Speed control using PID controller
// Function prototypes
void encoderISR();
int pidControl(int setPoint, float actual);
// Pin definitions
const int motorPin1 = 7;   // Motor driver input pin 1
const int motorPin2 = 8;   // Motor driver input pin 2
const int enablePin = 9;   // Motor driver enable pin (PWM control)
const int encoderPinA = 2; // Encoder signal A pin
const int encoderPinB = 3; // Encoder signal B pin
// Constants and Variables
const int numReadings = 5;  // Number of readings for averaging
unsigned long readings[numReadings]; // Array to store pulse durations
int readIndex = 0;
unsigned long total = 0;
int average = 0;
volatile unsigned long lastTime = 0;
volatile unsigned long pulseDuration = 0;
const int PPR = 240; // Pulses Per Revolution (Adjust based on your encoder)
// PID constants
float Kp = 1.0;
float Ki = 0.5;
float Kd = 0.1;
float integral = 0;
float previousError = 0;
const long interval = 100; // Interval in milliseconds for PID calculations
// Desired and current speed
int desiredSpeed = 100; // Desired speed in RPM
float currentSpeed = 0;
  // Set motor pins as outputs
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  pinMode(enablePin, OUTPUT);
  // Set encoder pins as inputs
  pinMode(encoderPinA, INPUT);
  pinMode(encoderPinB, INPUT);
  // Attach interrupt to encoder pin A
  attachInterrupt(digitalPinToInterrupt(encoderPinA), encoderISR, FALLING);
  // Start Serial Monitor
  // Initialize lastTime
  lastTime = micros();
  noInterrupts();
  // Update readings
  total = total - readings[readIndex];
  readings[readIndex] = pulseDuration;
  total = total + readings[readIndex];
  readIndex = readIndex + 1;
  if (readIndex >= numReadings) {
    readIndex = 0;
  interrupts();
  // Calculate average pulse duration
  average = total / numReadings;
  // Calculate current speed (RPM)
  if (average > 0) {
    currentSpeed = (60.0 * 1000000.0) / (average * (float)PPR);
    currentSpeed = 0; // Avoid division by zero
  Serial.print("Average Pulse Duration: ");
  Serial.print(average);
  Serial.println(" microseconds");
  Serial.print("Current Speed: ");
  Serial.print(currentSpeed);
  Serial.println(" RPM");
  // PID control
  int pwmValue = pidControl(desiredSpeed, currentSpeed);
  // Set motor speed
  analogWrite(enablePin, pwmValue);
  // Print PID output and PWM value for debugging
  Serial.print("PID Output: ");
  Serial.print(pwmValue);
  Serial.println(" PWM");
  delay(100); // Delay to prevent overwhelming the serial monitor
// Encoder ISR
void encoderISR() {
  unsigned long currentTime = micros();
  pulseDuration = currentTime - lastTime;
  lastTime = currentTime;
// PID control function
int pidControl(int setPoint, float actual) {
  float error = setPoint - actual;
  integral += error * interval / 1000.0;
  float derivative = (error - previousError) / (interval / 1000.0);
  int output = Kp * error + Ki * integral + Kd * derivative;
  previousError = error;
  // Constrain output to PWM range
  return constrain(output, 0, 255);
will code work for speed control of a dc motor. I am using l293d motor driver, CH-N20-3 encoded dc motor and arduino uno
Much depend on the wiring, the schematics and facts told by datasheets.
All depends on your calibration constants:
You have to provide the best constants by trial and error on the final construction.
I did the wirings and tried this code , but the motor stays standstill. I test the driver and the motor using some basic code , it was fine. What might be wrong.
Ohh, I couldn't find proper datasheet for CH-N20-3( dc motor with encoder). Any sources?
Put some Serial.print(...) in your code to moitor what the PID puts out. On the datasheet, id you ask google for it you get as the first link https://www.pololu.com/file/0J1487/pololu-micro-metal-gearmotors_rev-5-1.pdf
Seller, manufactorer.
digitalWrite(motorPin1,HIGH);
digitalWrite(motorPin2,LOW);
analogWrite(enablePin,255);
It started working after I set the motor at full speed in the set up. Why it didn't work at first , it should work anyway. By the way it is slow in adjusting the speed. Any advice. THANKS FOR YOUR HELP.
#include <RunningAverage.h>
void encoderISR();
RunningAverage myRA(numReadings);
int average = 0;
volatile bool newPulse = false;
float Kp = 0.78;
float Ki = 0.58;
float Kd = 1.35;
float integral = 0;
float integralMin = 0;
float integralMax = 300;
int desiredSpeed = 150;
  myRA.clear();
  digitalWrite(motorPin1, HIGH);
  digitalWrite(motorPin2, LOW);
  analogWrite(enablePin, 128);
  noInterrupts();
  myRA.addValue(pulseDuration);
  average = myRA.getAverage();
  interrupts();
  if (average > 0) {
    currentSpeed = 0;
  Serial.print("Currentspeed:");
  Serial.println("");
  Serial.print("desiredspeed:");
  Serial.print(desiredSpeed);
  Serial.println("");
  delay(100);
void encoderISR() {
  integral = integral + error * interval / 1000.0;
  integral = constrain(integral, integralMin, integralMax);
will this work now?
Try it ...
