Good gtardes dear community, I am trying to connect 2 plates MAX31865 to an arduino UNO. I understand that each board must have its own assigned CS pin, however, I have problems to implement it. I have used the code of another user that I found on the internet, however, I can only see the reading of a pt100, but not the two pt100. I leave the code with which I am working, I hope you can help me.
#include <Adafruit_MAX31865.h>
#include <SPI.h>
[code]
#include <SPI.h>
// use hardware SPI, just pass in the CS pin
Adafruit_MAX31865 max_1 = Adafruit_MAX31865(5);
Adafruit_MAX31865 max_2 = Adafruit_MAX31865(9);
// The value of the Rref resistor. Use 430.0!
#define RREF 430.0
SPI.begin();
max_1.begin(MAX31865_3WIRE); // set to 2WIRE or 4WIRE as necessary
max_2.begin(MAX31865_3WIRE);
//TERMOPAR 1
uint16_t rtd1 = max_1.readRTD();
Serial.print("RTD value1: ");
Serial.println(rtd1);
float ratio1 = rtd1;
ratio1 /= 32768;
Serial.print("Resistance1 = ");
Serial.println(RREF*ratio1,8);
Serial.print("Temperature1 = ");
Serial.println(max_1.temperature(100, RREF));
//TERMOPAR 2
uint16_t rtd2 = max_2.readRTD();
Serial.print("RTD value2: ");
Serial.println(rtd2);
float ratio2 = rtd2;
ratio2 /= 32768;
Serial.print("Resistance2 = ");
Serial.println(RREF*ratio2,8);
Serial.print("Temperature2 = ");
Serial.println(max_2.temperature(100, RREF));
// Check and print any faults
//TERMOPAR 1
//uint8_t fault1 = max_1.readFault();
//if (fault1) {
// Serial.print("Fault1 0x");
// Serial.println(fault1, HEX);
//if (fault1 & MAX31865_FAULT_HIGHTHRESH) {
// Serial.println("RTD High Threshold");
//if (fault1 & MAX31865_FAULT_LOWTHRESH) {
// Serial.println("RTD Low Threshold");
//if (fault1 & MAX31865_FAULT_REFINLOW) {
// Serial.println("REFIN- > 0.85 x Bias");
//if (fault1 & MAX31865_FAULT_REFINHIGH) {
// Serial.println("REFIN- < 0.85 x Bias - FORCE- open");
//if (fault1 & MAX31865_FAULT_RTDINLOW) {
// Serial.println("RTDIN- < 0.85 x Bias - FORCE- open");
//if (fault1 & MAX31865_FAULT_OVUV) {
// Serial.println("Under/Over voltage");
//max_1.clearFault();
//TERMOPAR 2
//uint8_t fault2 = max_2.readFault();
//if (fault2) {
// Serial.print("Fault2 0x");
// Serial.println(fault2, HEX);
//if (fault2 & MAX31865_FAULT_HIGHTHRESH) {
//if (fault2 & MAX31865_FAULT_LOWTHRESH) {
//if (fault2 & MAX31865_FAULT_REFINLOW) {
//if (fault2 & MAX31865_FAULT_REFINHIGH) {
//if (fault2 & MAX31865_FAULT_RTDINLOW) {
//if (fault2 & MAX31865_FAULT_OVUV) {
//max_2.clearFault();
