystal_I2C lcd(0x27,20,4);
AccelStepper stepper(AccelStepper::DRIVER, stepPin, dirPin);
/* ── Interrupt Routine ───── */
void readMotorEncoder() {
  bool a = digitalRead(encA);
  bool b = digitalRead(encB);
  if (a == b) motorEncoderCount++;
  else motorEncoderCount--;
/* ── SETUP ─────────────────────────── */
  lcd.init();
  lcd.backlight();
  lcd.setCursor(0,0);
  lcd.print("PID Drehzahlregelung");
  pinMode(rotaryCLK, INPUT_PULLUP);
  pinMode(rotaryDT,  INPUT_PULLUP);
  pinMode(rotarySW,  INPUT_PULLUP);
  lastRotaryCLK = digitalRead(rotaryCLK);
  pinMode(encA, INPUT_PULLUP);
  pinMode(encB, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(encA), readMotorEncoder, CHANGE);
  attachInterrupt(digitalPinToInterrupt(encB), readMotorEncoder, CHANGE);
  stepper.setMaxSpeed(8000);
  stepper.setAcceleration(1500);
  setpoint = 0;
  myPID.SetMode(AUTOMATIC);
  myPID.SetSampleTime(20);
  myPID.SetOutputLimits(-8000, 8000); // NEGATIVE erlaubt!
/* ── LOOP ─────────────────────────── */
  int clkState = digitalRead(rotaryCLK);
  if (clkState != lastRotaryCLK && clkState == HIGH) {
    if (digitalRead(rotaryDT) == LOW) rotaryValue--;
    else rotaryValue++;
    rotaryValue = constrain(rotaryValue, -200, 200); // NEGATIVE Werte erlaubt
    targetSpeed = rotaryValue * mmPerSecPerClick;
  lastRotaryCLK = clkState;
  static unsigned long lastTime = millis();
  unsigned long now = millis();
  float dt = (now - lastTime) / 1000.0;
  if (dt >= 0.02) {
    long delta = motorEncoderCount - lastEncoderCount;
    lastEncoderCount = motorEncoderCount;
    float rawSpeed = (delta * mmPerEncStep) / dt;
    filtSpeed += alpha * (rawSpeed - filtSpeed);
    measuredSpeed = filtSpeed;
    lastTime = now;
    input = measuredSpeed;
    if (fabs(targetSpeed) < deadband_mmps) {
      setpoint = 0;
      setpoint = targetSpeed;
    myPID.Compute();
    double cmd = output;
    if (setpoint == 0 && fabs(input) < deadband_mmps) {
      cmd = 0;
    } else if (cmd > 0 && cmd < min_cmd_steps) {
      cmd = min_cmd_steps;
    } else if (cmd < 0 && cmd > -min_cmd_steps) {
      cmd = -min_cmd_steps;
    stepper.setSpeed(cmd);
    stepper.runSpeed();
    // 🔎 Debug-Ausgabe
    double error = setpoint - input;
    Serial.print(setpoint);      Serial.print("\t");
    Serial.print(input);         Serial.print("\t");
    Serial.print(output);        Serial.print("\t");
    Serial.print(cmd);           Serial.print("\t");
    Serial.print(delta);         Serial.print("\t");
    Serial.println(rawSpeed);
  static unsigned long lastLCD = 0;
  if (millis() - lastLCD > 300) {
    lcd.setCursor(0,1);
    lcd.print("Soll: "); lcd.print(setpoint,1); lcd.print(" mm/s   ");
    lcd.setCursor(0,2);
    lcd.print("Ist : "); lcd.print(measuredSpeed,1); lcd.print(" mm/s   ");
    lcd.setCursor(0,3);
    lcd.print("Out : "); lcd.print(output,0); lcd.print(" steps/s   ");
    lastLCD = millis();
Moved to English language section of the forum
This is a linear speed. How does that translate to steps per second in your system?
Since a properly designed stepper-driven machine does not skip steps, why do you need feedback speed control, rather than simply command the step rate?
PID speed control is usually used with brushed DC motors.
Note: cross post to Hilfe bei der Einstellung eines PID Reglers where @uwefed raises the same question.
First of all, thank you for your reply! To provide more context, I have a pipe on my motor. This pipe is given a surface treatment, and this treatment must be carried out at a specific speed of between 0 and 200 mm/s. I would therefore like to determine the speed myself using the encoder. The motor and driver were already there, so I tried to implement this with the means at my disposal.
This is a circumferential speed.
The pipe circumferential speed is directly proportional to the step rate of the motor, which you set. PID is not useful.
Cross posting is against forum rules.
Thank you and sorry, that was my first post and I didn't know about cross posting.
