Processing(minim frequency energy) to arduino
Newbie here..
I'm using the sketch for frequency energy supplied in Processing and i want to use the 3 outputs of that (kick,share,hat) to trigger pins on the arduino. I have successfully communicated with the arduino using processing with the arduino_out sketch but am having trouble modifying the frequency energy code to output to the arduino. Any ideas?
Heres the supplied code:
  • Frequency Energy
  • by Damien Di Fede.
  • This sketch demonstrates how to use the BeatDetect object in FREQ_ENERGY mode.
  • You can use isKick, isSnare, isHat,
  • isRange, and isOnset(int) to track whatever kind
  • of beats you are looking to track, they will report true or false based on
  • the state of the analysis. To "tick" the analysis you must call detect
  • with successive buffers of audio. You can do this inside of draw,
  • but you are likely to miss some audio buffers if you do this. The sketch implements
  • an AudioListener called BeatListener so that it can call
  • detect on every buffer of audio processed by the system without repeating
  • a buffer or missing one.
  • This sketch plays an entire song so it may be a little slow to load.
import ddf.minim.;
import ddf.minim.analysis.
Minim minim;
AudioPlayer song;
BeatDetect beat;
BeatListener bl;
float kickSize, snareSize, hatSize;
size(512, 200);
smooth();
minim = new Minim(this);
song = minim.loadFile("marcus_kellis_theme.mp3", 2048);
song.play();
// a beat detection object that is FREQ_ENERGY mode that
// expects buffers the length of song's buffer size
// and samples captured at songs's sample rate
beat = new BeatDetect(song.bufferSize(), song.sampleRate());
// set the sensitivity to 300 milliseconds
// After a beat has been detected, the algorithm will wait for 300 milliseconds
// before allowing another beat to be reported. You can use this to dampen the
// algorithm if it is giving too many false-positives. The default value is 10,
// which is essentially no damping. If you try to set the sensitivity to a negative value,
// an error will be reported and it will be set to 10 instead.
beat.setSensitivity(300);
kickSize = snareSize = hatSize = 16;
// make a new beat listener, so that we won't miss any buffers for the analysis
bl = new BeatListener(beat, song);
textFont(createFont("SanSerif", 16));
textAlign(CENTER);
void draw()
background(0);
fill(255);
if ( beat.isKick() ) kickSize = 32;
if ( beat.isSnare() ) snareSize = 32;
if ( beat.isHat() ) hatSize = 32;
textSize(kickSize);
text("KICK", width/4, height/2);
textSize(snareSize);
text("SNARE", width/2, height/2);
textSize(hatSize);
text("HAT", 3*width/4, height/2);
kickSize = constrain(kickSize * 0.95, 16, 32);
snareSize = constrain(snareSize * 0.95, 16, 32);
hatSize = constrain(hatSize * 0.95, 16, 32);
void stop()
// always close Minim audio classes when you are finished with them
song.close();
// always stop Minim before exiting
minim.stop();
// this closes the sketch
super.stop();
yep. Done this awhile back.
See this bit
Copy it somewhere else in Draw and modify it to look like this.
if ( beat.isKick() ) port.write('A');
if ( beat.isSnare() ) port.write('B');
if ( beat.isHat() ) port.write('C');
In the arduino code write this in the event for serial reading.
digitalWrite(ledPin, HIGH);
delay(Change this to a number less then 20, Experiment);
digitalWrite(ledPin, LOW);
