Process a binary word into 2 PWM outputs
I have had a project land on my desk involving an arduino. I have never looked at one before and have no experience programming one. (Thanks to staff shortages...)
Basic premise. I need to take an 8 bit binary word input from a raspberry pi and using the 1st 4 bits output a pwm signal on one pin and using the 2nd 4 bits output another pwm signal on another pin.
I found the servo library and was able to get the two signals to output based on voltage inputs from potentiometers but i now need to use the binary word.
Thanks for your Help.
Is that like :
1101 0011, such as '13' and '3' ?
So take the whole 8 bits, and do a logical bit-wise "AND" with 0000 1111 to get:
0000 0011, which will represent the value associated with the lower four bits.
Then take the original 8 bits again, and bit-wise "AND" with 1111 0000 to get:
1101 0000, which can then be shifted right by 4 bits......to give :
0000 1101, which will represent the value associated with the upper four bits.
Alternatively, take the original 8 bit word, then just shift right by four bits to get...
0000 1101, which also gives the value associated with the upper four bits.
Did you want the values 0 to 15 to represent something other than a servo angle from 0 to 15 degrees?
Note: When you right shift your byte, make sure it is unsigned. If not the sign-extension may be confusing.
For signedness: shift the byte first, then mask out the excess bits.
Please note that servo signals and PWM are somewhat different - which one do you really need?
